Slaving autopilot to a VOR?
Old May 24th 04, 08:46 PM
Jay Honeck
Default Slaving autopilot to a VOR?
My autopilot (2-axis, Piper) is hooked up to my DG, via a "heading bug."
Otherwise, it's just a wing leveler.
I've been told that this autopilot has the capability of being connected to
my VORs.
Can anyone outline what's involved with connecting the two?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 24th 04, 09:16 PM
Dave Butler
my VORs.
Thanks!
I suspect what you have is something like a Piper Autocontrol? Two axis? You
mean it has altitude-hold?
Well, anyway, I think what you need is something like this MITCHELL RADIO
COUPLER FOR CENTURY III AUTOPILOT
http://cgi.ebay.com/ebaymotors/ws/eB...m=2479416 829
....but (assuming all my assumptions above are true) I predict you won't like it.
If there's any unsteadiness at all in the VOR signal, the autopilot will
follow the swinging CDI. There's some damping built into the coupler, but
still... Even when the VOR signal is rock-steady, all (well, OK, 2) the
installations I've seen will "hunt" back and forth across the centerline of the
signal. There might be a sensitivity adjustment that will correct this.
When I had one, I nearly always used it in heading (not NAV) mode, except for
the occasional coupling with a localizer for instrument practice. Actually, I
always felt guilty using it on the localizer. It made the approach too easy.
Dave
Old May 24th 04, 09:52 PM
Jay Honeck
You
Hmm. I thought 3-axis was altitude-hold? Whatever, all mine does is hold
the wings level, and follow the bug...
Thanks for the tips! I'd be interested to hear from folks who have these
things -- do they hunt all over, or can that be damped?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 24th 04, 09:59 PM
Dave Butler
You
You're right. In common usage, wing-leveler plus heading mode equals a two-axis
autopilot. I've always rebelled against that usage. To me an axis is
roll-pitch-yaw. Unless the autopilot controls two of those, it's a one-axis
autopilot... but I'm swimming against the tide.
Dave
Remove SHIRT to reply directly.
Old May 24th 04, 10:04 PM
Marc J. Zeitlin
Jay Honeck writes:
these
I have a single axis autopilot (Navaid) in my homebuilt. I have it
hooked up to my Garmin 195 GPS or to my Narco 122A NAV (via a switch).
Tracking the GPS is rock solid - no hunting whatsoever. Tracking the
VOR is a roller coaster. I watch the CDI needle, and it's always
jumping around a bit, and the AP tries to follow it, even when it goes a
dot to the left, and then two seconds later, a dot to the right.
The problem is in the VOR, not the AP - if your VOR CDI needle is
jumping around a bit, so will the AP when trying to track it. If your
VOR needle stays stuck (no clue if this jumping is a function of MY
receiver or of the inaccuracy of the basic system), then you'd probably
be OK tracking with the AP.
If I track an ILS/LOC, which never jumps around on my CDI, the AP is
solid, so I know it's not the VOR/AP combination.
At any rate, if it's easy to connect, give it a try. If not, don't
bother, especially if your needle is jumpy.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2004
Old May 24th 04, 10:37 PM
Ray Andraka
My STEC 20 is slaved can be slaved to my #1 VOR or to my Loran. It has front
panel selection of high and low sensitivity modes. Normally, for VOR's you'd
use the low sensitivity mode to minimize the manuevering to stay on a scalloped
signal. It flies a VOR radial just fine, no obvious hunting. It is a single
axis autopilot.
You
Jay Honeck
Iowa City, IA
Pathfinder N56993
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old May 24th 04, 10:57 PM
PaulaJay1
In article tossc.53968$gr.5228519@attbi_s52, "Jay Honeck"
writes:
Jay Honeck
The Autocontrol III in my Archer has switches that allow it to track a VOR, the
LORAN, or the GPS. The LORAN and the GPS (Garmin 430) do a better job of
flying a heading and not wandering but I wouldn't say the the VOR is bad. If
you are tracking a VOR that is distant and the signal is weak, you might be
better to watch the needle and use the heading bug, but if you are close (30
miles) and have a good signal, there isn't much of a problem. Get a 430 though
and you will think that you are on rails!
Chuck
Old May 25th 04, 12:41 AM
Michelle P
Jay,
if you are thinking about hooking up a VOR why not a GPS? The outputs
can be the same depending on the head configuration.
Michelle
my VORs.
Thanks!
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old May 25th 04, 01:47 AM
Aaron Coolidge
Dave Butler wrote:
: ...but (assuming all my assumptions above are true) I predict you won't like it.
: If there's any unsteadiness at all in the VOR signal, the autopilot will
: follow the swinging CDI. There's some damping built into the coupler, but
: still... Even when the VOR signal is rock-steady, all (well, OK, 2) the
: installations I've seen will "hunt" back and forth across the centerline of the
: signal. There might be a sensitivity adjustment that will correct this.
I also predict that Jay won't like it. I have an "Autoflite I" with the NAV
coupler. When coupled to the NAV (NAV1, FWIW), the needle stays dead centered.
But, look at the ground track on the GPS! It's moving all over! Who's flying
this thing?
Seriously, unless you're right on top of the VOR, or it's a Doppler VOR
(DVOR), the radials move around. A lot, in fact. The only steady one that
I routinely fly over is JFK.
When the autopilot is coupled up to the GPS following a radial, the VOR
needle moves around. The GPS guides the airplane where the radial is
supposed to be! This can get a bit nerve-wracking, especially if you're
flying, say, V3 in the gauntlet between ORL's "B" and Cape Canaveral's
restricted areas.
Aaron Coolidge
Old May 25th 04, 02:17 AM
BTIZ
lets see.. wing leveler and heading control... sounds close to roll and
yaw..
BT
"Dave Butler" wrote in message
To me an axis is
one-axis
Rain and autopilot unstable W9MV Owning 3 May 18th 04 09:51 PM
mitchell autopilot dave Owning 1 May 5th 04 07:11 PM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 08:17 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 04:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 03:01 AM
