#21
Actually there is a 3/32, 1/8, 1/4? set of collets available from
Princess Auto that seem to work fine with #30 and #40 bits in their cheap 90 degree die grinder. It gets into tighter places that way than it could with a chuck. I find that it turns too fast though and needs a steady hand or it will cut sideways like a router ;( It will make a hole real quick though if you don't have anything else that can get access to where you are working ![]() Ken I have an ancient direct-drive air drill I found at a Princess Auto here in Canada. No gears in it, and it turns at some insane speed like an air die-grinder, maybe 15 or 20,000 RPM. It sure does a nice job on small holes in aluminum, very little tendency to skid. I wonder if it might be worthwhile to make a threaded adapter for a 1/4" chuck and clamp it into the collet of a 90-degree die grinder? Or are there any pistol-grip die grinders? Dan |
"acepilot" wrote in message ... I have a 60 gallon upright air compressor and it seems to run the air drill fine. I've never seen an electric drill that turned RPMs in the thousands. I have an electric drill that runs at 3000, great for drilling 1/8 but not that good for under that size. It's home made, used the motor out of a B&D lawnmower, it used the same caseing as one of the small B&D's but with a higher gear ratio. -- --- Cheers, Jonathan Lowe. / don't bother me with insignificiant nonsence such as spelling, I don't care if it spelt properly / Sometimes I fly and sometimes I just dream about it. :-) My Makita cordless at work might do a few HUNDRED RPM. When I bought my Sioux, it was the highest speed air drill I found at an aviation tool supply. Oh well, that's life... Scott Veeduber wrote: I love my Sioux drill. Great trigger. Mine only goes 2600 RPM. Seems to do just fine at that speed. ------------------------------------------------- Dear Scott, I don' t want to bust up your romance but I suggest you borrow a drill-motor that turns at a higher speed and shoot a few holes. You really don't know what you're missing. I usta have a B&D 'aviation' drill motor, turned something like 4000 rpm. Wore it out. Had it rebuilt. Twenty years later it needed another rebuild but the bull-gear was not available at a price I could afford. Since then I've been using those cheap Chinee imports that turn 3600 rpm, last just about long enough for one airplane's-worth of holes, throw it away when it gets noisy. Air tools are nice but compressing air to drive a drill puts you on the wrong side of the economic equation here in southern California. That's a point a lot of newbies miss. Pneumatic drill is a real air hog; takes a pretty good compresser to keep you working. (On the other hand, pneumatic riveting hammers or squeezers don't use much air.) If a guy doesn't already have a big compressor, when you add the acquisition cost to the operating cost and divide by the number of holes, it represents a significant increase in cost when compared to using throw-away electric drill motors. -R.S.Hoover |
On Sun, 7 Mar 2004 00:18:18 -0000, "Model Flyer"
wrote: "acepilot" wrote in message ... I have a 60 gallon upright air compressor and it seems to run the air drill fine. I've never seen an electric drill that turned RPMs in the thousands. I have an electric drill that runs at 3000, great for drilling 1/8 but not that good for under that size. It's home made, used the motor Why would you want to run a drill bit that fast? I normally use less than half that speed even for the tiny ones. Although I have a number of air tools, I learned to hate that sound after working on an assembly line in my younger days. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com out of a B&D lawnmower, it used the same caseing as one of the small B&D's but with a higher gear ratio. |
#24
In Roger Halstead wrote:
On Sun, 7 Mar 2004 00:18:18 -0000, "Model Flyer" wrote: I have an electric drill that runs at 3000, great for drilling 1/8 but not that good for under that size. It's home made, used the motor Why would you want to run a drill bit that fast? I normally use less than half that speed even for the tiny ones. Although I have a number of air tools, I learned to hate that sound after working on an assembly line in my younger days. Because they work better at the higher speeds. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
