Attaching braided ground to aluminum skin
Old May 20th 04, 04:43 AM
Ben Jackson
Default Attaching braided ground to aluminum skin
My lower tail nav light doesn't work because the braided metal ground
strap that connected the tailcone to the light housing fell off the
tail cone side. I can't tell (at least from the outside) how it was
originally attached to the aluminum skin. I don't see a rivet -- would
it have been soldered? Crimped somehow?
Ben Jackson
http://www.ben.com/
Old May 20th 04, 01:16 PM
JDupre5762
tail cone side.
Usually they are connected with a crimp ring tongue on the braided strap and by
a screw to the frame that the tail cone attaches to.
John Dupre'
Old May 20th 04, 04:51 PM
mikem
You didn't specify make/model, but on my C182, the Grimes lamp
holder assembly is mounted on the fiberglass tailcone. There
are two wires, power and ground. Each has the aircraft-style
"quick connect" interlocking-blade connectors (the kind
that have a piece of insulating sleeve pushed over them).
The power wire comes through the rear fuselage bulkhead via
a grommet. The ground wire is grounded to that same bulkhead
with a crimp-on ring-tongue terminal under a 6-32 screw.
At each annual, it only takes a moment to remove the fiberglass
tailcone and to disconnect the blade-tongue connectors.
MikeM
Almay Hypo-Allergenic Kinetin Skin Care Value$32.89 [email protected] Aviation Marketplace 0 April 30th 04 12:41 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
