HURRICANE PROOF BUILDINGS
Old August 17th 04, 12:01 AM
Blueskies
"Vaughn" wrote in message
"Juan Jimenez" wrote in message
I have always wondered why people would be stupid enough to build out of
wood after the last hurricane takes the wooden home and enlarges it to a
few acres maybe an inch tall.
Wood is an amazing building material. A properly designed wooden structure
will stand up to a hurricane just as well as a properly designed concrete
structure. For proof, take a trip to Key West and check out some of those old
homes. The biggest advantage of concrete homes in Florida has nothing to do
with hurricanes; termites don't eat concrete.
The concrete homes are cooler also...
Did you know that they even make airplanes out of wood? (aviation content)
Vaughn
Dan D.
http://www.ameritech.net/users/ddevillers/start.html
Old August 17th 04, 04:22 AM
RobertR237
There's a simple solution: build HURRICANE PROOF BUILDINGS
http://www.monolithic.com/gallery/co...ars/index.html
Hurricane resistant, maybe...Hurricane Proof, never.
Unless everything around it is tied down and the wind is from the
right direction, any building is vulnerable to damage from a strong
hurricane. One of the biggest sources of damage in every hurricane is
blowing debris causing the initial damage to a building and the
resulting winds finishing the work.
That must explain why every home in the neighborhood I grew up in is still
standing, -intact-, 60+ years after they were built, and several hurricanes
later, while one hurricane pretty much wiped out entire cities and
neighborhoods in a few hours in Florida. It doesn't take a genius to figure
out that when it comes to protecting people from things like hurricanes,
concrete beats wood 99% of the time.
No, concrete designed to withstand hurricans beats wood that wasn't so
designed. The old wood sailing ships took a lot more beating on a daily
basis than is dished out by a hurricane. And they held up rather well.
It is a matter of what loads the structure is designed for, not the
materials used in the construction.
Matt
Matt,
You are wasting your time trying to reason with Jaun, he is a self proclaimed
expert in all things and nothing will ever change his mind.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old August 17th 04, 04:56 AM
Del Rawlins
On Mon, 16 Aug 2004 16:17:26 GMT, "Ken Finney"
1. If I lived in hurricane country, I'd have at least one Gunnite-type
quonset hut to put my valuables in and hide in.
Yup, quonset huts do good in the wind. Four winters ago the small
rural fishing town in Alaska where I lived was hit by a typhoon and
hurricane force winds were measured in the small boat harbor. Trees
went down all over town (fortunately most of the power lines were
underground), and many people lost roofs. One building in particular
literally exploded and its roof was carried away, out over the inlet,
never to be seen again. Our commercial buildings consisted of a
large, wood framed quonset hut and a timber framed shop and adjoining
warehouse built with 12x12 timbers (my dad didn't know the meaning of
the word overkill). Our total damage consisted of a couple chimney
caps that got blown off. One was rusted out and needed replacement
anyway, and the other, after the stoorm ended I picked it up off the
ground and put it back where it belonged. I felt kind of bad
considering the damage some of our friends suffered but oh well.
Del Rawlins--
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Remove _kills_spammers_ to reply
Old August 17th 04, 04:58 AM
ChuckSlusarczyk
In article , RobertR237 says...
Boy you got that right ,it didn't take jaun long to start ragging on people
over material for a building. I guess a cement BD-5 will fly as good as his
perpetual BD-5 project LOL!!
Flame shorts on !!
See ya
Chuck (the guy that designed wood is a pretty good designer) S
Old August 17th 04, 07:50 AM
On Mon, 16 Aug 2004 22:31:20 -0700, Richard Riley
Apparently most of them survived the huricane fine, unless
they were hit by flying cars and oak trees.
Flying cars and oak trees! So it takes a hurricane to make our wishes come true!
Not at all! Tornadoes do it too.
Yeah, but when a tornado hits Kansas, you don't get a lot of surfers
running around yelling, "Dirt's up!" :-)
Old August 17th 04, 03:10 PM
Ron Natalie
"Blueskies" wrote in message . com...
"Richard Riley" wrote in message ...
On 16 Aug 2004 14:24:02 GMT, osite (RobertR237)
I think I saw Moller down there looking at the oak trees.
Old August 17th 04, 08:20 PM
geo
structure
structure.
I'm not talking about cinder blocks. Reinforced concrete is by FAR the
strongest building material generally available and in the shape of a dome
it's much stronger still. Given the same forces a stick home will be a pile
of splinters while the dome is unscathed. The numbers have been done; it's
not a mystery. http://www.monolithic.com/plan_desig...ive/index.html
do
It has everything to do with hurricanes. And fire. And floods. And rot.
  #28
Old August 17th 04, 08:26 PM
geo
"RobertR237" wrote in message
Which of the numbers do you disagree with?
  #29
Old August 18th 04, 12:27 AM
Matt Whiting
Until they get warmed up and then they stay hotter.
Matt
  #30
Old August 18th 04, 12:28 AM
Vaughn
Subject: HURRICANE PROOF BUILDINGS
Date: Tuesday, August 17, 2004 2:20 PM
structure
structure.
And I am not talking about reinforced concrete dome houses. I am talking
about the real-life code-compliant housing that fills up neighborhoods here in
south Florida. In fact, my post above was not even in response to you, and
certainly not to some weird structure that lives in your imagination or on a on
a web page somewhere.
Last time I checked; here in south Florida, a code-compliant wooden house
will get the same insurance rate for storm coverage as a comparable concrete
home. Proper storm shutters and/or Dade approved window and door systems are a
major item and insurance companies may someday force 100% retrofit in storm
counties. After window protection, the next most important item for storm
resistance is roof design, not the building material of the walls.
Ten years ago, I toured hurricane Andrew's devastation and saw many failed
structures, wood, concrete block, and yes; even reinforced concrete.
Vaughn (a guy who lives in a concrete house)
Hurricane Charlie and Lakeland Orval Fairbairn Home Built 12 August 17th 04 03:42 PM
