New theory of flight released Sept 2004
Old October 6th 04, 03:01 AM
Dudley Henriques
"Roger Long" wrote in message
I would imagine you probably view me in the usual Usenet way and
wouldn't lose a moment's sleep if I crashed and burned tomorrow.
Typical Usenet posters, you and me......not friends......not enemies.
Not at all! I've greatly enjoyed the wisdom and experience you bring
to this group and your presence in it is one of my biggest reasons for
check it every day. I'm sure I am not the only one that would feel
the poorer if you decided to drop out. As for crashing and burning, I
don't even want to thing about it.
Thank you for the kind thought, which I'm fairly certain will probably
be negated by someone else before the thread dies out, but thank you
anyway.
Dudley Henriques
International Fighter Pilots Fellowship
Flight Instructor/Aerobatics/Retired
  #32
Old October 6th 04, 03:25 AM
Dean Wilkinson
"Gary G" wrote in message ...
How about the force one one side ****ers the force (gravity) on the other.
Turning an airfoil upside down doesn't violate Bernoulli.
You just change teh angle of attack to componesate.
Gee, if a golfer is someone who golfs, what would a ****er be?
  #33
Old October 6th 04, 04:24 AM
C Kingsbury
"Mark Oliver" wrote in message
THIS HAS A MAJOR PROBLEM - specifically inverted flight. The current
theory
of flight utilizing the Bernoulli's Principal is only applicable to normal
level flight.
That's what Bernoulli's Superintendent is for. He takes care of all the
really tough situations.
Pedantically,
-cwk.
  #34
Old October 6th 04, 04:33 AM
George
Andrew Gideon wrote in message gonline.com...
Roger Long wrote:
The web
site for this theory does just as much of a dis-service to the aliens
(they aren't really aliens because they are actually right next to us and
have been her all along) as the popular lift explanations do to Bernoulli
and Newton.
Wait...are you suggesting that it's the aliens lifting our aircraft? That
would explain so much!
Why do *I* end up with the lazy alien, I'd like to know.
You are going to have to get friendly with the Big Pink Sky Pixies.
They are replacing the old lift fairies who were all very good back in
the last century... :-))
  #35
Old October 6th 04, 05:07 AM
Casey Wilson
"G.R. Patterson III" wrote in message
Be content -- mine likes to play the maracas.
Hmmmph! Mine tries to play the control cables like a violin.
  #36
Old October 6th 04, 06:28 AM
Dean Wilkinson
Mark,
Nice job, your troll post has snagged a lot of responses... very effective post.
  #37
Old October 6th 04, 08:56 AM
Brenor Brophy
While the general aviation community is for the most part unaware of the
vital role played by Lift Demons, the FAA has for a long time taken them
into consideration when formulating Federal Aviation Regulations. In fact,
understanding the needs and wants of Lift Demons greatly helps in
understanding many of the rules that the FAA has introduced over the years
(which otherwise make little sense to the average pilot).
For example as it turns out there are two types of Lift Demons. Bird Demons
and Bat Demons. Bat Demons are blind because they evolved along side bats in
caves, they also have sticky feet which help them to grip onto the more
slippery wings of bats. Now, when man first took to the skies, it was on the
wings of bird demons (Seagull demons to be exact in Kittyhawk). However,
before long some bright sparks decided that unlike birds man would fly his
airplanes inside clouds (not something that birds usually do - I mean have
you ever seen a bird inside a cloud ?). Straight away there was a problem.
Bird Demons need to be able to see where they are going and when they can't
see they get scared and quickly jump off the plane - causing unfortunate
accidents. Should you every fly into a cloud by mistake - quickly start a
180 degree turn to get out of it before the Lift Demons panic. However,
before long a solution was found, Bat Demons, being blind didn't panic
inside a cloud, they didn't need to see in order to keep the lift working.
As a bonus, their sticky feet helped them grip wet slippery wings which is
common when inside a cloud. However, there are not very many Bat Demons (at
least compared to Bird Demons) so you need to make sure some Bat Demons are
waiting for your plane at the runway before you take off if you are planning
on flying into a cloud. The FAA realized this and created the Air Traffic
Control system to facilitate the timely coordination of Bat Demons and
planes. And that is why FAR 91.173 exists
Sec. 91.173
ATC clearance and flight plan required.
No person may operate an aircraft in controlled airspace under IFR unless
that person has--
(a) Filed an IFR flight plan; and
(b) Received an appropriate ATC clearance.
You see, when you file an IFR flight plan the flight service station
computer sends a message to the nearest colony of Bat Demons telling them
where and when they will be needed. Actually, the demons we all know that
live inside computers can communicate directly with their demon brothers -
so the Bat demons don't need their own computers. The Bat Demons don't
always turn up on time, which is why you can't actually take-off until ATC
sees the Bat Demons arrive and issue your IFR release. Sometimes, when the
weather is really bad and lots of planes want to fly in the clouds, there
are not enough Bat Demons to go around and you have to wait a long time on
the ground for some to arrive.
It all starts to make sense when you think about it. Bird Demons don't even
like getting close to clouds. That is why you always have to ask ATC for
Special VFR, this gives them a chance to call up at least a few Bat Demons,
to keep all the other Demons calm as you fly close too the (but not in) the
clouds. Class bravo airspace has so many big jets flying with lots of Bat
Demons that there is always a few extra around which lets you get closer to
the clouds as well.
  #38
Old October 6th 04, 12:00 PM
Cub Driver
On Tue, 05 Oct 2004 16:22:30 GMT, "OtisWinslow"
Bernoulli sucks. The wing lifts because air pushes on one side
and not the other.
That's what I told my flight instructor, but he did not seem
impressed.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
  #39
Old October 6th 04, 05:07 PM
Pat
"Dudley Henriques" wrote in message link.net...
anyway.
Dudley Henriques
Dudley,
I too would be most upset to find that you had crashed and burned...
Unlsess of course, Iwan Bogels got it on video and I could entertain
myself with the fiery spectacle of your demise!
  #40
Old October 6th 04, 05:31 PM
Dudley Henriques
"Pat" wrote in message
om...
link.net...
enemies.
bring
for
burning, I
probably
anyway.
Dudley Henriques
Dudley,
If your post was meant tongue in cheek, be advised I don't know you and
you don't know me well enough to say something like this to me. If you
meant it the other way, go f**k yourself!
Dudley Henriques
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 11:20 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 28th 04 12:49 AM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
