#21
Mitty wrote: So (1) is everyone taught to do it on final? (2) Why? 1) Yes 2) To have something to break up the monotony of "gear. gear?? gear!! better check the gear... gear? ok, gear down. gear is down. still down. not gonna land gear up." -- Ben Jackson http://www.ben.com/ |
zatatime wrote in message . ..
On 21 Nov 2004 20:04:44 -0600, Andrew Sarangan wrote: Going prop forward after the governor has hit the limit is a good practice. It makes less noise, and it demonstrates that you are smooth at the controls. Now i"m confused. It seems like we agree. I may not have been clear, or may have missed something, but this is what I meant when I said to go full forward after throttle reduction. I was not specifically responding to your comment. It was in response to the original poster who wanted to bring the prop forward on downwind prior to power reduction. Whether the prop is brought forward at downwind, base or final is not important as long as it is done after power reduction. Earlier the better I suppose. On a VFR traffic pattern, I bring the prop forward after power reduction just as I am turning base. On an instrument approach, I would do that after the power reduction at the final approach fix. |
I must be stupid or missing something. Does everybody in this ng come into the
pattern at cruise airspeed? I was taught, and teach, that you come into the pattern about 10 knots above your desired airspeed on final. If you do that, your power is already back for level flight to where the prop is in the stops anyway. With the 182, it is 80 knots turning from the 45 to downwind, 75 on base, and 70 on final. I don't understand why pushing the prop to full flat has any noise effect whatsoever. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"Jim Weir" wrote in message ... I must be stupid or missing something. Does everybody in this ng come into the pattern at cruise airspeed? I was taught, and teach, that you come into the pattern about 10 knots above your desired airspeed on final. If you do that, your power is already back for level flight to where the prop is in the stops anyway. With the 182, it is 80 knots turning from the 45 to downwind, 75 on base, and 70 on final. I don't understand why pushing the prop to full flat has any noise effect whatsoever. Jim Exactly |
On Sun, 21 Nov 2004 23:51:25 GMT, Mitty wrote: I've been taught to set the prop to high RPM on final, but I don't like this very much because then, when I run my checklist for the first time on downwind, I have to leave one item "open." So what's wrong with doing it on downwind? (This in a Cherokee 6 or and Arrow) It seems to work fine, does not disarrange the engine, etc. I suppose there is some small noise increase, but hardly much. So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong with doing it on downwind? TIA Full forward (high RPM) is in case of a go around. Going high pitch mid-field will create a really loud racket on the ground. Waiting until short final is too late in my opinion since we're human and can forget things. To avoid this I go full forward (high RPM) when I make my initial power reduction (generally abeam the numbers). This causes no noise increase, and time for me to double check as I fly the pattern. Hope this helps. z This one seems to work best for Me. Reduce Power, Increase RPM setting. No Noise increase due to reduced power and it is already set when I get to final. Brian |
"Chris" wrote in message
... [...] With the 182, it is 80 knots turning from the 45 to downwind, 75 on base, and 70 on final. I don't understand why pushing the prop to full flat has any noise effect whatsoever. Exactly Exactly, except for those airplanes that cannot maintain level flight at pattern speed with gear and flaps out at final descent power settings. Which is, by the way, all airplanes with a constant speed prop. The power setting for final descent is necessarily lower than that required for level flight within the pattern, even if you slowed ALL the way to your final approach speed. RPM will thus be higher, assuming the pitch is set to full fine pitch (high RPM). Higher RPM means more noise. If Jim's 182 flies along level in the pattern at the same airspeed and prop RPM that he uses for final descent, I have no idea how he accomplishes a final descent at all. A plane like that would be stuck up in the pattern indefinitely. Pete |
"Jim Weir" wrote in message ... I must be stupid or missing something. Does everybody in this ng come into the pattern at cruise airspeed? I was taught, and teach, that you come into the pattern about 10 knots above your desired airspeed on final. Do not high-volume airports prefer "local procedures" that encourage cruise or near-cruise for the small types until just about base turn, just to keep the traffic from backing up??? |
#28
Whew! Glad I didn't ask anything political!
OK, things to clarify: In the Arrow on downwind I've already pulled out a lot of power and flattening the prop really does have minimal noise effect. In the Six, which has a three-blade prop, I have to carry more power of course. Next time I fly it, I am going to listen more carefully while flattening the prop on downwind and see if there is much noise effect. I haven't been aware that there is. That airplane, though, is quieter than anything else in our fleet (Archers, Warriors, the Arrow) because of the prop. So maybe not an issue there either, even with the O-540. I like to run my checklist, really a "flow," on downwind, base and turning final. And I like all three to be the same because the point of doing it multiple times is that if I get distracted by ATC, traffic, or airplane problems, any one of them will have gotten the job done. It's a matter of style, I guess. Things learned/confirmed: The issue is only noise; no engine issues that I heard anyway. I like Bob Gardner's suggestion that going full forward may not be necessary at all unless the tactical situation demands it. One more thing to remember on final, however. I like the several suggestions that the go-around mantra be "everything forward" -- in fact I wish I had been drilled on that one while training for my Private. Thanks, Mitty On 11/21/04 5:51 PM, Mitty wrote the following: I've been taught to set the prop to high RPM on final, but I don't like this very much because then, when I run my checklist for the first time on downwind, I have to leave one item "open." So what's wrong with doing it on downwind? (This in a Cherokee 6 or and Arrow) It seems to work fine, does not disarrange the engine, etc. I suppose there is some small noise increase, but hardly much. So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong with doing it on downwind? TIA |
#29
Mitty wrote: Whew! Glad I didn't ask anything political! OK, things to clarify: In the Arrow on downwind I've already pulled out a lot of power and flattening the prop really does have minimal noise effect. Just monitor your tach when you do this. You should not go over about 2300 RPM, or you are pushing the prop forward at too high an airspeed. In the Six, which has a three-blade prop, I have to carry more power of course. Next time I fly it, I am going to listen more carefully while flattening the prop on downwind and see if there is much noise effect. I haven't been aware that there is. That airplane, though, is quieter than anything else in our fleet (Archers, Warriors, the Arrow) because of the prop. So maybe not an issue there either, even with the O-540. I like to run my checklist, really a "flow," on downwind, base and turning final. And I like all three to be the same because the point of doing it multiple times is that if I get distracted by ATC, traffic, or airplane problems, any one of them will have gotten the job done. It's a matter of style, I guess. Things learned/confirmed: The issue is only noise; no engine issues that I heard anyway. No -- you CAN overspeed the engine if you push the prop full forward at too high airspeed. Monitor the tach! I like Bob Gardner's suggestion that going full forward may not be necessary at all unless the tactical situation demands it. One more thing to remember on final, however. I like the several suggestions that the go-around mantra be "everything forward" -- in fact I wish I had been drilled on that one while training for my Private. Too much drill, not enough reasons for the drill. I do not add full prop until I am at gear speed. On 11/21/04 5:51 PM, Mitty wrote the following: I've been taught to set the prop to high RPM on final, but I don't like this very much because then, when I run my checklist for the first time on downwind, I have to leave one item "open." So what's wrong with doing it on downwind? (This in a Cherokee 6 or and Arrow) It seems to work fine, does not disarrange the engine, etc. I suppose there is some small noise increase, but hardly much. So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong with doing it on downwind? TIA |
#30
Unless you have been assigned a lower altitude by ATC, try setting up
your pattern so you arrive 1500 feet above field elevation when abeam the approach end of the runway. If you are on speed (80kts for the C182), you can reduce power to idle and bring in 30 degrees flaps. This will position you for a constant rate, 180 degree turn to the runway. Slowing to 75 kts, 90 degrees through the turn (base) and 70 kts, wings level, final. Bring in the last 10 degrees of flaps and touch down with the airspeed decaying through 55 kts. Cherokee Six and the Arrow, bring in two notches of flaps (25 degrees), airspeed 90 kts abeam the approach end of the runway, reduce power to idle. Slow to 85kts at the 90 degree point. Roll level at 80 kts on final. Bring in the last notch of flaps (40 degrees), slowing to 70 over the threshhold. If you fly "airline" (ie- wide) patterns, you will have to carry some power to make the runway. Wind dictates how wide and how far to extend the downwind. Get used to flying a steep approach. The more comfortable you are with it, the more fields will be available to you. |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
