C-150 for photos?
Old December 4th 03, 05:34 PM
G.R. Patterson III
Dale wrote:
I've opened windows in 150/152/172/182 and 206 and never noticed any
roll or need for any aileron and for certain "nearly full" aileron was
not needed.
You're absolutely correct - that should've been nearly full left *rudder*.
George Patterson
Some people think they hear a call to the priesthood when what they really
hear is a tiny voice whispering "It's indoor work with no heavy lifting".
Old December 4th 03, 07:08 PM
Dale
I still have the same question. I've never noticed a need for control
input with a window open.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old December 4th 03, 11:04 PM
G.R. Patterson III
I did in my '69 Cessna 150J.
George Patterson
Old December 4th 03, 11:33 PM
G.R. Patterson III
Wayne wrote:
Hmmm, I was reading about taking pictures from planes and most recommended a
300mm lens..
While the focal length is desireable, it's difficult to hold a lens that large
steady in something like a 150. If you opt for the longer lenses, I would also
opt for 400 ASA film and use a fast shutter speed.
George Patterson
Old December 5th 03, 12:07 AM
CVBreard
A couple of additional comments:
1.) I generally shoot behind the strut rather than ahead of it (between the
strut and the fuselage), and usually about the 9 o'clock or even 8 o'clock
position in an effort to keep the strut out of the image. I push the seat back
as far as safe.
2.) I generally shoot at 1/750th, even with the two Canon Image Stabilizing
lens 'on'. 400 speed film. I routinely shoot at 200 - 300mm f/l.
3.) You may want to check the window HINGES, particularly in older 150/152/172
series. They may not have been lubricated in DECADES. One of our PAPA members
reports losing a window in flight because the hinge failed.
4.) I've not encountered any significant yaw , pitch or roll problems in any of
the 150/152 and 172s I have flown with the pilot's side window open, no
tired-leg, etc.
5.) Altitude is your friend. The 1500' agl I typically shoot at gives me a
significant additional margin of safety (over, say, 1000' agl) if I have engine
trouble (and I did), generally has smoother air, fewer TV towers. If you can't
get acceptable images at 1500', maybe you need another lens (or camera). :-)
Old December 5th 03, 03:07 AM
Matthew P. Cummings
And I have in my 74 and in a rental 75 and in a rental 66. All required
rudder input only.
Old December 5th 03, 04:35 AM
G.R. Patterson III
rudder input only.
Which is what I said.
George Patterson
Old December 6th 03, 02:49 AM
Matthew P. Cummings
Yup, the second time and I wanted to agree with you and support your
correct observation.
I don't know how those that claim to not notice any change have that
effect since every plane I've ever flown exhibits that change. Of course,
if both windows are open it's a different story, maybe their planes leak
air more than the ones I've flown.
