What The Heck Is That Noise!?!
Old December 16th 04, 10:10 PM
Happy Dog
"zatatime" wrote in message
I think that there's a certain measure of hyperbole involved. This has
happened plenty of times and the fuel doesn't drain at that rate. But I
don't doubt that it was a sobering experience.
No hyperbole at all. Since it's usenet, of course you're entitled to
your opinion, but what I saw was not part of usenet, nor were any of
the other witnesses. I'm sure each airplane is different due to the
amount of lift generated, and other factors. This airplane lost most
of its fuel once around the patch.
Not each 185. This doesn't come even close to the incidents I'm familiar
with. But I don't mean to downplay the seriousness of this mistake. It can
easily have fatal consequences.
moo
Old December 16th 04, 10:24 PM
G.R. Patterson III
It happened to a friend of mine in a Grumman. The fuel *does* drain at that
rate. He lost five gallons out of one tank and never reached pattern altitude
(did a fast 360 at about 400').
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 17th 04, 12:21 AM
Happy Dog
"G.R. Patterson III" wrote in message
that
altitude
I was speaking only of a 185. I'm not trying to make light of this error.
moo
Old December 17th 04, 12:48 AM
zatatime
On Thu, 16 Dec 2004 16:10:04 -0500, "Happy Dog"
Not each 185.
Correct. I was thinking about 152 vs 172 vs 206, etc. What was in my
head was not transferred to "paper."
Agreed.
z
Old December 17th 04, 12:52 AM
Calm down. Nobody's calling you a liar. It can happen lke you said,
especially, as I said, with bladder tanks, since the bladder collapses
under the lower pressure and squeezes the fuel out. The dumb thing was
not getting the bladders checked before filling up and flying again.
Those bladders are held in place against the top and bottom wing skins
with snaps like you see on some jackets, and they come undone under
no-cap conditions. You're left with a partially-collapsed tank.
Dan
Old December 17th 04, 12:57 AM
Happy Dog
Lower pressure where? "Squeezing" implies higher pressure surrounding the
bladder. Is that what you meant to say? This happens just fine with metal
tanks too.
moo
Old December 17th 04, 03:13 AM
Morgans
"Happy Dog" wrote in message
metal
tanks too.
moo
Low pressure at the cap means low pressure in the bladder. Regular pressure
outside the wing means squeeze is pretty accurate.
Jim in NC
  #29
Old December 19th 04, 06:08 PM
Carl Ellis
The wing root ventilation tubes on a 172 can cause a very strange noise if
they are pulled most of the way out. I aborted a take off one time because
of it. They noise was low frequency and oscillating, following the
throttle and acceleration of the airplane.
- Carl -
  #30
Old December 19th 04, 07:18 PM
Dale
A real hard pushover will cause the vent tubes to "scream".
Dale L. Falk
Small plane noise is destroying my life Robert Morien General Aviation 5 December 1st 04 06:01 PM
Cherokee Strobe Noise Jonathan Goodish Owning 20 November 2nd 04 03:42 AM
Funny noise update Peter Duniho Piloting 1 July 1st 04 03:58 PM
Ear plugs and noise filtering Top Spin Piloting 12 January 16th 04 05:52 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 04:24 AM
