Slick aircraft tires
Old September 8th 04, 05:41 PM
Paul Lee
Default Slick aircraft tires
Anybody know of a source for slick aircraft tires?
The canard design front nose tire tends to throw pebles back
toward the pusher prop. I figure a slick tire without groves
would do it less.
SQ2000 canard: http://www.abri.com/sq2000
Old September 9th 04, 06:33 AM
Colibri
No, but...
would do it less.
http://www.avtesting.com/Documents/C...s/Airframe.txt
Question #344
Chines are used on some aircraft nose wheel tires to
A) help nose gear extension at higher air speeds.
B) help reduce the possibility of hydroplaning.
- C) help deflect water away from the fuselage.
Maybe pebbles too?
Old September 10th 04, 03:41 AM
Paul Lee
Do you know what a "chine" is?
Colibri wrote in message ...
No, but...
would do it less.
Question #344
Maybe pebbles too?
Old September 10th 04, 05:42 AM
Colibri
Yep.
Do you know what a chine is when it's part of a tire sidewall? Couldn't
find a picture online, sorry.
No, but...
would do it less.
Question #344
Maybe pebbles too?
Old September 10th 04, 03:44 PM
Paul Lee
That's begging the question. Never heard off a "chine" in any case.
There is such a thing as trying to describe it in words - w/o pictures.
Old September 11th 04, 02:02 AM
Dave Hyde
Paul Lee wrote...
In the case of a tire it's a circumferential
flared-up ridge just outside the wheel hub
on both sides. Kind of like you pinched up a wall
around the sidewall of the wheel on each side. You
can see 'em on some Lear nosewheels. Wouldn't
be on 'em holding down gravel any better than
a standard nosewheel.
In other cases you might have heard them called
"strakes" g
Dave 'mushroom' Hyde
Old September 11th 04, 02:09 AM
Dave Hyde
I wrote...
Wouldn't be on 'em holding down gravel...
Uh, that's "Wouldn't BET on 'em holding down gravel..."
Dave 'odds' Hyde
Old September 11th 04, 07:01 AM
Colibri
A projecting, vane-like shape.
Those thin edges along the forward fuselage sides on an SR-71.
http://www.fas.org/irp/program/collect/sr-71-front.jpg
This Lear appears to have the nose tire I'm referring to!
http://www.aerialvideo.com/photogall...tnosemount.jpg
The chines act like fenders.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
