#21
Jim Weir wrote...
Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? NONLUMBER? For a 2'x6' top? Shoot, Home Despot has marble for, like, $70/sf. Steel's probably too expensive too. If it doesn't have to be super rigid you might try 0.064 AL. The short answer is there probably isn't anything readily available and cheap. Bricks, maybe, or patio pavers. Me, I'd use plywood and slather epoxy on it. That's what I do already. Whenever I have leftovers I just dump it on one bench in particular and squeegee it over the top. But that's not what you asked. Dave 'hardtop' Hyde |
Cast some concrete in a 2" form?
How about some of those new plastic deck 'boards'. -- Dan D. .. "Jim Weir" wrote in message ... Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? I'm not making 747s, fellers, nor am I building spars. The worst I might want to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor Freight benchtop drill press. Jim Jim Weir shared these priceless pearls of wisdom: -However, since I'm going to a new method of framing, I'd like thoughts on what -you have used as workbench/shelving materials. The benches will be about 2' -wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick -and cheap is high on the list of attributes I'm looking for. - -Thoughts appreciated. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Blueskies wrote: How about some of those new plastic deck 'boards'. I used those on the last deck I built. It's like working with spaghetti. You'd need lots of reinforcement, and it won't take any punishment. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
#24
On Fri, 05 Mar 2004 03:27:40 GMT, "G.R. Patterson III"
wrote: Blueskies wrote: How about some of those new plastic deck 'boards'. I used those on the last deck I built. It's like working with spaghetti. You'd need lots of reinforcement, and it won't take any punishment. Trek? I'd have said it's like working with slippery iron and you need a truss (for the hernia you'll get from lifting it). DO NOT BUILD AIRPLANES OUT OF THIS STUFF. (ObContent) Don |
#25
Don Tuite wrote:
On Fri, 05 Mar 2004 03:27:40 GMT, "G.R. Patterson III" wrote: Blueskies wrote: How about some of those new plastic deck 'boards'. I used those on the last deck I built. It's like working with spaghetti. You'd need lots of reinforcement, and it won't take any punishment. Trek? I'd have said it's like working with slippery iron and you need a truss (for the hernia you'll get from lifting it). DO NOT BUILD AIRPLANES OUT OF THIS STUFF. (ObContent) Don I'm building some walls in the shop using steel studs. Light steel sections (maybe .020 thick?) rolled into the most beautiful beams, channels, other odd shapes... All three times too heavy. Richard |
#26
Jim Weir wrote in message . ..
Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? What are your operating parameters? How sturdy? Chemical resistance? Impact resistance? Easy to clean? Non static? Humidity resistant (no rot or rust)? My favorite work bench is part of an old restaurant. 1" galvanized steel structure, 14 ga stainless top with a nice rounded lip on the back to keep things from rolling off. The only thing that I could never clean off was some oil from a MB diesel. Nasty stuff. The oil not the Merc. |
#27
you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. Restaurant supply houses that specialize in used equipment will have stainless steel tables. Size / price / condition will vary. Might be able to find a butcher's table. I suspect that it's a sheet of teflon-like stuff (those white plastic cutting boards) laid over SS. Plexiglas / Lexan? You could stiffen it up with bracing on the underside. Foam board used for insulating houses and some a/c designs? You can get it thick for stiffness, though it won't handle beating on. It'll take pins well if you're building balsa models or laying out wiring harnesses. Just don't try to solder on it. ;-^ Corian / synthetic stone counters. Not cheap, unless you can find one salvaged or scrap. Some towns have architectural recycling centers where you can get pre-owned building materials cheap. (Might even find some old luan doors.) They might have a counter top or two; likewise the manufacuter or an installer might have a damaged or customer-rejected one they'd unload at cost. Why do you want a non-wood top, anyway? |
#28
http://www.roscoemoss.com/specs.html
-- Dan D. .. "Blueskies" wrote in message .com... Cast some concrete in a 2" form? How about some of those new plastic deck 'boards'. -- Dan D. . "Jim Weir" wrote in message ... Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? I'm not making 747s, fellers, nor am I building spars. The worst I might want to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor Freight benchtop drill press. Jim Jim Weir shared these priceless pearls of wisdom: -However, since I'm going to a new method of framing, I'd like thoughts on what -you have used as workbench/shelving materials. The benches will be about 2' -wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick -and cheap is high on the list of attributes I'm looking for. - -Thoughts appreciated. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Benchtops & Shelving | Jim Weir | Home Built | 30 | March 6th 04 02:32 PM |
