Planning a Trip Over The Rockies
Old July 11th 04, 10:58 PM
Snowbird
Cub Driver wrote in message . ..
It's I-90 through Missoula to Helena I think, then I-15N, but that's
a nit.
Thanks for the nit!
What are the high altitudes on this route, and how narrow are the
passes? If I ever bring a Top Cub home, this will be my route.
IIRC the highest pass is less than 6k, and if you can fly at
8 or 9k you'll be above most of the terrain flanking the valleys
so it's comfy for a flatlander.
I'm not the right person to ask about "narrow" because, being a
flatlander, I think it's "narrow" any time I'm flying along
with terrain on either side *g*. People who do mountain flying
tell me there's plenty of room.
At the recent AYA convention there was a chap who had flown a
Tripacer all over South America, including through a 12,000 ft
pass in the Andes. Service ceiling on his plane was 10k, they
circled for an hour and a half in a thermal until they got
the altitude they needed. Amazing story, wish I'd gotten to
hear more of it.
Cheers,
Sydney
Old July 11th 04, 11:32 PM
Newps
"Snowbird" wrote in message
om...
Montana does not have narrow valleys. Idaho is the king of narrow, deep
valleys. Here in Montana the valleys can be 10-15 miles wide at the bottom.
Real mountain flying is when you are below the tops just puttin' along
looking at the scenery.
hear more of it.
Service ceiling is a gross weight number. Get under gross and many things
are possible.
Old July 12th 04, 01:53 AM
vincent p. norris
What are the high altitudes on this route,....
The terrain across southern Wyoming is about 7000 msl, but it is
relatively flat.
and how narrow are the passes?
Miles wide.
Follow the Interstates in the high country and you'll have no problem,
Dan.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
Old July 12th 04, 04:22 AM
Ben Haas
"John T Lowry" wrote in message .net...
"NW_PILOT" wrote in message
Hello, everyone I am wanting to take a flight from "COE" Coeur
D'Alene, ID
to "GTF" Great Falls, MT I was wanting to do this in my Cessna 150 Any
advice or helpful hints from some one thats done the trip over the
Rockies
in a 150 I know I will have to be at really high altitudes just
wondering on
how well the 150 will perform.
I believe your C150 is only marginal for that part of the world. You can
certainly do it, but be sure to take precautions about wind, to NOT be
at max gross weight, to circle for altitude BEFORE coming to a high
ridge, and to lean/enrichen properly on climbs/descents. Good luck.
All the comments are very good advice. I fly into and out of the
"Hole" every day and early morning is the best time to fly for sure.
It takes 11,000 msl just to leave the Jackson area altho in N801BH
with that oversized V-8 Ford it is not a problem. Mountian flying is a
beautiful way to see the scenery and the one comment about winds
aloft is the most pertinant. Now, if you observe lenticular clouds
then tie that sucker down, get an adult beverage, and plan for another
day to fly.
Ben Haas N801BH Jackson Hole WY
Old July 13th 04, 12:01 AM
Learn how to quickly get best power during the takeoff roll, using
your mixture control for any higher altitude takeoffs. Expect the
engine smoothness range to get narrower in response to mixture
adjustments at very high altitudes. Do not run full rich on the
ground, or even on takeoff. Some use a full power runup to adjust for
max RPM before starting the roll but I always hesitated to do that to
an engine just before takeoff.
Is this your personal airplane? You want to know its flight and
engine operating characteristics pretty well to minimize the pucker
factor.
Having an EGT gage really helps. I think it should be mandatory on
any carburated engine but that is just the engineer in me showing I
guess....
I flew a 125 HP Tripacer with two of us in it thru that region amost
35 years ago. No problem
Now we go in comparative regal splendor in a 150 HP 172M!
Old July 13th 04, 12:10 AM
Peter Duniho
om...
your mixture control for any higher altitude takeoffs[...]
There's a good reason for doing it BEFORE starting your takeoff roll, and
frankly, adding "fiddling with the mixture" to the things a pilot has to
deal with DURING the takeoff roll seems unwise to me. Never mind the fact
that once the airplane is moving, you will have a much harder time
identifying the point at which the engine is developing maximum power, since
RPM will be increasing as the airplane accelerates.
I have no idea why you'd hesitate to do something proven to be safe, and
which is much less hazardous than your personal procedure, but I hope that
no one else applies your advice to their flights.
guess....
The EGT gauge is not necessary, nor useful, for the purpose of obtaining
maximum power for takeoff. Your RPM gauge will give you a 100% reliable
indication of maximum power, since maximum power will result in maximum RPM
every time. Using the EGT gauge adds an additional layer of indirection,
and you may or may not wind up with the actual maximum power mixture setting
using it.
Pete
Old July 13th 04, 06:00 AM
To each his own I guess.
I have gotten used to glancing at the EGT on my takeoff rolls just to
make sure things are feeding fuel and air, and also running right. I
look for something about 50 to 100 deg F on the rich side of peak.
EGT also tells me if I have loaded up the things with carb ice while
waiting for takeoff. It is the only cross-check that I have to figure
out if the air/fuel metering system is behaving right, and that the
engine is properly extracting energy from the combustion process.
Personally I feel that any new engine installation (such as in a
homebuilt) should have at least a temporary EGT until the
idiosyncracies (sp?) of the air intake system are proven out. I've
seen/heard of several aircraft that have been excessively lean
(especially in the winter) or rich to the point of stumbling when carb
heat is added. The technique of getting a badly iced engine back
requires aggressive leaning, but I don't see that taught anywhere.
How do you lean a constant speed prop aircraft without EGT? I agree
that leaning a fixed pitch prop on the run without an EGT is not good
practice unless you know the engine.
Maybe I am more into this because I am using autofuel.
Old July 13th 04, 07:21 AM
Peter Duniho
om...
Monitoring engine gauges is fine. Trying to adjust mixture while rolling on
takeoff is not.
I look for something about 50 to 100 deg F on the rich side of peak.
Like I said, the EGT (at any time) does not give you nearly as accurate an
indication of maximum power as RPM does during a static runup. Given that
you're happy with a range of 50 degrees, that's doubly true.
Firstly, you can easily do that cross-check during a static full-power
run-up just before takeoff. Secondly, huh? You could easily have carb ice
and still get a normal EGT reading, albeit at a different mixture setting
than normal.
Funny you should ask. First of all, this thread is about a 150, and you did
mention your TriPacer as well. Both fixed-pitched props.
Secondly, during a static run-up, even a constant speed prop is usually
going to be able to show you maximum power. Keep the prop control to
maximum RPM and for most installations, there won't be enough engine power
to bring the prop to the actual maximum RPM. This is true even at sea
level, but especially true if you're at high density altitude (the situation
we're talking about here), even for higher-powered engines.
I agree
I don't think that adjusting the mixture during the takeoff roll is a good
practice under any circumstance. The takeoff roll is a time during which
you should be trying to minimize workload, not introducing new, optional
items to add to your workload.
On top of everything else, it's my personal practice to keep my hand on the
throttle throughout the takeoff. This is a common technique used by many
pilots and helps ensure that the throttle doesn't accidently vibrate off the
full-power setting, and of course in a twin, makes sure your hands are in
the right place in case of an engine failure below Vmc (in airplanes where
that's an issue). It would be hard to keep one's hand on the throttle at
the same time you're fiddling with the mixture.
I don't see what the type of fuel has to do with it.
Pete
Old July 13th 04, 08:10 PM
Dan Thomas
Around here (Western Canada) most of the neophytes who get into
trouble in the mountains crash because of weather considerations or by
entering an upsloping valley that the airplane can't outclimb and the
pilot waits too long before turning around.
Mountain weather is treacherous and can change very rapidly. Pay
attention to the weather briefers. Mountain clouds usually have rocks
in them.
Mountain valleys can be confusing, especially if there's no
highway to follow, and it's easy to turn into a wrong canyon and get
lost real quick. The route should be marked on the map, with compass
headings penciled in on each leg. For anemic airplanes like the 150,
wind direction over the hills can make the difference between climbing
and sinking, as can lift or sink generated by solar heating or shade
on the slopes.
Dan
Old July 13th 04, 08:34 PM
Snowbird
"Newps" wrote in message ...
hear more of it.
are possible.
Apparently they were at or close to max gross weight (what I assume you mean).
It was all lift.
I believe it -- two people, full fuel, sensible emergency supplies, tools,
some parts, etc for a several months trip sounds like max gross weight
in a Tripacer to me.
Cheers,
Sydney
4800nm trip complete! SeeAndAvoid Piloting 2 June 19th 04 06:58 PM
Coast to coast trip finished :-) Filip Zawadiak Piloting 6 May 5th 04 09:45 PM
Planning a trip S Green Piloting 30 January 14th 04 01:17 AM
Crossing the Rockies in a 172 Peter von Tresckow Piloting 14 December 20th 03 06:27 AM
First long-distance trip Marc Piloting 2 December 16th 03 05:03 AM
