FAR rules on "ground-effect" vehicles?
Old April 2nd 04, 12:57 AM
Wright1902Glider
Default FAR rules on "ground-effect" vehicles?
Does anyone here know if / what-section-of FAR rules govern the operation of
"ground effect" vehicles? Specifically, how high can a machine fly AGL before
its technically classified as an aircraft and not a hovercraft,
hydroplane-boat, Ecronoplan, etc.? Is there a loophole for a powered airplane
that can't climb to more than 5' AGL?
Second question: If a machine has tricycle gear with nosewheel steering, wings
and 3-axis control, and is solely propelled by thrust from an engine/propeller,
BUT CANNOT FLY, how is it classified? Trike motorcycle?
NOTE: Both of these questions relate to a proposed machine that will weigh
more than 254lbs dry, i.e. not Part 103 legal.
Serious responses please. I'm looking to find and verify a specific FAR rule,
as the correct answer to this question is critical for legal, operational, and
insurance purposes.
Thanks,
Harry Frey
Wright Brothers Enterprises
Old April 2nd 04, 01:10 AM
BllFs6
before
airplane
wings
engine/propeller,
rule,
and
insurance purposes.
Thanks,
Harry Frey
Do an internet search on hovercrafts, WIG, Wing in Ground effect etc etc....
I dont remember the exact sites, but IIRC as long as it CANNOT get and stay out
of ground effect, ie KEEP gaining altitude...it AINT an aircraft...and it can
wiegh what ever you want....though its still a good idea to keep it
light.....(though high hops that utilize the vehicles kinetic engery, trading
off temporary altitude for speed are allowed)....its considered an ocean going
vessel and you actually have/should register it with the coast guard....and if
you do you'll probably be one of only a handful of people on the planet that
has such a registration.....
Now if you fly it over land I have no idea who you talk too....but besides
Groom lake i dont have a clue where youd fly such a thing over land....
here is one site I happen to have:
http://www.se-technology.com/wig/index.php
take care
Blll
Old April 2nd 04, 10:21 AM
Roger Halstead
On 01 Apr 2004 22:57:17 GMT,
insurance purposes.
It can't fly the FAA doesn't care, however your state and local regs
most likely will. That varies widely from state to state.
In Michigan it could be a nightmare if you operate on land and water
as it'd most likely be considered an all terrain vehicle (ATV)
requiring state stickers if used off your own land AND it would
probably require registering as a water craft if operated on water
AND then there would be operating in and along the edges of the Great
Lakes which requires additional schooling/training for the
operator(s).
www.rogerhalstead.com
Thanks,
Harry Frey
Old April 2nd 04, 04:11 PM
BllFs6
Hi,
found a few old WIG links last night....
these have pics of WIG hovercraft flying....
http://popularmechanics.com/outdoors...ts/print.phtml
http://www.hovercraft.com/
I used to have one pic showing a WIG hovercraft about 10 feet above the ground
doing a "hop"....bet it felt like a hundred feet to the operator though!
WIG hovercraft appear to have many problems....airborne stability for
one....another, dealing with mirror contacts with ground or water (waves)
without it turning into something resembling that bad landing they used to show
at the begining of the 6 million dollar man episodes....
Another problem is variation of weight.....you need to make sure you CANT get
truelly "aircraft" airborne at minimum load, yet you still want to be a decent
height above the surface at maximum load....so it may make more sense to NOT
make the thing as light as possible as you would an aircraft....so that the
percentage difference between min load and max load is significantly smaller
than that of a true typical aircraft....
which aint neccessarily bad...becuase if I built one of those suckers I'd put
in a heavy duty roll cage that protected me, my neck, and ensured that I
floated upright and intact when (not if) I wrecked the thing and it ripped
apart in spectacular fashion!
Sure, that way the drag is more than if you made it as light as possible, BUT I
bet you would still be going alot faster with much less energy than you would
in an equivalent boat! And the ride would be smoother...at least until you
crashed....
The CD reduction is .8 at height = .25 wing size, .6 at .15, and .5 at .10 the
wing size...where IIRC size = chord...though it could be span....and at height
above ground effect CD = 1.0
So you can see you need to get pretty close to the ground for the WIG effect to
help much...
I'll email you the graph I have
take care
Blll
Old April 2nd 04, 07:52 PM
Wright1902Glider
Let me make a clarification to my original post:
The machine that I'm considering is NOT GOING TO OPERATE FROM/OVER WATER. It
is not a flying-boat / hydroplane / Skycar / UFO thingie. It was designed as a
land-based aircraft and looks something like an untralight. It had wheeled
landing gear, wings, control surfaces, engine & prop, etc. However, it never
flew very well or very far... if it ever flew at all. There is no photographic
proof that it ever could or did leave the ground. Eyewitness reports lead me
to believe that it never flew out of ground effect, and never flew more than a
few hundred yards before being retired.
Now here's the rub: all of the flying Wright 1903 Flyer replacas that I know
of are considered (and are) true aircraft, thus requiring a PPL, N-numbers,
etc. They rely on sound aerodyamic principles and would be capable of flying
for miles at altitudes in excess of 10' AGL, given a very good pilot.
The machine that I'm researching does not benefit from any sort of aerodynamic
wing design. Its ribs are flat. If it flew, it was because large ammounts of
power were used to shove it into the air for a few hundred feet.
SO, is there a difference in the eyes of the FAA? And if so, what part of FAR
would govern such a machine? I realize this is a very unusual question, thanks
for your help.
Harry
Old April 2nd 04, 09:57 PM
BllFs6
FAR
thanks
for your help.
Harry
If it doesnt fly why should the FAA give a hoot?
The FAA doesnt regulate hovercraft or airboats and those use airprops for
forward propulsion...
Of course I dont know diddly about FAA regs either...
I hope you have some smoothhhh, softffff ground and that you are going pretty
darn slow when you do your flight tests at 3 ft AGL....
take care
Blll
Old April 5th 04, 10:52 PM
Wright1902Glider
Bill,
I was hoping that the FAA already had a rule or subsection on the books
governing WIG's. That way I could redesign the aircraft I'm considering so
that it would meet the rule. Unfortunately, it looks like the FAA has never
addressed this subject. However, they were adament about regulating ALL of the
reproduction Wright Flyers built last year. Even though the flight envelope of
those craft are very similar to the one I'm considering.
Since I do not currently have a PPL, clasifing the aircraft experimental is not
really an option. It might still be possible to go Part 103, but that won't be
easy. Right now my calculations put the plane at least 100 lbs. overweight.
This is the case for most turn-of-the-century aircraft. They are too slow and
primative to fly like modern airplanes, yet too heavy to be considered
ultralights. So far, I've managed to avoid the FAA problem by building kites
and gliders. But having to wing-walk / push my glider 7 miles around an
airfield last year convinced me that I want power on the next plane I build.
If anybody does happen to find an FAA subsection that specifically mentions
WIG's, please let me know.
Thanks for your input,
Harry
Old April 6th 04, 12:09 AM
BllFs6
Harry...
You might want to contact the FAA directly to get their scoop on it..and
contacting the Coast Guard as well....yes I know you are NOT going to use it
over water....BUT since there is air above BOTH land and water the Coast Guard
MIGHT happen to know when the FAA considers it it a plane rather than a
boat....or at least when the Coast Guard considers it a boat or WIG vehicle
rather than a plane.....
Again my limited understanding is it aint a plane if it cant get out of ground
effect....you just better be darn sure it CANT to keep you outa of trouble.....
also, might help to go ask these questions over at one of the hovercraft forum
since some of those folks appear to be interested in WIGs....there might even
be some wig forum somewhere that I dont know about...
keep us informed..at least I know I am interested....
take care
Blll
Old April 6th 04, 05:34 PM
Ron Natalie
"Big John" wrote in message ...
Frey
Let me ask a stupid question. First I have read the thread to date.
If your vehicle won't be able to fly out of ground effect (and you
don't plan on flying over water) where will you fly it??? I don't
think ground effect goes up and over obstructions (houses, trees,
water towers. electrical power lines, etc).
We've got these large skinny areas of flat surface connecting major
metropolitan areas.
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
