#51
"Newps" wrote in message ... wrote: If gelling of Jet-A were a problem, airliners would be falling out of the sky on a regular basis. It is a problem. It is solved by heating the fuel. .... and since hydraulic fluid needs cooling they locate the hyd.cooling coils inside the fuel tank(s). That helps solve two problems. |
#52
Excerpted from other posts.......
Any talk about Jet-A jelling sounds....bogus.. If gelling of Jet-A were a problem, airliners would be falling out of the sky on a regular basis. It is a problem. It is solved by heating the fuel. It is a problem on long flights at high altitudes and high latitudes. The fuel filters on the Boeings that I flew were heated to prevent the screens from "waxing" over. The fuel itself was not heated. The filters were heated with hot engine bleed air and heated for one minute every thirty minutes when the fuel temperature dropped below zero degrees celsius. At PanAm, we had three procedures for dealing with extremely low temperatures across the North Atlantic. 1. Re-route to a more southernly (warmer) route. 2. Reduce altitude to a warmer OAT. 3. Increase speed for a greater friction effect on the tanks. At around M.80, the Ram Air Temperature is about thirty degrees higher than the True Air Temperature. All of these required extra fuel of course and we depended on the Dispatcher providing a good Temp Aloft forecast. Bob Moore ATP B-707 B-727 PanAm (retired) |
#53
Aha,
But much of the cost is due to changing components other than the engine. If you had a glass cockpit, and fuel system that were compatible to start with, then all you would need to change was the engine, mount, prop, sending units, and software. That would seem to be less than what the europeans are giong through to put the Theilert in a skyhawk. wrote in message ... In rec.aviation.owning Mike Rapoport wrote: wrote in message ... In rec.aviation.owning Mike Rapoport wrote: The Caravan has a 940hp engine flat rated to 675hp. Turbines are typically flat rated so that the engine can make rated power to reasonable altitudes and temperatures without having to design the gearbox for the full thermodynamic horsepower. To keep the comparison with piston engines apples to apples you need to use thermodynamic ratings. http://www.pwc.ca/en/3_0/3_0http://w.../3_0_2_1_2.asp OK, that explains that. To put some numbers on things, the engines in my MU-2 have a specific fuel consumption of .55lb/hp/hr and a piston engine is about .45 and diesels can be under .40. Huge (ship) diesels can be under .30. Compare your model aircraft engines with the TFE731-60 used on the Falcon 900EX which uses .405lb/lb thrust/hr Aha, numbers! So if one assumes the motivation to switch from a piston to a turbine is the price of gas is roughly twice Jet-A, the crossover point would be a turbine that did about .8 (to allow for the weight difference in the fuels). Any idea how small (in appropriate terms of hp) current technology can make a turbine with that consumption? -- Jim Pennino That would be the economic crossover point if the engines cost the same. Of course a plane that needed twice the fuel (in lbs) to achieve the same performance wouldn't have much useful load or range. Dropping a diesel in an airplane costs a bunch. The justification is the cost is recovered in lowered fuel costs. Your second point is certainly valid though and a minor problem with the diesels according to the AVweb article on them. -- Jim Pennino Remove -spam-sux to reply. |
#54
If you really wanted to know...
You could likely compare figures derived from different models of armored fighting vehicles. Also, military aircraft used to have a mix a long time ago. "Peter Duniho" wrote in message ... "Roy Smith" wrote in message ... It occurs to me that compared to a piston engine, the turbine is 1) more expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? I believe that there are at least two factors: A turbine needs to be constructed out of more expensive materials, because of higher temperatures involved in the operation of the engine, and it needs to be constructed to higher tolerances, because it's very sensitive to imbalances. These contribute to cost. On the other hand, a turbine has no parts that reverse direction, while a piston engine has many such parts. So the turbine suffers less stress, when constructed correctly, than a piston engine does. It's also "simpler", in the sense that the engine doesn't need as many moving parts to accomplish the same thing. These contribute to reliability. The above ignores higher maintenance costs, which are probably related to several factors, including cost of parts, cost of training for a mechanic, and stricter maintenance guidelines (meaning maintenance happens more often and is more thorough). If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. I think one interesting way to address your question is to look at what causes engine failures. In piston engines, it's usually some secondary component, such as fuel delivery or oil circulation. When it's a primary component, often it's something that's either suffered from poor operation techniques (valves and pistons, for example) or a manufacturing defect (crankshafts). Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). But they have stricter maintenance regimes (which more often will catch problems with secondary components), and perhaps more importantly, they have stricter operating standards and instrumentation to monitor operation (for example, overtemp operation is strictly monitored and limits specified, and if those limits are exceeded, the engine is automatically up for inspection and/or repair). Which is a long way of saying that I think it's entirely possible that if you spent as much on a piston engine as you might spend on a turbine, and followed similar practices with respect to operation and maintenance, you could achieve similar reliability rates. Pete |
#55
"Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message nk.net... I don's see that I've overlooked something relative to the Caravan. The Caravan has a 940hp engine. There is currently no suitable piston engine to power such a large, single engine airplane. It couldn't be anything other than a turbine. As you yourself pointed out, that 940hp engine is derated to 675hp. You don't need a 940hp piston engine to provide the equivalent power, and a 675hp piston engine is not out of the question (for example, the Orenda V8 turbine replacement engines are in that ballpark, if I recall correctly). Large snip. I agree that it is difficult to compare different types of engines apples to apples since the power and specific fuel consumption curves are so different.. I have two airplanes, one turbine and one piston. Both engines are well suited for their applications. In the Helio, power is often set to 15"MP to keep the speed down in turbulent, low altitude mountain flying. A turbine would be horribly inefficient operated like this. In the MU-2, power is set close to the torque or temp limits from takeoff until reaching about 16,000' on the descent. A piston engine operated flat out like this wouldn't last long, particularly at high altitude. Both powerplanes have their place although I think that diesels will eventually replace gasoline piston engines because of their efficiency, long life and simplicity. Mike MU-2 |
#56
#57
... If gasoline hadn't risen to twice the price of Jet-A (at least in parts of Europe) 3 times. At least for avgas. Paul |
#58
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Paul |
#59
... Turbines do suffer from manufacturing defects http://www.tc.faa.gov/its/cmd/visito...30/turbine.pdf |
#60
Howdy!
In article , Roy Smith wrote: In article , ) wrote: Think of it this way - a model airplane engine can be made to run with 1/20 of a cubic inch (.049 cu inch to even .010 cu inch), but piston engine aircraft became impractical above a few thousand HP. That is the range of practicality for a piston concept. It is certainly possible to build much larger piston engines than that. How about http://www.bath.ac.uk/~ccsshb/12cyl/ But it is a *little bit* impractical as an *aircraft* engine... yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
