Prop to High RPM on downwind
Old November 22nd 04, 02:21 AM
Stan Prevost
I can't find it right now, but Lycoming had a publication in which they
advised against going to low prop pitch for deceleration of the airplane.
They said it caused detuning of the dynamic counterweights on the crankshaft
("harmonic balancers"?) and was the demonstrated cause of damage to certain
of their engine models. Although my engine was not listed in the affected
models, it seems that the same principle applies, and I have avoided going
to the high RPM setting until power is reduced on final, for engine
protection as well as noise. Supplement your printed checklist with GUMP
checks, including one on short final ALWAYS.
Stan
"Mitty" wrote in message
I've been taught to set the prop to high RPM on final, but I don't like
this very much because then, when I run my checklist for the first time on
downwind, I have to leave one item "open."
So what's wrong with doing it on downwind? (This in a Cherokee 6 or and
Arrow) It seems to work fine, does not disarrange the engine, etc. I
suppose there is some small noise increase, but hardly much.
So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong
TIA
Old November 22nd 04, 02:42 AM
zatatime
On Sun, 21 Nov 2004 23:51:25 GMT, Mitty wrote:
I've been taught to set the prop to high RPM on final, but I don't like this
very much because then, when I run my checklist for the first time on downwind,
So what's wrong with doing it on downwind? (This in a Cherokee 6 or and Arrow)
It seems to work fine, does not disarrange the engine, etc. I suppose there
So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong with
TIA
Full forward (high RPM) is in case of a go around. Going high pitch
mid-field will create a really loud racket on the ground. Waiting
until short final is too late in my opinion since we're human and can
forget things. To avoid this I go full forward (high RPM) when I make
my initial power reduction (generally abeam the numbers). This causes
no noise increase, and time for me to double check as I fly the
pattern.
Hope this helps.
z
Old November 22nd 04, 03:04 AM
Andrew Sarangan
Do you do a final gear check on final? If so, then how much extra work
is it to push the prop to forward on final? This will only become an
issue if you are performing a go-around *and* you forget to push the
prop forward. Even if you forget the prop on final, I don't see how you
can forget it again on a go-around. The go-around procedure calls for
everything forward, and you will catch it if the prop is out.
Going prop forward after the governor has hit the limit is a good
practice. It makes less noise, and it demonstrates that you are smooth
at the controls.
zatatime wrote in
like this very much because then, when I run my checklist for the
first time on downwind, I have to leave one item "open."
and Arrow)
suppose there
TIA
pattern.
Hope this helps.
z
Old November 22nd 04, 03:06 AM
John T Lowry
and Arrow) It seems to work fine, does not disarrange the engine, etc.
I suppose there is some small noise increase, but hardly much.
TIA
There's ALWAYS a problem if one learns to do something mechanical
without understanding the reason for it. Not recommended. Here are some
possibilities, pro and con:
If your engine quits, you want the propeller the prop already at low
rpm, to lower drag. On the other hand if you have to abort the landing
and go around, you want it on high rpm for added low-speed thrust.
Always ask WHY? (You may have to try several instructors until you get a
reasonable answer.) Don't just memorize checklists mindlessly.
John Lowry
Flight Physics
Old November 22nd 04, 03:25 AM
Roger
It depends on the airplane and prop, but it increases noise and drag.
Drag isn't bad if you wish to slow up and it's not at all uncommon to
wish to do so on down wind. OTOH that is not a problem with either
the Arrow or Cherokee family.
If you go full RPM in a Bonanza or Cessna 210 with a 2 blade prop,
the neighbors will not like you. With those there is a big increase
in noise until the MP is back to the point where it's controlling the
RPM.
www.rogerhalstead.com
TIA
Old November 22nd 04, 06:49 AM
zatatime
On 21 Nov 2004 20:04:44 -0600, Andrew Sarangan
Yes
For my philosophy the final check, should be just that - only a check,
no work unless an error has occurred. Subtle I'm sure, but the less
"work" on short final the better IMO.
If in your mind you think you pushed it forward you'll probably
realize it isn't only after the throttle has been pushed full forward.
(I know not an absolute, but more likely than not for an average
person). If it does happen you'll be way "over square" and
potentially do alot of engine damage. Not withstanding the damage
potential, you could get alarmed by the condition, fixate on
rectifying it, and relax the pitch control. In heavier airplanes you
could get enough of a pitch up that it's hard for a person to recover.
I'm not being sexist, but I had this happen to a woman I was flying
with, lets just say it was a good learning experience for her. g
This was in a 172RG so heavy is a relative term.
at the controls.
Now i"m confused. It seems like we agree. I may not have been clear,
or may have missed something, but this is what I meant when I said to
go full forward after throttle reduction.
z
Old November 22nd 04, 09:00 AM
Thomas Borchert
Mitty,
Yes, noise, noise. Just listen to a Bonanza turning on the chain saw on
downwind once, and you'll never again say it's only a "small noise increase".
The effect, while differing from type to type, is huge. If you want airports
to stay open, don't do it on downwind.
Also, in case of a go-around, it is probably anyway a good idea to think in
terms of "all levers go full forward" rather than just "throttle full
forward".
Thomas Borchert (EDDH)
Old November 22nd 04, 11:50 AM
Dylan Smith
very much because then, when I run my checklist for the first time...
Simple - change your checklist. They aren't set in stone.
In any case, forgetting the prop (especially on a plane like an Arrow or
Cherokee 6) is hardly critical - in the case of a go-around it's easy
enough to grab all the controls and push them forward when they are
arranged like this.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old November 22nd 04, 03:43 PM
OtisWinslow
Why even worry about it unless you're going to go around?
TIA
Old November 22nd 04, 03:47 PM
Jay Honeck
with
1. Yes.
2. Rote procedure.
3. Noise.
I had this brought home to me during Mary's biennial. I was working in the
hangar while she was coming into (and going out of) the pattern, and, boy,
could you tell when she pushed the prop control forward on a fast downwind.
That Lycoming O-540 just growled.
Now, personally, I LIKE that sound -- but I understand there are those in
the flight path who don't. Since we have to live with those folks, it's a
good idea not to give them the ammo with which to shoot us down. Noise
abatement is serious stuff when your community is not 100% for having an
airport in the first place.
We now don't push the prop full forward until we're on final, when the
airspeed and MP is already so low that it makes no audible difference.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 04:04 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 08:45 PM
