Glider to ASEL Conversion
Old July 7th 04, 03:20 AM
solo89
Default Glider to ASEL Conversion
I got my ticket to fly gliders about a year ago.
I love soaring, but I'm growing a little tired of the weather demands
of the sport. In the southeast, it's been hard lately to get VFR
conditions. Add to that the requirement of thermals and it's been
mighty hard to fly lately.
Which has me thinking about getting my ASEL.
Does anyone have experience teaching (low time) glider pilots to fly
power? It seems a bit arrogant to think I can get my ticket with the
minimum requirements. But then again, I'm pretty sure I could pass the
written now.
The big drawbacks to ASEL are the cost to rent. It's seems to be about
3 to 6+ times what I'm paying for gliders. And, I can't imagine
getting my ASEL without continuing on to IFR. That really adds to the
cost of training and I assume to the cost of renting as well. Several
years before I ever flew I had regular access to a flying magazine. I
always read the accident reports. If nothing else, I learned that one
sure way to die is "continuing VFR flight into IFR conditions".
Any input will be appreciated.
thanks,
Doug
Old July 7th 04, 05:46 AM
Bartscher
written now.
I did the same thing about 10 years ago when I moved from the Rocky Mountains
(great soaring conditions) to the Midwest (relatively poor conditions). My ASEL
rating took 28 hours if I recall, which wasn't the minimum by any means, but it
also wasn't the 50-60 hours of a typical student without any experience. Also,
I had zero cross-country time in gliders, and I think if you have done glider
XC time, some of it can count.
I chose to get the rating at a towered class-C field since my prior experience
with gliders was entirely at uncontrolled airports (as with most glider
pilots). In retrospect I think this was well worth it, even though it does add
to the cost & training hours (holding on taxiways with the engine running).
The only downside is that my flying seems to continue to get more expensive by
the year. The progression of Schweizer 2-33 to 1-26 to Grob 103 to Piper
Tomahawk to Archer to 172 to 172RG to 182 to Cherokee Six to 206 has taken the
hourly rate up by about a factor of 10. However, it wasn't possible to load 4
adults and luggage into the 2-33 and go 300nm (at least not that I ever figured
out) :-)
I'd recommend finding an instructor and working with them to figure out what it
will take to add on the rating, with the current regs. You may find it is less
than you expected.
Eric
Old July 7th 04, 04:48 PM
Yes, I have been successful in the "cross-pollenation" of glider and
power pilots (both ways). Any experience off the ground helps in the
transition.
Yes, because you are already a pilot in your own right (you have
a ticket), it is easier for you to go on to complete the power.
If you are staying local, a recreational pilot certificate is for
you... keeps you within 50 miles of where you took off.
If you and the friend you fly with don't weigh much, and you are
willing to only fly light weight airplanes, then consider waiting for
the Sport Pilot regulations to get released. (Oshkosh?).
If you are EVER going to get a private or higher airplane pilot
certificate, I believe it is more cost and time efficient to get the
private ASEL next.
power?
thanks,
Doug
Best regards,
Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 203 Young Eagles!
Old July 10th 04, 03:23 AM
solo89
Thanks for the input. After giving it some thought I've decided my
options a
1) Quit flying (not likeley)
2) Buy a Glider (doesn't improve the weather but eliminates the hassle
of renting)
3) Go for the ASEL (I enjoy learning)
4) Sit and stew
I think I'll sit and stew for a while. I can still fly gliders in the
interim. Fall is a busy time for me. Maybe I'll start the ASEL
training in November. Fortunately, Flying is a 12 month a year
activity in SC. Although, some of those months are a lot better that
others.
Doug
(solo89) wrote in message . com...
written now.
thanks,
Doug
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Get your Glider Rating - Texas Burt Compton Aviation Marketplace 0 December 1st 04 05:57 PM
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 04:47 PM
WW II glider pilot reunites with aviators in England Otis Willie Military Aviation 0 October 20th 03 12:08 AM
