#51
("Ron Garret" wrote)
Not quite. They have to reach thermal equilibrium if there is no heat flowing in or out of the system. But, as you correctly note, heat can (and doe) flow in and out via radiation. Surfaces can "soak up" the cold of the night sky (actually, they radiate their heat into the night sky) and become colder than the surrounding air, just as they can "soak up" the heat of the sun and become warmer than the surrounding air. Eventually some of the cold/heat does get transferred to the air. This is why clear nights tend to be colder than cloudy ones (and why clear days tend to be warmer, all else being equal). So on the 41F night in question, and having imaginary temp probes build into the composite wing surface, we might see overnight wing temperature readings of say 29F or 30F? Is there a way to (WAG), in advance, what different surface temps will be on the night in question? (41F overnight and 40F at 8:15 am) Knowing air temp, humidity, cloud cover, wind, etc - could someone predict that the composite wing will be in the 25F - 31F range overnight, whereas the aluminum wing might only get briefly down to say 35F? Aluminum being willing to give up its heat to the air more readily than the composites? Montblack |
#52
"Martin X. Moleski, SJ" wrote: On Fri, 11 Feb 2005 15:12:27 GMT, George Patterson wrote: W P Dixon wrote: That's pretty cool (Pardon the pun ) Where can I read up on that George?I read about it in the 70s and don't remember where; probably a Science Fact article in Analog or Popular Mechanics. As I recall, the technique is to dig a hole large enough to keep your water container completely below ground. Cover it during the day and insulate it (the Romans used straw). Leave it open to the night sky. It will freeze in a few days. The article said it only works in areas where the night sky is usually perfectly clear (ie. the desert). This site gives a reference: http://www.madsci.org/posts/archives/nov99/941723540.Sh.r.html Marty Except that particular reference isn't very clear about the relative roles of heat transfer to the air (and into the surrounding ground) and radiative transfer to the sky -- e.g., it says ". . . at night, the pit would be uncovered so that it could lose heat to the desert air." You might take that to imply that the air temp in those African and Palestinian deserts goes below 32 F at night? (Anyone know?) You guys are into some interesting physics here. Do the plane wings frost even when the surrounding air is above 32 F because their net heat transfer to the surrounding above-freezing air is not as strong as their net radiative heat transfer to the cold sky? (which should also imply equally strong net heat connectivity to the ground below, is that not so?) Or do they acquire and retain frost because some colder and therefore heavier below-freezing air just fell down on them at some earlier time? I'll wait for an authoritative answer, but bet on the latter explanation. |
#53
It is worth noting also that dark surfaces absorb and radiate more readily than light ones, and so they get hotter during the day and colder at night. Cirri are all painted white in order to take advantage of this phenomenon and keep the skin from getting too hot in the sun. (You'll never see a non-white Cirrus. It's part of the certification conditions to paint the white.) Accordingly, Cirri are less prone to radiation-induced cooling and icing than a dark-colored plane would be, all else being equal. I get the sun heating darker surfaces up (many degrees!) more than an identical white surface. What I don't get is: Two wings of identical design and an identical starting temp, both sitting out on a cold February night (no sun). How does the dark wing get colder than the white wing? If it's a microscopic temperature difference because of star twinkle and ambient light pollution from the surrounding city, I can see that. However, a number of degrees between the white wing and the dark wing at night? Nope, I still don't get it. Montblack |
#54
What I don't get is: Two wings of identical design and an identical starting temp, both sitting out on a cold February night (no sun). How does the dark wing get colder than the white wing? Visible light and infrared radiation (heat) are both forms of electromagnetic radiation, they just have different values of frequency/wavelength. Objects that are absorptive or reflective of radiation in the visible spectrum can (but don't necessarily) also exhibit the same or similar properties of absorption or reflection of radiation in the infrared spectrum. I think. ![]() -R |
#55
AES wrote:
You guys are into some interesting physics here. Do the plane wings frost even when the surrounding air is above 32 F because their net heat transfer to the surrounding above-freezing air is not as strong as their net radiative heat transfer to the cold sky? No, it's not necessary for the heat transfer to the night sky to be "stronger", just for it to be a significant effect. According to: http://www.efunda.com/formulae/heat_..._enclosure.cfm the radiative temperature of the clear night sky is about -150 F, so if the wing surface got no heating from its surroundings and reached thermal equilibrium with the night sky then it would cool to -150 F. On the other hand, if it didn't lose any radiational heat to the sky but was in complete equilibrium with the ambient air temperature that dropped to a low of 40F, then that would have been its lowest temperature. In reality, both effects occur. It gets some heating from the surrounding air and also conduction from other parts of the wing and plane, but it also loses some heat through radiation to the cold night sky. The resulting temperature is therefore somewhere between +40 F and -150 F and in practice probably around 25F - 30F on a perfectly clear night and very close to 40F on a cloudy night. (which should also imply equally strong net heat connectivity to the ground below, is that not so?) Yes, for the bottom surface of the wing. I wouldn't expect ice to form on that surface on nights where neither the air nor ground temperatures drop below freezing. Or do they acquire and retain frost because some colder and therefore heavier below-freezing air just fell down on them at some earlier time? In that case a thermometer registering the ambient air temperature should also record this below-freezing temperature sometime during the night. But the lowest temperature recorded on the night in question was reported to be +40F. I'll wait for an authoritative answer, but bet on the latter explanation. How much? ![]() |
#56
I don't follow the workload issue. Yes, the Mooney may require a bit
more skill to land but in cruise I've not noticed it flying much different than an Arrow (just faster). I've had both, I love my Mooney best. The Mooney is the ideal plane for tall guys like me. My partner is of average size and finds it difficult to find the rabbit on the ILS and see over the glareshield as well as trying to reach the rudders. Short guys beware. ![]() -Robert |
#57
"T o d d P a t t i s t" wrote in message ... "Montblack" wrote: What I don't get is: Two wings of identical design and an identical starting temp, both sitting out on a cold February night (no sun). How does the dark wing get colder than the white wing? The dark wing radiates heat better than the white wing, so it cools more rapidly. I thought that bodies radiated EM energy based on the relative temperature irrespective of color? Darker bodies *absorbed* more visible spectrum radiation but there was no difference in radiating energy. Is this wrong? Mike MU-2 |
#58
Mike Rapoport wrote:
I thought that bodies radiated EM energy based on the relative temperature irrespective of color? Darker bodies *absorbed* more visible spectrum radiation but there was no difference in radiating energy. Is this wrong? Nope, you're right. See www.azsolarcenter.com/design/pas-1.html for an explanation. One relevant quote from that site: "The extent to which a material emits thermal energy depends both on the temperature of the material and nature of its surface. Polished metal surfaces are poor emitters and poor absorbers of thermal energy." Maybe not clear from the brief snippet I quoted, but when they talk about "nature of the material surface" they don't mean color. Jim Rosinski |
#59
I agree. Having lived 40nm south of Reno for five years, I would say that
it is no place for IMC flying in any piston single, by any pilot. The only IMC there consists of thunderstorms or clouds containing ice (or both) along with lots of turbulence (tow planes and gliders have ended up facing each other head on!). The current theory around Reno (I was there yesterday) is that the pilot thought he could climb on top since the tops weren't forecast to be too high. This strategy probably would have worked during daytime when the clouds are visible. When I had a Turbo Lance, I used to use this strategy to cross the mountains on top VFR at about 15,000 and then descend near Sacramento where tops were often below 5000'. I never depended on being able to see clouds at night over unlit terrain. In the case of the accident airplane the tops forecast was wrong and the pilot didn't realize it until he had bet his life. There is nothing wrong with Cirrus' deicing system. A TKS type sytem is pretty much immune from being overwhelmed by icing because the fluid runs back and protects the entire wing. In that respect it is superior to boots or heated leading edges where ice can form behind the protected surface. Granted, TKS doesn't have unlimited duration but that should not be a problem in practice. THe only way it doesn't work is if it is broken, out of fluid, turned off or not installed. Mike MU-2 "Colin W Kingsbury" wrote in message link.net... "houstondan" wrote in message oups.com... i like that analogy. i'm sorta suprised noone has gotten on the cirrus guys' comment that they have a really excellent icing system...the saying it's only good for an hour or so to find somewhere to land. huh?? do you suspect they might phrase that a little different in the sales talk?? i would be interested in knowing how many times that pilot had made that trip in those "approximate" conditions, relied on that "excellent" icing system and did just fine. Night, mountains, ice, inexperienced pilot? Could be just simple task saturation followed by panic followed by disorientation with 'chute deployment too late to make a difference. It's awful soon to speculate the deicing system is bum. -cwk. |
#60
This is a classic heat transfer problem from college engineering. The
heat transfered by radiation is proportional to the emissivity of the surface. Most paint emissivities range from .98 for flat black to as low as .8 for some very shiny paints. Oxidized aluminum, like my plane, would run .25, while a highly polished aluminum surface could be as low as .04. The other part of the heat transfer equation is that the transfer is proportional to the ratio of the temperatures to the fourth power. That is why something as far away as the sun is such a great heat source. It's temperature is very high. Finally, the radiant heat transfer is effected by the "view" of one surface to the other. This part is very complicated to calculate, depending on the geometry. I never was worth a crap at this part of the calculations. Have fun, tom pettit radiation-induced cooling and icing than a dark-colored plane would be, all else being equal. I get the sun heating darker surfaces up (many degrees!) more than an identical white surface. What I don't get is: Two wings of identical design and an identical starting temp, both sitting out on a cold February night (no sun). How does the dark wing get colder than the white wing? |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| can you tell if a plane's iced up by looking at it? | Tune2828 | Piloting | 8 | December 1st 04 08:27 PM |
| Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 11th 04 12:30 AM |
| Cirrus attracting pilots with 'The Wrong Stuff'? | Jay Honeck | Piloting | 73 | May 1st 04 05:35 AM |
| New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 05:43 PM |
