Switching radios on 1 antenna
Old June 13th 04, 05:02 PM
Jim Weir
Brian Whatcott
-If we are going to brain-storm it, let's dump the relays in favor of
-SSRs (that can be had in sizes less than a finger nail in real
-estate.)
Finding a SSR that will handle 10 watts is difficult. Finding a SSR that will
be relatively loss-free at 137 MHz. is more difficult. Finding a SSR that will
do both is difficult in the extreme.
-Let's by all means add fifty cents of security with back to back
-diodes to limit receiver input excursions to 0.6 volts or less.
At that sort of forward current, the excursions will be more like a volt. And,
those diodes have a burnout mechanism also.
-Come to think of it, how hard could a functional isolator be?
-They've been around for sixty years. But wait: its the bandwidth that
-makes those tuned things less practical - great isolation midband, but
-skanky at the band-edges.
You are kidding, no? A ferromagnetic isolator at 127 MHz. would be about the
size of a computer printer and weigh something on the order of a small child.
http://www.rst-engr.com
Old June 13th 04, 06:26 PM
Rob Cherney
On Sun, 13 Jun 2004 08:58:42 -0700, Jim Weir wrote:
But that's not the common failure mode. The common failure mode is for the
PTT/relay circuit to fail to respond to a "put me in transmit" mode. Thus, the
only isolation you have is from the splitter.
I've already said that you don't key the transmitter until all relay
positions are verified. You can do this at DC and still pass RF.
If you're really worried about this failure mode, put two
-independent relays in series.
Isn't that flawed logic like carrying a bomb with you on an airliner? The odds
of TWO people having a bomb are much smaller.
No. It's more like checking for a bomb twice. See above.
Lastly, I would not select a Wilkinson divider for the receiver. I'd
-use a transformer hybrid.
Your call. I note that under the common failure mode that your transformer
hybrid will have to handle the whole 10 watts. That's going to be one hell of a
transformer. The Wilkinson splitter will handle 50 watts without a whimper.
If the failure mode for the receiver is addressed, the failure mode
for the hybrid is addressed.
R-
Robert Cherney e-mail: rcherney(at)comcast(dot)net
Old June 13th 04, 11:54 PM
rip
You all seem to have lost sight of the fact that just about every
transceiver HAS a T/R switch in it already. If it's good enough
internally, it's good enough externally.
Jim Weir wrote:
Brian Whatcott
-estate.)
Old June 14th 04, 01:10 AM
Rob Cherney
On Sun, 13 Jun 2004 22:54:20 GMT, rip
How do you tell Transceiver-A to isolate it's receiver yet not
transmit when Transceiver-B is transmitting? What connector pin on
the radio does this?
Old June 14th 04, 12:10 PM
IIRC there's a "receive inhibit" on most radios. I had to add that wiring to
my KLX-135 and KY-197 setup so transmitting on one wouldn't open the squelch on the
other (probably 40 dB isolation between the separate antenna... enough for IMD).
-Cory
Rob Cherney wrote:
: On Sun, 13 Jun 2004 22:54:20 GMT, rip
: r*nospam*quinby@snet.*nospam*net wrote:
: You all seem to have lost sight of the fact that just about every
: transceiver HAS a T/R switch in it already. If it's good enough
: internally, it's good enough externally.
: How do you tell Transceiver-A to isolate it's receiver yet not
: transmit when Transceiver-B is transmitting? What connector pin on
: the radio does this?
: Robert Cherney e-mail: rcherney(at)comcast(dot)net
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Antenna informtion needed dave Home Built 14 April 12th 04 05:05 AM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 08:03 AM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
