#11
I looked up a couple of the planes...
N-Number Model 90030 140 --- Has rotoway engine 885DE 172G --- Rotax engine. I don't believe a 172 would fly with so little power. Cy Galley Safety Programs Editor Sport Pilot |
Ben Haas wrote:
OK Cy and Roger, Explain these??? A curious mind wants to know.. For every hard-and-fast rule regarding homebuilts you can find at least one exception. If the OP is serious about this, he'd be smart to as his question of his regional FSDO, or more specifically ask the person who will be signing his paperwork. I can pretty much guarantee that if you asked more than one FSDO, maybe even more than one person in a single FSDO, you'd get a variety of answers. Dave 'smart shoppers' Hyde |
But it *is* possible to get production-style airplanes certified as Experimental Amateur-Built. I mentioned a Cessna 150 owner on a previous posting, and realized that there is a Stinson 108-3 in the same situation at my home field. The owners either pulled strings with friends at the FAA or performed such a massive rebuild that the inspector probably agreed it met the 51% rule. I had always heard that it couldn't be done. But a couple of guys I know are rebuilding a Piper Malibu and have gotten the FSDO to agree to their plans to certify it as Experimental - Amateur-built. They claim that there are already three others so certified. The trick (and I am quoting them) is that they have identified from the Piper documents 51+% of the TASKS that must be done to build the aircraft. And (given how bad this one was wrecked) it certainly shouldn't be a problem to find 51%. Some of these items are in the details, of course. For example, they will take a couple of places where they need new skin and make it out of sheet aluminum, rather than simply buy the parts from Piper. And they are going to make substantial differences to the power plant and ancillary components. As I understood it, the key is: 1) Make (rather than simply assemble out of replacement parts) as much as possible. 2) Get the FSDO involved early, and get him/her to agree to the plan. |
Ron Wanttaja wrote in message . ..
According to the FAA's database, there are over 150 "Amateur-Built" Gulfstream 5s. cheapshot Maybe that's the only way to get a BD-5J signed off? /cheapshot |
The FAA Aircraft Registration database lists about four hundred Cessna
aircraft currently registered as Experimental. Of those, only the following 14 Cessnas are registered as Experimental Amateur Built. The FAA databases, in general, are full of errors. 14 Cessnas registered as experimental amateur built is really not a surprise. Don't buy any bridges based on FAA databases. Ed "I used to research those for a living" Wischmeyer |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
