Impulse Coupling on Magneto
Old October 1st 04, 12:42 PM
Kai Glaesner
Default Impulse Coupling on Magneto
Hello community,
I have a question I think some of you may be able answer: in most(?)
reciprocating engine installations, the left magneto seems to have a impulse
coupling, enabling the magneto to produce a spark strong enough for ignition
even at low (starter cranking) RPM's.
The question: does the coupling alter the ignition _timing_ (e.g. towards
late), too?
I hear this, sometimes, as the main reason why you should put the ignition
shift in the "L"eft position when handpropping the engine and, while doing
so, preventing the right (early igniting) magneto to kick back the prop.
Thanks in advance for the answer....
Best Regards
Kai
Return address is invalid to help stop junk mail.
Old October 1st 04, 01:06 PM
Paul Sengupta
"Kai Glaesner" wrote in message
om...
Hello community,
impulse
ignition
late), too?
Yes.
Old October 1st 04, 04:50 PM
Paul Sengupta wrote:
: I hear this, sometimes, as the main reason why you should put the ignition
: shift in the "L"eft position when handpropping the engine and, while doing
: so, preventing the right (early igniting) magneto to kick back the prop.
: Yes.
... and I believe it's on the order of 5 degrees ATDC. Hand-propping with one
mag set to fire 25 BTDC could ruin your day, although it's fairly unlikely to fire at
such a slow speed.
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old October 1st 04, 05:37 PM
G.R. Patterson III
late), too?
Yes.
This is correct if the left mag has an impulse coupling and the right does not. It's
unlikely that the right mag will cause kickback, since it will not produce a very
strong spark while handpropping, but it's possible.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old October 3rd 04, 12:27 AM
Dan Thomas
"G.R. Patterson III" wrote in message ...
late), too?
Yes.
George Patterson
My A-65 starts best on Left (impulse) mag only. If I try to
start it on Both, the right one will start firing before the engine
has passed thru 150 RPM or so, and will sometimes kick back and quit.
The mags are 58-year-old Case tractor mags, originally certified for
aircraft use, and still produce a hotter spark than a brand-new Slick.
Dan
magneto installation help Dick Home Built 5 February 10th 05 04:02 PM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 08:59 PM
Burning out a Magneto Drop O. Sami Saydjari Owning 23 March 2nd 04 10:42 PM
Club Membership: Getting for what one's wished Andrew Gideon Owning 11 October 18th 03 05:18 AM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 04:01 AM
