Can anyone here talk to me abut the Realflight G2 flight sim. First, I need
a review as to it's realism as it applies to flight charactaristics of heli's (and planks) but mostly heli's. I googled it and only came up with 2 reviews. One was negative and one was on the Reflight web page (biased proably). Personally, I really like the sim, but is it realistic to an actual RC copter? Also, the interface has 3 switches and a knob. I'm a bit confused about these. 1. The knob. Blade pitch? I see no real change when this is turned. 2. Throttle hold toggle switch. Doesn't hold throttle. Actually cuts it so if I am in a hover and hit this switch I come down fast. Returning switch to original position returne me to hover power. 3. Dual rate switch. I think I have this one figure out. 4. Most confusing switch to me.. The G2 manual lists it as Idle up but I seem to feel that it is a flight mode switch. What is this for? It's a 3 position toggle switch amd I can't figure out what it does. The only efect I get from this switch is when I am in an inverted over of inverted flight. If the switch is in the top or bottom position, the engine quits (or maybe just the main rotor stops) after a few seconds. In the center position and while inverted everything keeps spinning ang I can remain inverted as long as I like Help me out here?? Many thanks, OC |
Old Codger
Coupla things The throttle Hold switch is actually doing what its supposed to do. Model Helicopters mix the throttle and collective pitch automatically. So when you hit the Hold switch it sends the motor to low throttle and allows you to manipulate the collective with out changing the throttle. Allows you to practice autorotations without acttually shutting the motor down. The Idle up switch is actually a flight mode switch. you should be able to set the throttle/pitch curve to allow three modes. Basic mode - the throttle is linked to the collective aerobatic mode - throttle is linked to collective with more throw to the pitch. 3d mode - throttle is set in a high power mode and the collective is decoupled from it. Also collective pitch is maximized to +- 10-15 deg. this allows those wild aerobatics. The rotating knob I guess would be the gyro gain. Do you notice any difference in tail rotor athority when you manipulate the knob ? all the best Sean old_codger wrote: Can anyone here talk to me abut the Realflight G2 flight sim. First, I need a review as to it's realism as it applies to flight charactaristics of heli's (and planks) but mostly heli's. I googled it and only came up with 2 reviews. One was negative and one was on the Reflight web page (biased proably). Personally, I really like the sim, but is it realistic to an actual RC copter? Also, the interface has 3 switches and a knob. I'm a bit confused about these. 1. The knob. Blade pitch? I see no real change when this is turned. 2. Throttle hold toggle switch. Doesn't hold throttle. Actually cuts it so if I am in a hover and hit this switch I come down fast. Returning switch to original position returne me to hover power. 3. Dual rate switch. I think I have this one figure out. 4. Most confusing switch to me.. The G2 manual lists it as Idle up but I seem to feel that it is a flight mode switch. What is this for? It's a 3 position toggle switch amd I can't figure out what it does. The only efect I get from this switch is when I am in an inverted over of inverted flight. If the switch is in the top or bottom position, the engine quits (or maybe just the main rotor stops) after a few seconds. In the center position and while inverted everything keeps spinning ang I can remain inverted as long as I like Help me out here?? Many thanks, OC |
"Sean Trost" wrote in message om... Old Codger Coupla things The throttle Hold switch is actually doing what its supposed to do. Model Helicopters mix the throttle and collective pitch automatically. So when you hit the Hold switch it sends the motor to low throttle and allows you to manipulate the collective with out changing the throttle. Allows you to practice autorotations without acttually shutting the motor down. The Idle up switch is actually a flight mode switch. you should be able to set the throttle/pitch curve to allow three modes. Basic mode - the throttle is linked to the collective aerobatic mode - throttle is linked to collective with more throw to the pitch. 3d mode - throttle is set in a high power mode and the collective is decoupled from it. Also collective pitch is maximized to +- 10-15 deg. this allows those wild aerobatics. The rotating knob I guess would be the gyro gain. Do you notice any difference in tail rotor athority when you manipulate the knob ? all the best Sean Your explanation is very clear...thank you. I'll have to check on thr TR authority and the knob. I haven't checked on that. |
As for realism it's not the most realistic out there, that's for sure.
Hovering isnt bad, but it "feels" very different when flying around. It will build in you the proper reflexes though as stick and orientation are the most useful aspects of using a sim. Flying in real life is just different because it's harder to see orientation and a lot more scarey when youre life and money is on the line. You tend to "freeze" a lot more in real life when you get into problems. I think the scale Commanche helicopter in FMS feels very realistic with it's weight and momentum athough it wont do 3d very well. ![]() |
The rotating knob I guess would be the gyro gain. Do you notice any difference in tail rotor athority when you manipulate the knob ? No idea about helis but in G2, the rotating control knob is commonly used to operate flaps on fixed wing aircraft. Take a look at the actual aircraft description in the select aircraft box. It should tell you the assignments for each aircraft. MS |
| RealFlight RC simulator | coustanis | Simulators | 3 | February 11th 04 10:33 PM |
