Vertex Handhelds
Old November 25th 04, 12:46 PM
Cub Driver
On Wed, 24 Nov 2004 18:11:12 -0800, Jim Weir wrote:
After a hell of a lot of
work and research, I settled on Vertex. THe reasons would take me an hour to
lay out, so I won't.
I would one would appreciate hearing any of them that related to the
units' performance, durability, etc (as opposed to business reasons).
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
the blog www.danford.net
Old November 25th 04, 06:05 PM
Malcolm Teas
"Jeff Franks" wrote in message ...
Just wondering if anyone here had experience (good or bad) with Vertex
handheld transceivers. I'm about to buy SOMETHING, but I'm not sure whether
or not I'm gonna stick with the standard ICOM.
I bought the VXA-700 and I'm quite happy with it. I've used it twice
now in the air when I've had radio problems (I don't fly with that
club anymore). Once to fly back into the Wash. DC ADIZ. I monitor
local traffic for my own amusement when I'm on the ground with it too.
I like it since it's small and relatively lightweight. It uses a LiON
battery so there's a very long battery life. It has a 5W output which
is good. It's hardy and robust so that it can bang around in the
bottom of my flight bag w/o harm. All of this combined means that
it's easy to carry and will have the power to be useful when I need
it.
If it's NOT easy to carry, then I'm more likely to omit it and not
have it when I need it. A bigger and heavier radio, or one that I
need to carry a backup battery for, is one I'm less likely to have
with me.
I bought the headset adapter for the earphone plug. I often just
leave that attached to the radio. I can move my headset from the
panel to the handheld very quickly if needed. It has the VOR feature,
but I've not had occasion to use that. It also gets weather radio (in
the US), FM broadcast, and 2 meter band.
Ideally, I would prefer a standard earphone/headset plug and standard
antenna plug, but it's a minor issue. I'm willing to live with
external adapters for the sake of the smaller size and lower weight
than ICOM or Sporty's.
The thing is waterproof up to 3 feet under, so rain won't hurt it
either. There are rubber corners for more protection from getting
dropped too.
I live under and fly in and around the ADIZ. Loosing a radio here is
a big deal. Potentially fighter jets and license suspension type of
big deal. Having a robust, powerful, long-life backup radio is a key
part of my strategy. I would recommend the VXA-700.
-Malcolm Teas
Old November 25th 04, 07:02 PM
Jim Weir
The nice thing about being on the engineering side of the house (as opposed to
the business side) is that my decisions are based on the quality and technical
superiority of one product over another. Business reasons played very little in
my decision.
I considered the Vertex superior in terms of mechanical design and the resultant
reliability. As was pointed out elsewhere, that chicken$#!t advertising 5 watts
RF output (and then in small letters "PEP") isn't far from deceptive
advertising, but that's the way some other companies are doing it and I guess to
be competitive you have to play the game.
Actually, you can't really go wrong with either Vertex or Icom. What I wish
Vertex would do is come out with a permanent panel mount flatpack like the Icom
and then I'd REALLY be happy.
Cub Driver
-On Wed, 24 Nov 2004 18:11:12 -0800, Jim Weir wrote:
-After a hell of a lot of
-work and research, I settled on Vertex. THe reasons would take me an hour to
-lay out, so I won't.
-I would one would appreciate hearing any of them that related to the
-units' performance, durability, etc (as opposed to business reasons).
http://www.rst-engr.com
Old November 26th 04, 05:12 PM
John Galban
Jim Weir wrote in message . ..
I think it is deceptive. More than once I've heard somebody saying
that they bought X handheld because it had a 5 watt transmitter.
Several of the companies that sell handhelds are using the gimmick.
Transmit power on most handhelds is about 1.5 watts. The funny part
is that this is plenty of power for the task. You can transmit to the
horizon from jet altitudes with 1.5 watts. When I used a handheld as
a primary radio (1.5 watt w/ external antenna), I had no problem
conversing clearly with Approach when I was 30 miles out. All in all,
transmit power is not a big deal for aviation handhelds.
Old November 26th 04, 05:20 PM
Jose
horizon from jet altitudes with 1.5 watts. [...]
...transmit power is not a big deal for aviation handhelds.
One of the uses of a handheld is to get weather, clearances and such on the ground in winter before starting the hobbs meter. I suspect that this is
where the extra power comes in handy.
Jose
Freedom. It seemed like a good idea at the time.
Old November 26th 04, 07:34 PM
Jim Weir
Please stop me, Dear Lord, before I answer him in a tone unbecoming of a
Thanksgiving weekend...
Jose
-One of the uses of a handheld is to get weather, clearances and such on the
-where the extra power comes in handy.
-Jose
Old November 26th 04, 07:53 PM
Jose
- One of the uses of a handheld is to get weather, clearances and such on the
- ground in winter before starting the hobbs meter. I suspect that this is
- where the extra power comes in handy.
Bearing in mind that the sites one might need to reach from the ground might not be located on the same field (in which case a tin can and a string
would work), and there could be hills and such in the way, what is wrong with my thinking?
Jose
Old November 26th 04, 08:06 PM
Jack Allison
Wow, such restraint? An early New Year's resolution perhaps?
Impressive! :-)
Jack Allison
PP-ASEL, soon-2-B-IA Student, airplane partnership student
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old November 27th 04, 12:27 AM
Dave Stadt
"Jose" wrote in message
om...
on the
this is
with my thinking?
Jose
DON'T DO IT JIM! Just send the poor guy a 30 year old ARRL Handbook and
maybe he will see the light. Hmmmmm, now, what chapter was it that talked
about transmitting through hills at VHF frequencies?
What's next for Garmin handhelds? NEW 296 MichaelR Piloting 3 March 19th 04 01:50 PM
What's next for Garmin handhelds? Mike Rapoport Piloting 13 March 6th 04 04:58 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 10:27 PM
Handhelds and alkaline batteries Ross Richardson Piloting 44 August 10th 03 01:17 AM
Vertex Standard 700 opinions?? EGWW Owning 3 July 15th 03 02:43 PM
