9800 Pro & FS2004
Old September 17th 04, 06:36 AM
Skyhawk
Default 9800 Pro & FS2004
Hi all
I just bought Radeon 9800 Pro and is running almost excellent. "Almost",
because I have a problem running FS2004. The fps is very low and during
(only) fs2004 harddrive is accessed constantly. It's happening on high
settings. When I minimize them, the FS2004 runs smooth with occasional
stutter once every 10-20 seconds, and harddrive is not being accessed
constantly then. I think that 9800 Pro should handle every current game
pretty easily, and my system is not so old. Any ideas, I think it's a common
problem. I've seen many posts on this topic in the past (not on this group),
but never found any solution.
BTW, during Mafia, all settings on max runs smooth with occasional stutter.
When I disable sound in Mafia's Setup the stutter no longer exists.
Disabling sound in FS2004 doesn't help at all though .
I think I got 2 problems: 1. occasional stutter (probably sound card etc) 2.
constant hd access during FS2004 (probably not sound card related)
FS2002, on maximum settings, runs (almost) beautifully if it wasn't for that
occasional stutter.
Please help, cause I thought that with this card all my gaming problems
would disappear.
Previously I had nVidia G4 420 MX, and FS2004 run almost the same as on 9800
Pro. All other games were of course much worse.
My comp:
Dell Dimension 8250
chipset Intel i850
Pentium 4 2.4 (not HT)
512 Ram
120Gb 7200
Radeon 9800 Pro 256Mb
Sound Blaster Live!
Old September 17th 04, 06:54 AM
Peter Duniho
"Skyhawk" wrote in message ...
Hi all
settings.
512 Ram
Add more RAM.
When the hard drive is going at the same time performance suffers, you are
almost always dealing with a low-memory issue. I can easily believe that
512MB is not enough RAM for running FS2004 at high graphics settings.
Pete
Old September 17th 04, 02:33 PM
Quilljar
You do not say what you consider lowFPS? For FS2004 I find that 15 -18 fps
is perfectly acceptable. However, with 512 RAM you will never get the
results that you want. Double that at least.
Hi all
settings.
512 Ram
Add more RAM.
Pete
Old September 17th 04, 06:13 PM
Tom Gibson
Hi,
Until you add more RAM, you must close down all uneeded programs while
you are flying (like antivirus and other programs, as well as unneeded
OS parts). Use a program like End it All or Ken Salter's program at
AVSIM to quit these before starting up FS.
Hope this helps,
Skyhawk wrote:
Hi all
occasional stutter.
would disappear.
My comp:
Dell Dimension 8250
chipset Intel i850
512 Ram
120Gb 7200
Sound Blaster Live!
Tom Gibson
California Classic Propliners: http://www.calclassic.com/
Cal Classic Alco Page: http://www.calclassic.com/alco/
Freeflight Design Shop: http://www.freeflightdesign.com/
San Diego Model RR Museum: http://www.sdmodelrailroadm.com/
Drop by! ___x_x_(")_x_x___
Old September 30th 04, 10:37 PM
Mr Digital
I tended to find this was the case on my system too. I now have 1.5gb of
DDr400 PC 3200 ram & the Athlon XP2600 processor GF4 Ti 4800 on AGP8 & i get
about a constant 18 to 20fps with no stuttering. This is without having to
close any applications.
Phil.
"Tom Gibson" wrote in message
Hi,
Until you add more RAM, you must close down all uneeded programs while you
are flying (like antivirus and other programs, as well as unneeded OS
parts). Use a program like End it All or Ken Salter's program at AVSIM to
Hope this helps,
Skyhawk wrote:
Hi all
common problem. I've seen many posts on this topic in the past (not on
this group), but never found any solution.
stutter. When I disable sound in Mafia's Setup the stutter no longer
exists. Disabling sound in FS2004 doesn't help at all though .
2. constant hd access during FS2004 (probably not sound card related)
that occasional stutter.
would disappear.
9800 Pro. All other games were of course much worse.
My comp:
Dell Dimension 8250
chipset Intel i850
512 Ram
120Gb 7200
Sound Blaster Live!
Tom Gibson
FS2004 & ATI 9800 XT Classic - problem! smooby Simulators 1 March 22nd 04 11:21 PM
Vatsim, FS2004 and online flying, help Anthony Acri Simulators 0 October 13th 03 06:16 AM
Disappointed with FS2004 Phiber Optik Simulators 5 October 12th 03 05:13 PM
Bridges in FS2004 Kevin Reilly Simulators 18 October 3rd 03 12:00 AM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 11:20 PM
