Diesel aircraft engines and are the light jets pushing out the twins?
Old September 17th 04, 09:13 PM
A gas turbine scales up easily and but is nearly impossible to scale
down. The auto manuacturers found that out in the 1940s - remember
the "car of the future" on the covers of Popular Science et al?
Turbines for cars are further away now than they were 55 years ago.
The turbine suffers from excessive fuel consumption at part throttle
(the piston engine is incredibly flexible that way)and in smaller HP
installations.
So much of the useful load of an aircraft is fuel, that fuel
efficiency is very important for overall mission performance.
The problem of an engine is to find the most efficient way to expand a
certain flow rate of compressed hot gas to atmospheric pressures. A
turbine can do this with large mass flow rates, but as the flow rates
become smaller, the turbine speeds (rpm) must increase enormously and
the centrifugal accelerations get out of hand. On the other hand, a
piston can process an expansion efficiently with small flow rates.
Think of it this way - a model airplane engine can be made to run with
1/20 of a cubic inch (.049 cu inch to even .010 cu inch), but piston
engine aircraft became impractical above a few thousand HP. That is
the range of practicality for a piston concept.
An engineering prof once said - if the gas turbine had been invented
first, the piston engine would have been looked on an ingeneous
solution to the turbine's material and speed and power range problems.
Diesels may eventually make it. They have a weight problem that may
be offset by a lower specific fuel consumption, but for a given
operating condition, spark ignition engines can nearly approach the
consumption of diesels by using turbo compounding and operation only
at full throttle.
Old September 17th 04, 10:04 PM
installations.
at full throttle.
While not quite a .049, here's a 3.7" in diameter, 2.6 lb turbine
that produces 16.5 lb of thrust.
http://jetcatusa.sitewavesonline.net/p70.html
Their biggest turbine is 5.12", 5 lb, and produces 45 lb of thrust.
Here's another outfit that sells a 3.5" diameter, 7.25" long, 1.9 lb
turbine with 11.4 lb of thrust.
http://www.swbturbines.com/model_turbines.htm
Now granted these are turbojets, not turboprops, but it appears to me
that making small turbines is possible...
Jim Pennino
Remove -spam-sux to reply.
Old September 17th 04, 11:16 PM
Mike Rapoport
installations.
at full throttle.
Jim Pennino
You are missing the point. Everyone agrees that small turbines can be
built, the issue is fuel consumption. What is the specific fuel consumption
per lb of thrust?
Mike
MU-2
Old September 18th 04, 12:28 AM
Jim Pennino
per lb of thrust?
Not quite "everyone" has signed on to that notion and you are one of few
that has wanted to talk about numbers as opposed to making sweeping
statements.
For the 16.5 lb thrust engine it is 1.8 lb/hr-lb thrust, but I doubt fuel
efficiency is a design criteria in a model airplane engine.
The question remains, at what HP level, based on the physics of the engines,
does the crossover from piston to turbine occur?
As additional criteria, assume specific fuel consumption is the most
important parameter and that the A/C spends the majority of its time in
flight not doing touch and goes.
Jim Pennino
Old September 18th 04, 12:31 AM
About the size of the Caravan 900hp+
Mike
MU-2
According to the Cessna website, the current Caravan is 675hp.
Jim Pennino
Old September 18th 04, 12:39 AM
Mike Rapoport
Jim Pennino
consumption
per lb of thrust?
statements.
engines,
Jim Pennino
I think that you can look at the market to see where the crossover occurs.
THere are currently no production piston aircraft engines over 450hp and
there are no aircraft turbines under 400hp.
Mike
MU-2
