Adjustment of Altimeter
Old April 4th 04, 02:13 PM
Ron
Default Adjustment of Altimeter
Seems as if I remember when calibrating the altimeter there is a small
screw next to the adjustment knob that covered a mechanism allowing
one to adjust the hands relative to the barometric pressure. Does
anyone know where I can find instructions on this. I have searched the
Internet but am yet to find anything.
Thanks.....Ron
Old April 4th 04, 02:52 PM
Barnyard BOb -
Thanks.....Ron
You could go to the RV List archives...
http://www.matronics.com/search/
and find this...
RV-List message posted by: "John D. Heath"
Set the altemeter to field elevation
Turn the screw out far enough to clear the face of the insturment
Slide it away from the knob, Wiggle as required, turn it in to hold it
in place
Pull the Knob out to the stop
Turn the Knob to adjust only the Kolsmans window to the altemeter
setting
Slide the screw back to it's original position and secure it
Now You Know
Barnyard BOb --
Old April 4th 04, 04:33 PM
rip
Have someone who's done this before show you how. If you back the screw
out too far, the lock plate will fall off inside the altimeter. It's an
easy adjustment to make, if you've seen it done once!
Thanks.....Ron
Old April 4th 04, 11:18 PM
Blueskies
I backed the screw all the way out and didn't notice a lock plate fall off. Once I figured this out, it adjusted easily.
All went back together just fine. Should I worry about a loose lock plate now?
Dan D.
"rip" wrote in message om...
Thanks.....Ron
Old April 5th 04, 12:10 AM
rip
No, you'll know it when it happens.
Rip
Old April 5th 04, 04:12 AM
Blueskies
Thanks!
Good, nice to be able to 'dial in' without any concern about certs...
Dan D.
"rip" wrote in message news
Rip
easily.
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 04:40 PM
