Cessna 182T w. G-1000 pirep
Old July 20th 04, 05:47 PM
C J Campbell
"Javier Henderson" wrote in message
"C J Campbell" writes:
a) The TBO on the Cirrus engine is 2000 hours.
b) The airframe lifetime on the Cirrus is now 12,000 hours.
Not true, the SR-22 still is 4350 hours until you can show me a type
certificate that says otherwise. If the airframe life limit has been
extended then Cirrus is sure keeping quiet about it.
So, where does that leave your crusade against Cirrus?
Right where I started. I didn't like the plane when I thought the TBO was
2000 hours.
-jav (Skylane owner, trying to offer a balanced view)
A balanced view does not ignore the facts.
Old July 20th 04, 05:50 PM
Tom Sixkiller
"Tom Sixkiller" writes:
http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf
Biased as hell, but some good statistical comparisons.
Some of those comparisons are based on flawed data (airframe life,
engine TBO).
Actually, those are OLD data (as in "revised" since publication), not
"flawed " data.
You really should work for the DNC :~)
Old July 20th 04, 05:51 PM
C J Campbell
engine TBO).
Actually, the data are not flawed. Let's see you come up with something that
proves it wrong.
Old July 20th 04, 06:04 PM
gwengler
Just a few corrections:
Max. cruise is 165 at 20000 ft. and 88% power.
Range WITH 45 miuntes reserve is 635 nm (88% power) to 970 nm (45% power).
Gerd
ATP, T182T
Old July 20th 04, 06:39 PM
Javier Henderson
Nope...CJ was right, it's 1700 hours (TCM IO-550...normally aspirated).
No, CJ is wrong, the IO-550 in the SR22 has a 2000 hour TBO.
http://www.tcmlink.com/producthighlights/ENGTBL.PDF
The IO-550N is on the second page, sixth line from the bottom.
Again, I don't own an SR22 (actually, I own a Skylane) but stating
inaccurate data to make a point is not right.
Are you implying a lie (ala Joe Wilson) or the fact that they have one model
of 550 that has a 2000 hr TBO vs. all their other models with 1700?
Oh, good grief.
I'm saying that the engine in the SR22, which is the IO-550N, has
a TBO of 2000 hours.
-jav
Old July 20th 04, 06:40 PM
Javier Henderson
engine TBO).
"flawed " data.
Whatever. "Inaccurate information for the purposes of comparing current
revisions of the products under consideration".
Happy now?
You know, we as pilots sure do a **** poor job in promoting
evolution. We whine and complain about how it's all old stuff because
the FAA gets in the way of everything, but when a new design comes
along, we sure are ready to bash it to pieces.
-jav
Old July 20th 04, 06:41 PM
Javier Henderson
engine TBO).
proves it wrong.
I did post the link to TCM's datasheet on the engine, stating a
TBO of 2000 hours.
The lifetime of the airframe was recently lifted to 12,000 hours.
Now what?
-jav
  #28
Old July 20th 04, 06:46 PM
Javier Henderson
You are ignoring facts, however.
You may also have the last word, clearly one can't reasonably discuss
this topic with you.
-jav
  #29
Peter
engine TBO).
proves it wrong.
TBO of 2000 hours.
I'd think this would be something Cirrus would be happy to announce. So
I'm surprised their Aircraft/FAQ page still says "The SR22 airframe was
initially certified for 4,350 using data derived from the SR20 test.
Cirrus is nearing completion of the same structural tests used to extend
limits of the SR20 and anticipates that the SR22 will soon be rated for
the 12,000-hour life."
  #30
Old July 20th 04, 06:52 PM
Stefan
C J Campbell wrote:
Even if it was not, you are still faced with a fatal accident rate per
100,000 hours 10 times that of average,
Put the average PPL into a Boeing 737, and I bet the accident rate will
be even higher. So the 737 is an inherently unsafe plane?
Statistics offers the numbers, but they must be interpreted.
Stefan
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 04:40 PM
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 08:06 PM
Cessna 182T w. G-1000 pirep C J Campbell Owning 64 July 22nd 04 08:06 PM
PIREP WANTED: Airmap 1000 [email protected] Piloting 2 June 5th 04 04:51 AM
