How does a stormscope/strikefinder actually work?
Old July 16th 04, 03:38 PM
James M. Knox
Jim Weir wrote in
Howzat?
As usual, pretty durn good.
From my conversations with a couple of the BFG guys that worked the "series
I to series II" transition, the first real trick was to accurately
characterize the lightning RF data. In several parts of the country they
put up triangulation systems (ground based). This allowed them to
accurately pinpoint any strikes in area. They then outfitted a couple of
planes and flew them around the outskirts of any storms that moved through.
The result from the planes was the recorded RF broad-spectrum energy
patterns from strikes at known distances. It was from this that they found
that they could do a good estimate of distance by essentially matching the
basic pattern to one of several basic shapes (this is partly how they
exclude cloud-to-cloud) and then comparing the difference between the
"paradigm" shape and what was actually measured.
The rest was just a lot of high-speed (for the time) DSP.
jmk
Old July 16th 04, 04:50 PM
G.R. Patterson III
Dumb question time. Why exclude cloud-to-cloud? Wouldn't that type of lightning also
indicate conditions one would wish to avoid?
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 16th 04, 05:41 PM
William W. Plummer
Good question. I think the idea that a lightning bolt is an impulse
that excites all frequencies equally at the source. So it shouldn't
matter if it is cloud-cloud or cloud-ground. And, how does a receive
know which is which anyway?
Old July 16th 04, 07:40 PM
Andrew Gideon
Dave Jacobowitz wrote:
I do believe that ground-base strike measuring equipment used for
forecasting and storm tracking can better isolate the position of
lightning strikes -- but in that case, they *do* have the luxury of
spreading out their sensors.
Now *that* would be a terrific use for mode-S: cooperative weather analysis.
- Andrew
Old July 16th 04, 07:53 PM
Andrew Gideon
lightning also indicate conditions one would wish to avoid?
I'm stuck on the question "why would I care?" I mean, if I want to avoid a
t-storm, I don't particularly care whether the discharges are to the ground
or within the atmosphere.
This brings me to my main concern about this type of device, at least as I
understand it. Static discharge occurs after the storm is already worth
avoiding. If I'm in the clouds, this seems terribly likely to permit a
storm to suddenly appear much too close.
Solutions based upon drop size/density (ie. RADAR) would appear to be more
useful in that regard.
So...is it really safe to fly in the clouds with naught but spherics for
weather?
BTW, since my club's aircraft are all carrying strikefinders, I'd appreciate
any references to descriptions of how best to leverage these in IFR flight.
- Andrew
Old July 17th 04, 01:25 AM
Peter Duniho
"Andrew Gideon" wrote in message
online.com...
a
ground
I've yet to see any reference that indicates that the devices actually do
filter out cloud-to-cloud lightning. So far, all we've got to go on is a
Usenet post.
First, I have no idea why you say that "static discharge occurs after the
storm is already worth avoiding". Lightning is a very good indicator of
*active* thunderstorms, exactly the sorts of storms you'd want to avoid.
Secondly, storms can appear quickly true, but it's not like one's going to
engulf you in an instant.
They are sometimes useful, sometimes not. Consider, for example, that it is
entirely possible to have heavy rain, perfectly safe to fly in without a
thunderstorm. Also consider that radar suffers from attenuation (heavy rain
hiding even heavier rain farther away), while lightning detection does not.
weather?
I haven't had a chance to use them myself, so I can't answer that question
first-hand. However, those who ought to know say that lightning is actually
a much better predictor of thunderstorm strength, and of whether what's out
there is a thunderstorm at all (of course) than rainfall is. Lightning
detectors sure seem to be the standard equipment preferred in places like
Florida, and they seem popular elsewhere at all, for those frequently
dealing with thunderstorms (embedded or otherwise).
appreciate any references to descriptions of how best to leverage these in
IFR flight.
Turn it on. Stay away from the strikes. I understand your hesitance to
just cruise right on into developing thunderstorms without knowing ahead of
time how well the Strikefinder works. But I'd have to say you're at least
in a better position than most of us to report on how well they work.
If I had a plane available to rent with a Strikefinder installed and lived
somewhere that isolated thunderstorms happened with any frequency, I would
take that opportunity to go out flying when one or more isolated
thunderstorms are around, and see what the Strikefinder says. You don't
need to get very close at all for the Strikefinder to tell you what it sees.
Compare the information from the Strikefinder against that from the Nexrad
radar information (available for pretty much everywhere in the US to anyone
with an Internet connection), and see for yourself whether you think the
Strikefinder does a reasonable job of highlighting the dangerous storms.
Pete
Old July 17th 04, 02:23 AM
Teacherjh
I think he (or she?) means that the storm becomes worth avoiding =before=
static discharge happens. So, there is a window of development of storms that
the stormscope does not cover. I don't know whether this is true or not, but I
think that is what was being said.
There are certainly "almost thunderstorms" that it's best to fly around.
Jose
(for Email, make the obvious changes in my address)
Old July 17th 04, 07:34 AM
Peter Duniho
"Teacherjh" wrote in message
that
but I
A developing storm won't necessarily show rain either. Falling rain occurs
during the mature and dissipating stages of thunderstorm development, and
while water droplets may be present during the developing stage (being
lifted by the updraft), there may not necessarily be enough to show up on
radar as a significant storm.
I agree that his statement might have meant what you said, rather than what
I thought it meant. But I still don't see how it would imply 'spherics
devices are inferior for detecting thunderstorms. Also, while I'm not
positive, if I recall correctly lightning is present in any thunderstorm
where turbulence and strong updrafts are present, regardless of the stage of
development.
In other words, lightning is a very good indicator of what kinds of
thunderstorms should be avoided.
No doubt...but I haven't seen anything that would suggest a Stormscope or
Strikefinder wouldn't identify those storms.
Pete
Old July 19th 04, 03:28 PM
James M. Knox
"G.R. Patterson III" wrote in
The official answer is "where would you plot it???"
Some of the newer models have a feature that allows you to temporarily
disable the suppression feature. This was in response to pilot requests
(pilots who got tired of seeing a lot of lightning and NOTHING showing up
on the screen).
jmk
Old July 19th 04, 06:38 PM
Peter Duniho
"James M. Knox" wrote in message
2...
What do you mean? You'd plot it where it happens, just as with
cloud-to-ground strikes.
How could that possibly be an "official" answer?
Pete
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 10:45 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 11th 04 12:06 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 01:04 PM
