Alternator load distribution in a Baron
Old December 8th 03, 01:55 PM
Viperdoc
Default Alternator load distribution in a Baron
My 1980 B-55 has uneven load distribution on the two alternators, with the
right side consistently reading around 15% lower than the left.
Is this an indication of a problem with the alternator like a bad diode, or
is this normal operating behavior?
Old December 8th 03, 08:28 PM
Bill Hale
"Viperdoc" wrote in message ...
They match within 15%? That's great. Even tho the POH suggests better.
You should check to verify that each can handle the load by itself, even at
fairly low RPM like 1500. That will eliminate the possibility of
failed diodes.
You do switch between regulators on each trip, don't you? That
way you know both regulators work. T'aint redundant otherwise.
Bill Hale, BPPP instructor
Old December 8th 03, 09:04 PM
Nathan Young
I had a similar problem with a Seneca. Except is was more like 80/20.
Turned out to be the voltage regulators being set higher on one
alternator than another.
-Nathan
Old December 8th 03, 11:40 PM
Viperdoc
Yes, I switch the voltage regulator on every flight. The concerns that I
voiced regarding the alternator load came from an article in the American
Bonanza Society magazine, where another Baron owner saw similar behavior.
This article suggested that it might be a bad diode in the weaker
alternator.
As a matter of fact, I called the ABS today, and they suggested that the
observed difference could be due to a poor ground, and suggested
investigation of the same. I hope to do this in the near future.
Thanks.
Old December 9th 03, 12:40 AM
David Lesher
"Viperdoc" writes:
alternator.
Could be bad grounds. Could be bad diodes.
But unless the two voltage regulators EXACTLY track {and they never
do} one will work harder than the other. That's life.
You can test for bad diodes with a fair degree of success as follows.
With one alternator on line at idle, load it down, say the landing
lights. Listen carefully in your headset for whine, dependent on
RPM. Then swap to the other alternator. If one is missing a diode,
it likely will have far more audible whine than the other.
(I'm having a hard time picturing how you swap regulators. Does
this aircraft use one regulator for both alternators???)
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old December 9th 03, 02:57 AM
Viperdoc
The B-55 has two voltage regulators, which are switchable from inside the
cockpit. I plan on flying locally tomorrow, and will check the diodes for
each alternator.
Old December 9th 03, 02:59 AM
Viperdoc
Just thinking: does cutting the alternator (belt driven) in and out with the
engine running damage anything?
Old December 9th 03, 11:27 PM
PaulaJay1
In article , "Viperdoc"
writes:
I hope not. I start my Archer with the Gen field off and then turn it on after
engine start.
Chuck
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 10:07 PM
Beach Baron Crash Kevin Owning 0 November 22nd 03 01:40 AM
Red Baron vs. Rickenbacker? Gregorso Military Aviation 28 October 13th 03 08:26 PM
Red Baron reports and other stuff Qs Zajcevi Military Aviation 5 September 7th 03 06:32 PM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 05:02 AM
