Normal EGT - Very Low CHT
Old March 3rd 04, 06:36 PM
markjen
Default Normal EGT - Very Low CHT
I was flying yesterday and noted on my GEM that on cyl #1, the EGT was
normal, but the CHT was very low. Most of the time the CHT was off the
scale low, so there was essentially no reading, but occasionally it would
come up enough to be at the bottom or one bar from the bottom of scale.
I can't think of a scenario which would cause normal EGT, but CHT 150 deg
lower than normal. The engine runs normally. So I'm suspecting a bad CHT
sensor although it if failed outright the GEM manual says it would just be
missing all the time. Any other ideas? (This is on an IO-520 in a Bonanza,
BTW.)
- Mark
Old March 3rd 04, 06:59 PM
Ron Rosenfeld
On Wed, 03 Mar 2004 17:36:59 GMT, "markjen"
BTW.)
- Mark
Loose connection.
Bad probe
Bad channel in the GEM.
Old March 3rd 04, 07:46 PM
Jim Weir
You nailed it.
Ron Rosenfeld
-Loose connection.
-Bad probe
-Bad channel in the GEM.
http://www.rst-engr.com
Old March 3rd 04, 09:29 PM
Dan Luke
CHT 150 deg lower than normal. The engine runs normally.
I'm betting on Ron's #1 choice: a bad connection. First place to look
is the splice between the wire coming from the GEM and the lead coming
from the probe. These are often screw/star washer/ring terminal/nut
affairs that can become loose. They're usually in the engine compartment
covered by sleeves.
Dan
C172RG at BFM
(remove pants to reply by email)
Old March 4th 04, 12:45 AM
Jon Woellhaf
When my mechanic had my JPI installation half finished, I noticed in the
installation manual that JPI specified the star washer be _between_ the ring
terminal from the probe and the wire to the display. I thought that was
interesting and unusual. He had been putting them under the nut. After I
pointed that out, he made the remaining connections with the star washer
between the terminals. I've noticed no difference in operation so far.
Jon
"Dan Luke" wrote in message
covered by sleeves.
Dan
C172RG at BFM
Old March 4th 04, 07:09 AM
markjen
Thanks for all the good ideas guys, appreciate it.
- Mark
Old March 4th 04, 07:21 AM
Is it possible that the probe is not making good thermal contact with the
cyl. head?
-Elliott Drucker
Old March 4th 04, 02:54 PM
Dan Luke
"Jon Woellhaf" wrote:
... I noticed in the installation manual that JPI specified the star
washer be _between_ the ring terminal from the probe and
I've had one become loose, but I don't remember what the assembly order
was. Next time I've got the cowl off, I'll check a couple.
Thanks for the tip.
Dan
C172RG at BFM
Blackbird v. Mig-25 Vello Kala Military Aviation 79 September 15th 04 05:05 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 03:18 PM
Accelerated spin questions John Harper Aerobatics 7 August 15th 03 08:08 PM
