Question about center-line push-pull engine configuration
Old June 7th 04, 05:03 AM
Shin Gou
Default Question about center-line push-pull engine configuration
Hello all,
I am currently brainstorming/daydreaming of a twin design. I would
choose a pair of Rotax 912 or Jabiru 2200 or 3300. Considering the
place configuration of two engines on a twin, I am just wondering what
are the pros and cons of center-line push-pull design. There're far
less such configuration than side-by-side engine configuration among
twins, so I think there must be a reason.
The biggest (if ther's any other) advantage of push-pull design seems
obvious: the center line configuration eliminates the torque effect
when one engine fails.
So what're the cons? Besides the heating issue of the rear engine, I
can only guess it might be the efficiency issue. The front engine
disturbs the air flowing through the rear engine. If it's true, how
big is this disturbance? Say if the side-by-side two engines'
efficiency is 200, what's the possible number for push-pull
configuration, 180,160,150? If the number is no lower than 150, I
think it's tolerate for my use.
Thank you very much in advance.
Shin
Old June 7th 04, 06:09 AM
x
Balance is one issue. The wing wants to be near the engine (look at pushers
vs. pullers - pushers are rear wing, pullers are front wing). So you can't
just stick another engine on the tail of a standard config plane.
Thrustlines are another issue. If you are flying and you lose the front
engine, do you nose up? Nose down? Ditto for the rear.
Google for the Cessna Skymaster to read up on the pros and cons.
Then go to www.scaled.com and look at some of Burt Rutan's designs like the
Rutan Bommerang for some out-of-the-box thinking on twins.
One might ask - why do you want two engines?
- More power? Get a bigger single engine.
- More reliability? Get a more reliable single engine. There are many
alternatives to continental and lycoming one the scene now. People have
been saying this for years, but it's really true now. Since you are
thinking about a new design (experimental) you don't need to wait for FAA
certification to use an engine. I haven't checked the NTSB database (you
certainly could - www.ntsb.gov/ntsb/query.asp), but from googling other
peoples discussions, it seems the accident rates for singles and twins are
the same.
Enjoy the argument that's about to start, or check the archives of this
newsgroup for basically the same argument, only repeated every few months...
"Shin Gou" wrote in message
om...
Hello all,
Shin
Old June 7th 04, 09:16 AM
Richard Lamb
who was that masked man?
Old June 7th 04, 04:02 PM
Shin Gou
Thank you very much for your advice and information, Mr.x. So seems
efficiency not a big issue. good to hear that.
Shin
"x" wrote in message news:2URwc.62186$Ly.20810@attbi_s01...
the same.
Old June 7th 04, 06:57 PM
Jay
This topic has been discussed over the last year a few times. I've
been the main agitator on this topic as of late. Been playing with
some models in X-Plane, read all about it below:
http://inline_twin.tripod.com/concept.html
I think one of the main reasons for left/right twins is that for
structural purposes, you like to put your heaviest componants near the
main wing spar so you don't have to build such a heavy structure to
support the engines. The engine loads are applied directly to the
wing spar instead of showing up as bending loads at the wing root.
The reason I was interested in the twin arrangement was in the pusuit
of composit reliability (fail soft) and cost. An idea analogous to
the cross coupled brake system in your car- Critically important, dirt
cheap, rarely inspected.
The idea was to use 2 small motors to fly 2 people. This is in
contrast to almost every twin was designed to use 2 power plants
powerful enough to lift 2 people, so they were large 4 or more seat
aircraft.
As far as efficiency, its true the rear engine is living in the
turbulance of the front prop. This is one of the reasons the
Mix-Master is so loud. This is part of the reason why in my designs
I've tried to get them as far apart from each other as I can. But
there is also an advantage of living the the accelerated air of the
front prop, and that is the idea that you can accelerate the air in 2
stages, instead of all through a single prop disk. Similar to reason
you use a 2 stage turbo for high altitude boost. The larger the
difference between the velocity of the air infront of and behind the
prop disk, the lower the efficiency of that prop. You might end up
with a design that puts a large prop in front and smaller one in back
(which is nice for ground clearance as well).
Regards
the same.
om...
Hello all,
Shin
V-8 powered Seabee Corky Scott Home Built 212 October 3rd 04 12:45 AM
Diesel engine Bryan Home Built 41 May 1st 04 08:23 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 10:27 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
