#31
FYI, here's another site for pre-made LED position lights:
http://www.periheliondesign.com/ledlights.htm He has a Luxeon Star Portable 5.6W white tail-light too. (Might be prohibitively expensive for many, tho'. These Luxeon's aren't cheap!) (Again, for the record, I have no financial interest, blah blah blah.) Greg Reid http://www.DivorceMagazine.com/Vision132 |
#32
![]() Greg Reid wrote: FYI, here's another site for pre-made LED position lights: http://www.periheliondesign.com/ledlights.htm He has a Luxeon Star Portable 5.6W white tail-light too. (Might be prohibitively expensive for many, tho'. These Luxeon's aren't cheap!) (Again, for the record, I have no financial interest, blah blah blah.) Greg Reid http://www.DivorceMagazine.com/Vision132 Actually, a 3w luxeon is less than $20 -- more than enough for any tail light. The other $130 goes to the guy. Get a surplus housing and drop in an LED! (Also no financial interest). Scott Gettings |
#33
![]() "Ernest Christley" wrote in message m... Scott Gettings wrote: Glad you guys found this useful. Our DAR says that they don't make specific demands regarding how something is done, so LEDs are fine as long as they are bright enough and have the necessary visibility pattern. He saw no problem whatsoever using LEDs for these lights. I noted in one of my aviation mags that Whelen has a $700+ vertical stab. LED strobe light! Probably doesn't include the power supply. This is obscene and could easily be done with a set of Luxeon 5-watt white LEDs in a circular pattern. Some 3-rd parties are trying to market various combinations, but unless you need very special hardware, you can just make these yourself at a fraction of the cost. You can actually make them much cheaper without the Luxeon and get the pattern closer to the FAA spec. Buy the LED's from SuperBright LED (sorry, can't remember the website). Their website will show the light patter makes for each of the LED's and how much power they put out. The FAR's specify how much light must shine where. Pick out the LED combinations that will put the right amount of light in the right places. Take a piece of 1/4" plexiglass. Drill holes that will be a tight fit for the LEDs at angles that will point them where they should shine. Push the LEDs into the holes, solder some resistors directly to the leads, and pot the backside of the whole thing. You have a solid chunk of plastic that will blind you at night if you put 12V across it. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Panel Lights Dimmer | MII Driver | Home Built | 3 | April 3rd 04 01:56 AM |
LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 01:53 AM |
What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 09:14 AM |
LEDs with Strobe lights | pekka1510 | Home Built | 11 | August 31st 03 11:36 PM |
LED for position lights | Jerry Springer | Home Built | 2 | August 19th 03 01:43 AM |
