Cool Oil Temperatures
Old January 11th 05, 10:28 PM
Mike Rapoport
"Ross Richardson" wrote in message
Now that is interesting. When I purchased this aircraft it had the oil
screen instead of the spin on oil filter. The vernitherm was located in
that casting. When I installed the spin on oil filter adapter the
vernitherm was transfered to the adapter. I am not sure of the
temperature rating. How do I tell the rating of the vernitherm since it
is not in the cooler?
Mike Rapoport wrote:
"Ross and Paula Richardson" wrote in message
You should check the rating on the vernitherm which is usually mounted on
the side of the cooler. It should have a rating on it. My Helio Courier
has low oil temp too but only because the vernitherm is a 165F unit. I
am
thinking about replacing it with a 180F unit. You need to do this before
experimenting with blocking off part of the oil cooler.
Mike
MU-2
On the ones I have seen the rating is stamped onto the part.
Mike
MU-2
Old January 12th 05, 01:54 AM
nrp
Yes - I believe the vernatherm is a cooler bypass or shunt valve.
You might try blocking the cooler air inlet completely & do a short
flight to see what happens. I used a foam plug wrapped with a
polyethylene bag - all aircraft approved of course.....
Oil Temperatures Ross Richardson Owning 12 August 19th 04 07:58 PM
Another cool RV added to the Rogue's Gallery! Jay Honeck Home Built 4 January 17th 04 03:35 PM
Another cool RV added to the Rogue's Gallery! Jay Honeck Owning 4 January 17th 04 03:35 PM
Bead-blasters are cool! Jay Honeck Owning 4 January 16th 04 12:16 AM
Cool aviation downloads for you all Andrew [email protected] Instrument Flight Rules 0 September 7th 03 04:49 AM
