Chelton vs Avidyne
Old May 21st 04, 09:32 AM
Charles Talleyrand
Default Chelton vs Avidyne
Ray Andraka wrote in message ...
I called an aviation supply house today. I'm told that you cannot get a
Garmin 1000 for any price, and that they do not intend to market to the
refit market. So the answer is .... no.
I'm told an Avidyne would not recieve a field approval from any field office.
It would need an actual STC. This supply house says they are on good terms
with the local FAA, but there is little chance of success on a field
approval.
The Chelton Flight Systems units seem at least as capable and invasive as an
Avidyne and they have an STC for something like 650 models.
I have no idea why the difference. Anyone?
Old May 21st 04, 04:31 PM
Bravo Delta
office.
terms
approval.
an
Chelton got the STC covering all the aircraft models because of the Capstone
program in Alaska.
Old May 22nd 04, 06:14 AM
Charles Talleyrand
"Bravo Delta" wrote in message ...
office.
terms
approval.
an
program in Alaska.
Yes, but Chelton only got $8 million from the Capstone program
if I remember right. That's probably not enough to get an STC for
sooo many different models. Chelton on their web site says that they
have 650 models STCed. I also read that the capstone program is to equip
only 210 different airplanes (presumably lots of them of the same
model).
I really wonder if Chelton and Avidyne are being held to different
requirements/standards.
Old May 22nd 04, 02:43 PM
Doug Vetter
model).
Perhaps. I heard that the Capstone project timeline and budget were
such that the FAA needed to reduce the regulatory hurdles associated
with the approvals to get a number of diverse aircraft types involved in
the project. The only way to do that quickly was to issue a "blanket"
STC. IMHO, there's nothing special about the hardware or software of
the Chelton gear, aside from the fact that it's been flying longer than
the Avidyne equipment in experimental aircraft.
Just goes to show you how much the FAA is intentionally slowing
innovation, how much faster it can move when properly motivated, and why
so many people are building experimental airplanes to avoid all the
hassle. I just can't see why the FAA can't get out of its own way to
allow these installations. How a 40 year old automotive style analog
gauge is more accurate or safe than a solid state transducer coupled to
an electronic display is beyond me. I'll agree that "new" isn't always
better, particularly if it's not properly tested, but com'on!
To respond to the OP regarding the G1000, I heard from my avionics guy
(who is quite close to people inside Garmin) that certification in the
aftermarket is "at least 3 years out" assuming they do it at all. While
not particularly encouraging, it's not exactly the same as "no way hose
a". Perhaps there is hope after all.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 04:08 PM
Question on Avidyne FlightMax Jim Caldwell Instrument Flight Rules 6 March 12th 04 06:10 AM
Nashua Festival, Avidyne and WSI Doug Vetter Owning 9 September 24th 03 03:45 AM
