Stealth bird
Old November 26th 03, 06:10 PM
Big John
Default Stealth bird
Just some ramblings on stealth.
When the Air Defense Command was in high gear with Radars all over the
States and over lapping coverage, we used 'skin paint' (vs beacon/IFF
or transponder) to located and track aircraft (we didn't think the
Russians would come in squawking for us). The FAA always used
beacon/transponder to make a large blip on their scope for traffic
control purposes.
With that background, what does FAA use today? If they do not use
'skin paint' why can't the 'glass' birds with a wooden prop, turn off
their transponder and fly through all the restricted areas unseen?
I'm not up to speed on current traffic control radar and if they both
'skin paint' and look at transponder returns?.
Anyone want to comment on this thread and expand?
Big John
Old November 26th 03, 10:35 PM
Orval Fairbairn
control purposes.
Big John
There is still a fairly large RCS, even on a glass bird -- engine,
pilot, electronics, wiring, antennae, landing gear, etc. It would take a
lot of expertise to get the RCS down to stealth levels.
Old November 26th 03, 11:02 PM
Big John
Orval
The only thing that reflects radar is metal or things (like paint)
that have metal in them.
The biggest contributor to the return is the engine.
WAG is that a 1 square foot flat plate might be close to equivalent
area reflecting radar if plan built?
A bird built for minimum return might even be less.
Some of the Stealth Birds are supposed to have a reflection equivalent
to a sparrow +/-. GA might get close to that with some special radar
absorbent paint, etc. ?
Big John
On Wed, 26 Nov 2003 21:35:35 GMT, Orval Fairbairn
control purposes.
Big John
Old November 26th 03, 11:06 PM
Big John
Dave
Your words brought back memories. TNX. Should have remembered.
I still think homebuilders can build a Stealth bird.
Some shielding like in the 117 might be an easy way to reduce return
from areas that are not 'glass'.
Big John
On Wed, 26 Nov 2003 17:06:41 -0500, Dave Butler
What you're calling 'skin paint' is what ATC calls "primary radar". The ATC
system that processes transponder returns is called "secondary radar", also
known as ATCRBS (Air Traffic Control Radar Beacon System).
Both kinds of radar operate simultaneously and using antennas that rotate together.
Occasionally you'll hear that either primary or secondary radar is out of
service at a particular facility. If secondary radar is out of service they have
to use some other means of identifying the primary radar returns. If primary
radar is out of service, they can see only transponder-equipped aircraft.
Remove SHIRT to reply directly.
Dave
Dave Butler
Dave
Old November 27th 03, 12:54 AM
Gene Seibel
Used to fly to Mexico about 20 years back in a fabric covered
Tri-Pacer without a transponder. Once, we came back into the US,
cleared customs at Bisbee, AZ and continued on to Albuquerque, NM. We
were met there by customs again, wanting to count passengers. Our leg
to Albuquerque had been very slow with a headwind and they apparently
were not sure that we had not slipped back into Mexico.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
control purposes.
Big John
Old November 27th 03, 01:12 AM
Bob Noel
In article , Big John
at least some restricted areas augment the FAA radars with
primary radars that are better suited to the air defense role
than the FAA radars.
Bob Noel
Old November 27th 03, 01:38 AM
BTIZ
they can still see my composite fiberglass glider with "skin paint", they
are required to watch for "primary returns" below FL180. Some aircraft are
still exempt from carrying transponders.. like balloons, gliders and J-3
cubs..
BT
"Orval Fairbairn" wrote in message
news
control purposes.
Big John
Old November 27th 03, 01:40 AM
BTIZ
glass can be seen, its the square corners (wing fuse joints) and flat
surfaces (wing underside in a turn and vert fin) also reflect radar energy..
does not have to be metal..
BT
"Big John" wrote in message
Dave
Big John
ATC
also
together.
they have
primary
Dave
Old November 27th 03, 02:34 AM
John Harlow
to a sparrow
So, exactly how much metal is used in the construction of the modern
sparrow? ;^)
North Korea Denounces US Stealth Bomber Deployment Otis Willie Military Aviation 0 July 2nd 04 10:20 PM
Why is Stealth So Important? James Dandy Military Aviation 148 January 20th 04 05:17 PM
F-32 vs F-35 The Raven Military Aviation 60 January 17th 04 09:36 PM
How long until current 'stealth' techniques are compromised? muskau Military Aviation 38 January 5th 04 05:27 AM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 04:40 PM
