Time to change the air in your tires
Old March 21st 04, 02:03 PM
Stealth Pilot
On Fri, 19 Mar 2004 16:18:39 -0800, "Rich S."
(Shamelessly stolen & edited from the garden & lawn tractor forum)
Well spring is nearly upon us, and the oft-forgotten task of removing
the winter air from your airplane tires needs to be completed before the
temps hit 60.
can I offer you a bottle of australian air? we have next to nothing in
the way of air pollution which means that the stuff isnt perpetually
corroding out the inner tubes. we typically use the air for the life
of the aircraft.
btw an added bonus of australian air is that the eucalyptus aroma
(which is really quite pleasant) is instantly detected warning you of
a tyre leak.
Stealth ( it is available here pre heated at the moment ) Pilot
Old March 21st 04, 06:05 PM
Tim Ward
"Stealth Pilot" wrote in message
removing
temps hit 60.
of the aircraft.
a tyre leak.
If you buy the Australian air, be sure to switch your left tire for your
right, and vice versa, since the residual Coriolis force will tend to make
them rotate the wrong way.
Tim Ward
Old March 21st 04, 09:26 PM
Dan Thomas
Stealth Pilot wrote in message . ..
temps hit 60.
Here's a certified source of Tire Change Air:
http://www.mufflerbearings.com/products.htm
They have other useful products, too.
Dan
Old March 22nd 04, 03:48 PM
moby
What is this crazyness? What homebuilder inside joke am I missing out on.
"Rich S." wrote in message
removing
temps hit 60. Last year I made the ghastly mistake of allowing my mechanic
to change my air, and darnit if he didn't put RV air in my beloved
Emeraude.
The poor green baby shook and sputtered terribly, and had flat tires
within
an hour. Luckily my rims were not ruined.
Remember to use caution when jacking up your planes, and do not be
fooled by cheap imitation spring air offers on ebay - you need genuine,
temperature and pollen tested spring air for successful homebuilt aircraft
use.
Happy Spring!
Rich S.
Old March 22nd 04, 06:33 PM
Rich S.
"moby" wrote in message
Try this site for more insight http://home.swipnet.se/~w-40823/Eyetest1.htm
Rich S.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Alodine Max Setup time JDupre5762 Home Built 1 September 6th 03 05:40 PM
It's that time of year again. Capt. Doug Home Built 19 September 3rd 03 11:53 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
