"just an average Farlang..." wrote in message news:bm9yaWtv.2c49808e3f2f35f5431910160ea416b5@107 6505681.nulluser.com... | Can anyone tell me what criteria, rules, regulations a person needs to | be | allowed to construct a private runway on his or her property. It really depends on your local zoning. Federal laws allow a person to build a runway just about anywhere, so it is up to local government officials to regulate where and how he can build a runway. You should talk to your neighbor about your concerns. Be frank -- don't beat around the bush. Also call your local zoning board and find out when the hearing is and put yourself on the agenda so that you can speak and tell them your concerns. I doubt if your neighbor is running a crop dusting business or even developing an airpark. Also, he is likely to be well over 1000 feet up by the time he passes over your house on takeoff, which is when the airplane is most noisy. It could be worse, I suppose. You could be living back in town with a neighbor who runs his noisy leaf blower all day. I don't think there are any places left where you will find pristine peace and quiet. |
just an average Farlang... wrote: Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. You do not own the airspace above your house. As long as it is legal for him to have a runway on his property you are out of luck. |
Thai
1. Will this be a private airfield and listed on the charts? If so, probably will have to meet some FAA rules. Have you checked with FAA? 2. If he is just landing on his own property you may have problems? Again, ask FAA. 3. Have you set down with your neighbor and in a friendly tone tried to talk out the problem? If you haven't, do that first, as there may be a mutual solution to your problem that allows him to fly and not a big bother to you ? Point out the flight path over your house and see if he can cock his strip 'catty corner' across his (2600') land. This will take pattern away from your house and also give him a longer runway. Best of both worlds. What activity and type of A/C is planned? You may not even have a problem. Can he give you a call on phone prior to taking off so you can expect the noise? etc., etc., etc. If you follow the don't get mad, get even train of activist: 4. Lay out a landing strip on your land pointing at his house. Use a few times so he gets the idea. 5. Build a two story barn on your property at the end of his strip. 6. Put a skeet range on your property at the end of his strip )7. Put up a windmill at the end of his strip to pump water for your cattle to use. 8. Take up kite flying )On prevailing wind. I sited a strip a number of years ago and went to Wx bureau and got the number of days the wind blew from 360 degrees around the clock for several years. I used the direction where the wind blew the strongest and runway was built. Now we find that 'every' day we have a cross wind as the strong winds only blow a few days in the year and we just land with the these cross winds. Get winds from Wx bureau and evaluate as possible ammo in your discussion. i.e., if strong winds are only in winter when you have 6 feet of snow, they are not a problem for private strip which will never get plowed ) Ifthis is to be a fair Wx summer strip, check winds for those months. From my Owners Manuals I used while active as a CFI: All figures with zero wind. Cessna 150 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 910' Ground run = 1115' Clear 50' obs = 1660' Clear 50' obs = 1985' Cessna 172 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 1040' Ground run = 1255' Clear 50' obs = 1910' Clear 50' obs = 2480' Cessna 182 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run - 845' Ground run = 1015' Clear 50' obs = 1625' Clear 50' obs = 1990' Cessna 210 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 1325' Ground run = 1600' Clear 50' obs = 2305' Clear 50' obs = 2855' All of these figures are for a hard surface runway so have to be adjusted (increased) for dirt R/W. Hope some of this errata helps with your problem. Keep the thread informed how you come out. Big John Sometimes you can't win for trying (On Wed, 11 Feb 2004 08:21:21 -0500 (EST), "" just an average " Farlang..." wrote: Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. ----clip---- |
You do not own the airspace above your house. As long as it is legal for him to have a runway on his property you are out of luck. In Benton County Oregon, the neighbors have considerable say in a situation like this if the proposed use is on a list of conditional uses allowed on the particular zoning of the land. Getting a conditional use permit requires the county to notify and collect data from all the neighbors, then develop a plan to mitigate concerns, or deny the application if they don't see a way to keep the peace. I think the operative word is to find out if the airstrip is a totally allowed use or if some conditions or permit process is required in your county. good luck, tom |
just an average Farlang... ) wrote:
My message topic was never intended to start up any flame war. I asked a simple dam question of what can or can't be done just as the subject of the thread suggests. Why can't people like you stop making things out of it that were never put to it! This is Usenet and it is best if you try not to take things too personally. From where I sit reading this thread you are getting some pretty excellent help from all involved. The only one descending this thread into a flame war appears to be you. FWIW... -- Peter R. ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
message news:bm9yaWtv.9cc04ee02a8bf61515c8a3baf728e8b9@107 6513463.nulluser.com... I wouldn't say that. In fact the collective IQ of the message thread increased exponentially after the first two posts. You jumped to your conclusion about this newsgroup after two posts, one of which wasn't even offensive (Don's)? You can't really expect this newsgroup (which is for pilots, people probably more like your neighbor than like you) to be 100% sympathetic to a person who is apparently looking to raise a ruckus over an activity we all enjoy. Frankly, if you're handling the neighbor situation the same way you're dealing with us, I think you're going to find that this sort of knee-jerk, quick-to-judge attitude won't serve you well. Let's see if you can get all the way through this post without accusing me of being a redneck too... Maybe some are blind-sided by their interests... let me use a couple exmamples: "Blind-sided" isn't the phrase you want to use there. As for your examples... I previously lived on 5 acres and the police department told me I could legally target shoot on my property with a gun but does that mean it is ok? Define "ok". Absent any other restrictions (property covenants and restrictions found on the deed, for example), since it's not against the law, you had every right to use a firearm on your property. [...] Really, using common sense and good judgement I concluded it is not appropriate to do this. It probably wasn't, from a safety standpoint, unless you improved your property to create an area where you could safely fire a weapon and be assured the ammunition would remain on your property. Five acres doesn't give a bullet very much room. But then, a bullet is deadly, and isn't the same kind of thing as an airplane. Yet, this really isn't relevant to the question you asked. I have a racing motorcycle, just because it will go 165 miles per hour does that mean I am allowed to do it? Sure, on your own property or other private property. You could even drive it at 165 miles per hour on public property where such things are allowed. But there aren't any public roads in the US where you are permitted to drive that fast. Yet again, this really isn't relevant to the question you asked. I got a dirt bike, does that mean I can go ride it anywhere I please on private, public or forest land? Again, the various lands you might operate your dirt bike on will have their own use restrictions. Where dirt bikes are allowed, you may ride the dirt bike. Where they aren't, you may not. Simple, no? Yet again, this really isn't relevant to the question you asked. If you're going to raise a fuss over your neighbor's "airport" (which appears to not even be a sure thing at this point), you need to learn enough about the legalities and issues to come up with valid comparisons. None of the other examples you've given have any relevance at all, except VERY vaguely from a "being neighborly" point of view. Frankly, you're not being any more neighborly than the neighbor you're describing, and possibly less so (hard to say, since all we know about his actions, we learn from you). The theme of my message thread I believe is about acting responsible. If you say so. Just as a pilot and landowner should have the right to fly his airplane shouldn't I have the right to sleep late on a hot summer day with my bedroom window open without being woke up by some airplane buzzing over my property and house? You may or may not have that right. But you probably don't. I know I don't in my house. I paid for my land! I am entitled to the use of the land I paid for. Unless the aircraft is taxiing on the ground, on your property, then the operation of aircraft in the vicinity of your property has nothing to do with the land you paid for. You bought the land, not exclusive rights to the airspace over it. I live in a residential neighborhood, near a medium-sized city. At various times of the day, including late at night and in the wee hours of the morning, there are the occasional aircraft that fly overhead. Usually it's jets flying into the nearby (15 miles away or so) commercial airport. Other times, it's a low-flying helicopter (as if there are any other kind ) orless frequently a small plane (they are more often found during normal daytime hours). All of those aircraft have the legal right to overfly my house, and if that disturbs my sleep or other activity (as it sometimes does), I have no legal recourse. How about if I were your nextdoor neighbor... Is it appropriate for me to park my truck in front of your house? Are you parking your truck on my property? You don't have that right. Are you parking your truck on public property, or on your own property adjacent to mine? Then you do have that right, though local laws may restrict how long you can leave your truck on public property, how it should be parked, that sort of thing. And yet again, that example has nothing to do with your original question. How about if I owned 5 cars and had them parked all up and down the street in front of your house? How about it? If the street is public property, and you have not abandoned them (by whatever legal definition exists in your neighborhood...it varies from neighborhood to neighborhood, and in my neighborhood a vehicle needs to be moved daily to avoid it being legally abandonded), you have every right to park your five cars on the street in front of my house. Oops...but yet again, this has nothing to do with the original question. Speaking of which, I might as well use this post to comment on your original post, rather than making a separate reply... First of all, how did you come to the conclusion that "the prevailing winds position the optimal take-off direction to be directly over" your house? Runways do NOT need to be aligned directly into the prevailing winds, nor do I believe that you have done a serious survey of the prevailing winds well enough to determine what the optimal direction for a runway would be. Finally, the direction the runway is pointed is only half the equation; you also need to know *where* the runway is located. Offset the runway by fifty feet or so in one direction or the other, and the departure path no longer winds up over your house (assuming it was over your house in the first place). Secondly, how is that you have 500 acres, and yet your house is only 1500' from the supposed runway? For someone who wanted peace and quiet, you sure built your house pretty close to the property line. Not that this really matters...the choice of where to build your house was yours, not your neighbors. You can only ensure "peace and quiet" in as much as you obtain enough land to buffer yourself from potential disruptions. For what it's worth, 1500' from the property line is too close to ensure peace and quiet insulated from any number of disruptive activities, any of which are likely legal on your neighbor's property. Most of the examples one might think of are noise-related (firearms, dirt bikes, go-karts, loud automobile engines, etc.) but others might involve things like smoke or other vapors drifting over from the property. As far as what kind of airplanes your neighbor might operate, if he's only got 2600' across his property to work with, there's no way he's going to have any large airplane there. Probably bigger than an ultralight, since you hardly need a runway for those. But he's not going to be able to make full use of the 2600'...probably closer to 2000', and assuming he doesn't pave it, that restricts the size of the aircraft even more. Especially given the altitude of 3000' (the maximum temperature is less of an indicator, since he might just not fly on those hot days). As far as the "socialite parties" go, sure, he might have a few friends over. I'd be surprised if more than a handful of airplanes show up at one time though. But even if they did, that's just how it goes. Our house is less than 50' from our neighbor's pool, where they have parties in the summer all the time. Lots of loud goings-on. But since the parties occur during the daytime, they're not in violation of any noise ordinances, nor do I have any basis for complaint. With respect to your question of whether your neighbor is "helping himself to a sort of easement", rest assured he is not. You have no legal right to restrict the use of the airspace above your property -- it's not yours -- so he's not helping himself to anything. As far as farm animals go (which you don't even have yet), there may be some period of adjustment, but they will quickly learn that the aircraft is not a threat, and the noise won't bother them at all. They don't have the human capacity for hate or empathy, so they won't be sitting on the ground fuming about how their neighbor is ruining their lives. Bottom line: it is likely that your pilot is well within his legal rights with respect to his planned airport. You can either be the ugly neighbor, raise a big stink about it, make a bunch of lawyers rich fighting over something in court when you'll likely lose anyway (unless you can outspend the other guy), and so forth. Or, you can have a NICE conversation with your neighbor, recognize that he's within his legal rights and work with him to try to ensure that you both come out with a solution you're each happy with. Your choice. Pete |
I didn't make myself clear.
The purpose of hiring a lawyer is not necessarily to represent you at some particular hearing. As the zoning commissioner noted, sometimes having a lawyer representing you means you are simply screwing yourself. The main purpose of hiring an attorney is to have him/her advise you as to all of the avenues that may be open to you regarding this matter. Sure, the zoning board may allow your neighbor to lay down a strip of asphalt, but if there's a migratory bird range (or something) at the end of the strip, your neighbor won't be flying any airplanes off of it. So an attorney can advise you of all of the ways you can stop this thing, whether you want to use them or not. And he would be able to help you prepare the documents you would need to preserve your rights. As I said, I don't like lawyers, but this is a time when you really need to hire one. The $200 or so you would pay for a consultation would be money well spent... "just an average Farlang..." wrote in message news:bm9yaWtv.36a3367ae106408230a699a6630b24d0@107 6516792.nulluser.com... Bill Denton wrote: One of the most important things to do is immediately contact a lawyer (and I hate lawyers). I don't believe this myself but I asked the zoning commissioner if I would be allowed to have a lawyer represent me at the hearing and he laughed and said if I did that he thought I would surely be voted against. I don't know if it was a lawyer joke or the attitude of the local people about having a lawyer address them. (Thank you for your reply) I don't remember the exact legal terms, but here's a layman's explanation... In some instances, if someone creates a nuisance, and you do not contest that nuisance immediately, you will never be able to contest that nuisance. So, while having a light plane fly over your house a couple of times a week might not bother you, the guy could theoretically suddenly decide to start running 20 747's a day out of his strip and you would not be able to do anything about it. But if you act immediately, you can draft an agreement that would let your neighbor operate a certain number of flights per day/week/whatever during certain hours, and that's it. In this way you would be allowing your neighbor reasonable use of his property while protecting your own property rights, and hopefully preserving your relationship with your neighbor. But you want to act on this immediately, as the game changes once the first airplane takes off or lands. You might also want to check the FAR's, the FAA's website, and the DOT's website; I believe you'll find some information there. "just an average Farlang..." wrote in message news:bm9yaWtv.2c49808e3f2f35f5431910160ea416b5@107 6505681.nulluser.com. . Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. My neighbor owns land that is 2600 feet wide. The elevation is about 3000 feet and the hottest temperature is 91 degrees in the summer. The land is located in Idaho. The prevailing winds position the optimal take off direction to be directly over my house about 1500 feet from the property line. I LOVE airplanes! I worked for Boeing (Lazy B) for the last fifteen years. I worked at Cessna in Witchita before that. I stop to watch planes take off and land. I LOVE PLANES!!! But what I don't love is buying 500 acres to finally get some peace and quiet and then having some loud plane buzz my house at will. The person wanting to put in the runway has money to build a 3 floor nice house so I expect they will want to be socialites and invite all their friends to fly in for a barbacue on the weekend. I talked to planning and zoning and they don't even know what prospective planes will be flown there i.e. ultralites or larger planes that require longer runways. I would like to think it is being fair for me to expect no planes flying over my land below 500 feet whether taking off, landing or pattern flying. I bought my land and paid for the use of each and every acre. If by putting in a runway on the edge of my property that means they are helping themselves to a sort of "easement" flying a hundred feet or so over my land that doesn't seem at all fair. I may wish to build a barn, corral animals (which might go crazy) penned up with planes buzzing over them. Can I get some ideas on what is realistic? I don't even know what a common length of runway is but a friend of mine told me using generic table calculations that a fully loaded small plane on a hot day could very well need a long take off and after lift off .... how long a distance til that plane gets to minimal required elevation? Yesterday I took a flying lesson with a chief piot and he told me a small plane can lift off after about a thousand feet of runway and then the maximum climb would be about 500 feet per minute. He thought for a plane to stay the necessaary elevation over my property the pilot is required a total of no less than 4000 feet. The runway will be a dirt strip which also requires more distance. any comments would be appreciated |
message news:bm9yaWtv.79091ef375f43760b097c51b2b91c89a@107 6516246.nulluser.com... [...] I have not heard one reply in this thread commenting whether the neighbor is allowed to do such a thing as he would be flying very low over my property and below the minimum federally regulated altitude. You didn't ask that question. The minimum federally regulated altitude during takeoff and landing is 0' AGL. Yes, that's a zero. I realize this is during a take off or landing but the fact remains with this amount of land it is not possible to take off or land without using other people's land for his runway to be possible. "Possible"? That word means something other than what you seem to think it means. He certainly CAN build a runway only on his property and still operate an aircraft from it. No "not possible" about it. If you are asking whether he's permitted to actually construct a portion of his runway on your property, then no...of course he's not allowed to do that. But that's not what your original post appeared to be asking. Pete |
"just an average Farlang" wrote in
message news:bm9yaWtv.79091ef375f43760b097c51b2b91c89a@107 6516246.nulluser.com hmmm.... Key phrase the "public". Look up the phrase "navigable airspace" and see what it is, who owns it and who can use it. It was an example that may apply in part but the land in question is privately owned. Your example may have been arbitrary, but my request wasn't. "Navigable airspace" is federal domain and you have no claim to it - even if it is over your property. As others have stated, if your land is under the approach/departure path of an airport, planes may legally be lower than the 500' minimum that may otherwise apply - and you would have no legal recourse. Very true but what I am trying to address is where his rights on his property end and where my rights on my property begin as it applies to his plane taking off on his land and barely clearing a border fence and his plane then affecting my rights That's just it: The plane would not be affecting your rights. You're claiming some "right" to "peace and quiet" - the only thing that you've specifically claimed would be affected by this possible airport. Perhaps Idaho is different, but I am aware of no jurisdiction that provides you with a legal right to "peace and quiet". I appreicate your thoughts but I hope you realize I do not have "homeowner's associations" in outside areas. I knew that was likely the case, but it doesn't preclude you from organizing one with your neighbors, does it? I have not heard one reply in this thread commenting whether the neighbor is allowed to do such a thing as he would be flying very low over my property and below the minimum federally regulated altitude. I realize this is during a take off or landing but the fact remains with this amount of land it is not possible to take off or land without using other people's land for his runway to be possible. See Peter's response. Simply put: You're wrong. Please do not misunderstand my personal feelings and confuse that with all I am trying to present as a topic of discussion in this newsgroup. I am not asking for anyone's sympathy and I would never expect to get it in this newsgroup. Then what exactly are you hoping to achieve here? -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
In article busWb.278549$xy6.1422325@attbi_s02, Newps
wrote: You do not own the airspace above your house. As long as it is legal for him to have a runway on his property you are out of luck. Not quite true. Nothing to stop him from erecting a 500 foot tower on his property in line with the runway. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 01:50 AM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 01:40 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
