Trim tab location
Old June 23rd 04, 09:30 PM
Jay
Default Trim tab location
I've noticed that a lot of aircraft put trim tabs on the trailing
edges of the normal movable control surfaces. Wouldn't this just
deflect the control surface to neutralize the forces and not affect
much change except drag? It seems like you'd want to put the trim tab
on the fixed part of the wing/stab/vert, that way its pushing the
airplane instead of the flight controls in your hands. I've noticed
some articulated mechanisims on some aircraft (anti-servo) but this
seems to be a complicated way to make up for the fact that the tab was
put in the wrong place to begin with. What am I missing?
Old June 23rd 04, 09:56 PM
plasticguy
"Jay" wrote in message
om...
I believe you are missing the point. The tab was not placed in the wrong
place.
The trim tab drives the surface. When you drive the surface to a new
position,
it creates forces in the same manner as if you had used the controls to
place it there.
Trims are made to unload the controls in the pilots hands, so not placing
them
on the surface would be futile. Scott.
Old June 23rd 04, 11:58 PM
Bob Martin
om...
You're confusing equal moments with equal forces. Putting the trim tab on
the trailing edge of the surface only creates a little force but has a
fairly large moment arm (about the control surface hinge line). The control
surface makes the same moment, but does it on a shorter arm (meaning the
total force is greater). The net effect on the entire airplane is that the
control surface's force vastly overcomes the trim tab's and puts a pitching
moment on the whole airplane.
Old June 24th 04, 10:16 AM
Jan Carlsson
A small tab at the trailing edge is moving the control surface so the
control surface is doing the job (trimming) by a small change in the angle,
if the trim tab is sitting on a fixed part of the plane a bigger tab and or
angle is needed.
Jan
"Jay" skrev i meddelandet
om...
Old June 26th 04, 05:25 AM
sidk
Bob,
Thanks for the great explanation.. I too have been puzzled by the trim
tab effect. I have read many "explanations" and yours is the first
that was articulated sufficently well to sink into my fuzzy brain.
Sid
"Bob Martin" wrote in message ...
om...
Old June 28th 04, 01:39 AM
Ray Toews
I have wondered why some aircraft, use a small moveable control
surface seperate from the normal controls. I believe I have seen this
in the form of a small wing under the horizontal stab being used as
elevator trim.
I once installed a trim tab on the back of the elevator on an
Ultralight Challenger and induced severe flutter, something I did not
want to repeat and obviously it is more than just deflecting the
control.
Ray
On Thu, 24 Jun 2004 10:16:24 +0200, "Jan Carlsson"
angle is needed.
Jan
. com...
Old June 28th 04, 03:15 AM
Bob Martin
Ray Toews wrote in message ...
elevator trim.
control.
Sometimes, a control surface will have "spades" extending either above or
below it. As I understand it, they serve to reduce the control loads on
that surface with high deflections. Usually, you'd see this on a very
high-maneuverability aircraft (like those used for competition aerobatics).
Adding such surfaces takes some knowledge though; you can't just slap one on
without careful study or you might rip the entire surface off.
Also, sometimes you see mass balances (usually like little teardrop shapes)
extending forward of the surface. The best example of this that I can think
of is on the P-38's elevator (though whether it was actually needed is still
up for debate). I don't quite understand what those do as much, though I
think they help with flutter.
Old June 29th 04, 08:12 PM
Big John
Bob
They balance the weight of the control surface equal on each side of
the hinge.
A better wording might be static balance.
Am sure there will be others that add to this question.
Big John
On Sun, 27 Jun 2004 21:15:46 -0400, "Bob Martin"
elevator trim.
control.
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 03:48 AM
trim tab help Robert Loer Home Built 0 March 29th 04 09:30 AM
pitot/static location Ray Toews Home Built 2 December 30th 03 01:52 AM
Canard static port location Paul Lee Home Built 1 July 12th 03 03:55 AM
