#11
On Thu, 06 Nov 2003 17:06:23 GMT, "Bob Gardner"
wrote: A checklist doesn't mean that you have to do something, just that you should think about it. Your mention of flaps is a good example...FLAPS should be part of the landing checklist, and it means "what flap setting, if any?" This does not contradict my reply to BoDean. Bob Gardner I wasn't commenting on your message, I was responding to the original post. My experience has been that other than flaps and mixture, with the fuel injected engined 172's there's nothing else to adjust. You pretty much cannot land the airplane without thinking about the flaps, or at least I can't, so digging out the checklist and reading "set flaps", or whatever it says seems unnecessary to me at a time when you want to be concentrating on holding pattern altitude, your position in regards the runway, airspeed and traffic. Complex airplanes would of course be different, but the question was stated in regards "Cessna 172/152." Corky Scott |
On Thu, 06 Nov 2003 17:36:14 GMT, Newps wrote:
Skip the seatbelts. That's probably the only thing on the list required by regulation: http://www.access.gpo.gov/nara/cfr/c...4cfr91_00.html § 91.107 Use of safety belts, shoulder harnesses, and child restraint systems. ... (2) No pilot may cause to be moved on the surface, take off, or land a U.S.-registered civil aircraft (except a free balloon that incorporates a basket or gondola, or an airship type certificated before November 2, 1987) unless the pilot in command of that aircraft ensures that each person on board has been notified to fasten his or her safety belt and, if installed, his or her shoulder harness. (3) Except as provided in this paragraph, each person on board a U.S.-registered civil aircraft (except a free balloon that incorporates a basket or gondola or an airship type certificated before November 2, 1987) must occupy an approved seat or berth with a safety belt and, if installed, shoulder harness, properly secured about him or her during movement on the surface, takeoff, and landing. For seaplane and float equipped rotorcraft operations during movement on the surface, the person pushing off the seaplane or rotorcraft from the dock and the person mooring the seaplane or rotorcraft at the dock are excepted from the preceding seating and safety belt requirements. .... |
BoDEAN wrote: How many people do / teach doing a full before landing checklist when doing pattern work? I flew with at least six different instructors during training for my PPC, two others for transition to tailwheel, and several others for BFRs. None used checklists during landing, nor did any of them recommend that I create one or use one. I don't have or use one in my Maule, but there aren't a whole lot of things to remember. I think I would develop the habit of using one if I were flying more complex aircraft, or if I were flying several different types of aircraft. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
"G.R. Patterson III" wrote in message
... BoDEAN wrote: How many people do / teach doing a full before landing checklist when doing pattern work? I flew with at least six different instructors during training for my PPC, two others for transition to tailwheel, and several others for BFRs. None used checklists during landing, nor did any of them recommend that I create one or use one. My instructors talked about it, but didn't regularly reinforce the habit and as a result I often forget. In a 172 and similar, there really is nothing to actually *do* as a result of the checklist (I think that was the point about the seatbelts; you always know you are wearing them) and, ironically, if you do the check on downwind you probably don't pull the carb heat yet. On the occasions when I do remember or am reminded, I usually take care to actually touch the fuel selector, mixture, and primer, and look down at the gear. I hope I'm creating habits that will help when I fly something more complex, but right now I'm worried about re-creating the checklist habit in the first place. -- David Brooks |
David Megginson wrote: ('Vejita' S. Cousin) writes: Define 'full'? I mostly fly C152 and GUMP pretty much covers everything. I do speed/flaps as I fly the pattern. What do you do for the "U" and "P" in a 152? Check gear is down and welded. Check prop pitch is fixed. Actually when I was a student I did These days my actuallychecklist is: 1. Seatbelts secure 2. Fuel both (not really necessary as I check this prior to takeoff too) 3. Mixture (as needed, normally full rich) |
"'Vejita' S. Cousin" wrote in message ... In article , David Megginson wrote: ('Vejita' S. Cousin) writes: Define 'full'? I mostly fly C152 and GUMP pretty much covers everything. I do speed/flaps as I fly the pattern. What do you do for the "U" and "P" in a 152? 2. Fuel both (not really necessary as I check this prior to takeoff too) The engine is running isn't it? The only choices you have in the 152 are BOTH and OFF. Frankly, we NEVER touched that lever. |
What do you do for the "U" and "P" in a 152? Check gear is down and welded. And check that the parking brake is off. Jose -- (for Email, make the obvious changes in my address) |
Newps wrote: That's probably the only thing on the list required by regulation: Yeah, that's my point. Who takes them off? You never know. Actually, it doesn't matter. The reg requires you to notify all passengers whether they have the belts on or not. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
