wrote in message ... The simplest way to make a helicopter go faster is to simply increase the rotor rpm. That way, the differential of lift as the helicopter goes faster and faster is less significant than a slower turning rotor. That is, at 400 mph tip speed and at 100 mph forward velocity, you have a 200 mph differential or 50% of the tip speed. At 1000 mph tip speed, you still have a 200 mph differential speed but its only 20% of the tip speed. So in this example, a helicopter with a 1000 mph tip speed could go forward at 250 mph before hitting 50% differential. I'm not sure what the actual tip speed is, but I know that a lot of modern fully articulated systems run at tip speeds just under the speed of sound in order to significantly reduce the chances of ground resonance. Dennis. Real helicopters use a tip speed on the order of 700-800 ft/sec (475-545 mph), well below the speed of sound. This has nothing to do with ground resonance. It is driven by blade loads, vibration & stability, and noise at high speeds. |
The fully articulated hub design is susceptable to ground resonance when landing. By increasing the rotor speed to just under the speed of sound, that is, so nothing goes faster than the speed of sound even at max forward velocity, the risk of ground resonance when landing is significantly reduced. There are other advantages to speeding up a fully articulated hub, but not flying apart when you land is a big one. Dennis. "mm" wrote: Real helicopters use a tip speed on the order of 700-800 ft/sec (475-545 mph), well below the speed of sound. This has nothing to do with ground resonance. It is driven by blade loads, vibration & stability, and noise at high speeds. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
wrote in message ... The fully articulated hub design is susceptable to ground resonance when landing. By increasing the rotor speed to just under the speed of sound, that is, so nothing goes faster than the speed of sound even at max forward velocity, the risk of ground resonance when landing is significantly reduced. There are other advantages to speeding up a fully articulated hub, but not flying apart when you land is a big one. Dennis. You clearly don't know anything about ground resonance. It has little or nothing to do with the blade tip Mach number. |
"mm" wrote:
You clearly don't know anything about ground resonance. It has little or nothing to do with the blade tip Mach number. I don't pretend to be a fully articulated hub expert, but this is not something I made up. It comes from an FAA inspector who makes his living flying all sorts of helicopters. He IS an expert. Are YOU an FAA inspector? Are you qualified to say that he is mistaken? Think about the word "resonance". Do resonance and frequency go hand in hand? By increasing the rotor RPM, do you increase the frequency of rotation? Of course you do, its the same thing. If you sing a perfect pitch into a tuning fork, does it also vibrate at resonance? Yes. If you sing at a non-resonant frequency, does it still vibrate? No. Are marching soldiers told to break step when crossing a bridge? Yes. Why? Resonance. Think about this and what ground resonance actually is. Before you say this guy doesn't know anything about what he does for a living, I suggest that you think about it a little while. Dennis. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
wrote in message ... "mm" wrote: You clearly don't know anything about ground resonance. It has little or nothing to do with the blade tip Mach number. I don't pretend to be a fully articulated hub expert, but this is not something I made up. It comes from an FAA inspector who makes his living flying all sorts of helicopters. He IS an expert. Are YOU an FAA inspector? Are you qualified to say that he is mistaken? Think about the word "resonance". Do resonance and frequency go hand in hand? By increasing the rotor RPM, do you increase the frequency of rotation? Of course you do, its the same thing. If you sing a perfect pitch into a tuning fork, does it also vibrate at resonance? Yes. If you sing at a non-resonant frequency, does it still vibrate? No. Are marching soldiers told to break step when crossing a bridge? Yes. Why? Resonance. Think about this and what ground resonance actually is. Before you say this guy doesn't know anything about what he does for a living, I suggest that you think about it a little while. Dennis. Yes, as a matter of fact I am qualified to say he is mistaken. I can guarantee you that I know MUCH more about ground resonance than you or your source. I challenge you to find a single reputable reference (text book, technical paper, certification documentation, FAA training material, etc.) that relates ground resonance directly to tip Mach number. Your source may be the worlds ultimate helicopter pilot, but I don't think that this is much of credential with respect to rotor aeromechanics and structural dynamics. The original analysis of helicopter ground resonance was by Coleman and Fiengold, NACA TN 3844. Read it, and will not find any mention of tip Mach number. Your tuning fork and marching soldiers examples are essentially meaningless in this context. |
I never said anything about tip mach number. I said "rotor speed". The two are similar, but not the same. I'm not going to sit here and argue with an anonymous person who thinks a "diskCopter" is practical. Your facts about ground resonance may have been accurate 50 years ago, but they are out of date. Dennis. "mm" wrote: Yes, as a matter of fact I am qualified to say he is mistaken. I can guarantee you that I know MUCH more about ground resonance than you or your source. I challenge you to find a single reputable reference (text book, technical paper, certification documentation, FAA training material, etc.) that relates ground resonance directly to tip Mach number. Your source may be the worlds ultimate helicopter pilot, but I don't think that this is much of credential with respect to rotor aeromechanics and structural dynamics. The original analysis of helicopter ground resonance was by Coleman and Fiengold, NACA TN 3844. Read it, and will not find any mention of tip Mach number. Your tuning fork and marching soldiers examples are essentially meaningless in this context. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
wrote in message ... I never said anything about tip mach number. I said "rotor speed". The two are similar, but not the same. Your original quote was "By increasing the rotor speed to just under the speed of sound,..." . When you talk about "rotor speed" and the "speed of sound" in the same sentence, blade tip Mach number is the only rational way to connect these two. How else can anyone compare "rotor speed" with the "speed of sound", please tell us. Without my connecting these two quantities this way for you, everything you said is completely meaningless (as opposed to simply wrong). I'm not going to sit here and argue with an anonymous person who thinks a "diskCopter" is practical. I've NEVER said anything about the "diskCopter" at all in this discusssion. (For the record I think the "diskCopter" is silly.) Your facts about ground resonance may have been accurate 50 years ago, but they are out of date. We're talking about physics here, what part of that "went out of date". Please tell us what part of the analysis "no longer applies". I'll bet you don't even really know what ground resonance is. How about this, tell the group just what is in resonance with what. What is the frequency of the blade motions, what is the frequency of the body motions? How is it prevented? Do you know the FAA or military requirements with respect to ground resonance? Tell us how many helicopters you have done a real stability analysis for. When you can do this, then please explain further your comments about the "speed of sound" and it's crucial role in this phenomenom, I'd really like to hear your detailed analysis. I really don't care about what you know and don't know, I just get a little annoyed with people on the internet who spout complete nonsense to the rest of the world, and then rather than trying to learn something argue with reality. You might mislead someone with your nonsense and cause some harm some day. I'm sorry if tone of this conversation is less than polite, I just don't deal well with nonsense. |
I don't mean to further yet another moronic discussion about yet
another pie in the sky (lol) rotorcraft, but MM, regardless of who he is, is correct. Ground resonance has nothing to do with rotor tip speed. Its mainly germane to helicopters which have shock-struts as the main rotor rotational rate crosses the resonant frequency(ies) of the struts. It tends to be exaggerated and more dangerous in machines with four struts and three blades. Nothing has ever caused my Jetranger to enter the onset of ground resonance. Know why?; Two blades, No struts....Hmmm. Mach number my eye, and who the heck cares about ground resonance in a discussion on increasing Vmax? Bart wrote: I never said anything about tip mach number. I said "rotor speed". The two are similar, but not the same. I'm not going to sit here and argue with an anonymous person who thinks a "diskCopter" is practical. Your facts about ground resonance may have been accurate 50 years ago, but they are out of date. Dennis. |
Like I said, my source does know what he is talking about and you don't. I am not the expert and I cannot adequately explain why the rotor speed is important for preventing ground resonance. However, my source told me that it is and he is far more credible than you. How many of the newer fully articulated hubs have tip speeds of only 400 mph? I wonder why they sped things up. The other poster did have a point regarding landing struts. Fixed struts hitting the ground are high(er) frequency. Spring loaded struts are low frequency. Its the frequency imparted into the body and thus the blades during impact, not just the impact itself. Past that, I'm not going to say any more. I suppose in your next post that you will be spouting nonsense about how it has something to do with gravity and the space-time contuinuum or something. Quite frankly, you are a troll. I am not going to waste any more time with you. If you want to post that you are the helicopter god of the world, be my guest. I won't challenge you. You are still posting anonymously and expect us to believe that you are an expert. Get real. Dennis. "mm" wrote: Nonsense deleted Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
| Taiwan to make parts for new Bell military helicopters | Otis Willie | Military Aviation | 0 | February 28th 04 01:12 AM |
| FA: The Helicopters Are Coming | The Ink Company | Aviation Marketplace | 0 | August 10th 03 06:53 PM |
| OH-58 for Civilian use | pp | Rotorcraft | 10 | July 17th 03 08:53 PM |
