Crosswind components
Old February 24th 04, 04:13 PM
James L. Freeman
Default Crosswind components
Can someone offer a non-mathematical EXPLANATION (as opposed to
DESCRIPTION) of why the speed of headwind and crosswind components of
a wind add up to more than the speed of the wind?
Thanks.
Old February 24th 04, 04:22 PM
Andrew Crane
"James L. Freeman" wrote in message
om...
The same reason the opposite and adjacent sides of a right angle triangle
add up to more than the hypotenuse. I guess that's mathematical, but it is
an explanation...
Regards
Andrew
Old February 24th 04, 04:55 PM
mikem
You shoulda stayed awake during trigonometry...
MikeM
Thanks.
Old February 24th 04, 04:56 PM
Gary Drescher
om...
For the same reason that it's a shortcut if you can walk diagonally from one
corner of a city block to the opposite corner, rather than following the
roads around the block.
--Gary
Thanks.
Old February 24th 04, 06:53 PM
Darrell
It's because they are separate definitions of the crosswind and are not
additive.
B-58 Hustler History: http://members.cox.net/dschmidt1/
om...
Thanks.
Old February 24th 04, 10:13 PM
Andrew Sarangan
Because wind has speed and direction. You cannot just add the numbers
to get the total. You have to do a vector sum (considering direction
and speed).
(James L. Freeman) wrote in message . com...
Thanks.
Old February 25th 04, 10:59 AM
arcwi
That's simple - it's a vector sum. But can someone explane this to me:
Scenario One
An aicraft is flying from A to B, TAS=200 Kts, Distance AtoB=100nm, Wind
blowing from B to A with a speed=100Kts
Everyone should be able to claculate that GS(A-B)=100 Kts and GS(B-A)=300
Kts , therefore round trip time A-B-A=60min+20min=1hr20min
Scenario Two
Same as One, but remove the wind completely. The GS in both cases = 200 Kts,
therefore round trip time A-B-A = 30min+30min = 1hr
Can someone explain the difference?
om...
Thanks.
Old February 25th 04, 11:09 AM
Stefan
You spend more time in headwind than in tailwind.
Stefan
Old February 25th 04, 12:04 PM
arcwi
Yes, but the common logic suggest that you also spend less time in tailwind
that in head wind - and if there is no wind the two should cancell each
other... Or should they...
"Stefan" wrote in message
Stefan
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 03:56 AM
