Cleaning a 3-way TE probe
Old October 9th 03, 04:06 AM
JJ Sinclair
The Limitations of the Experimental Certificate on my current sailplane
(Ventus 2 Bx) does not state anything about operating in accordance with
flight/maintenance manuals.
Yes I have those limitations on both the ASH-25 and the Genesis 2 and all the
experimental airworthiness limitations that I have seen for the last 10 years
has had them also. Its contained in a 4 page document that is stapled to my
airworthiness certificate. You don't have 4 pages? I would quote them, but
their in the ship, in the trailer and in the barn.
JJ Sinclair
Old October 9th 03, 06:06 AM
Duane Eisenbeiss
"Marc Ramsey" wrote in message
m...
"Duane Eisenbeiss" wrote...
Here's an example from some Operating Limitations circa 1998:
7. This aircraft shall not be flown unless it is inspected, maintained
and
operated in accordance with appropriate technical publications as
follows:
Flight Manual for the ELAN/GLASER-DIRKS, DG-300 ELAN ACRO,
dated 5/92, as revised and the Maintenance Manual for the
ELAN/GLASER-DIRKS, DG-300 ELAN ACRO, dated 5/92, as
revised.
I've owned four experimental gliders over the past 10 years, and they all
had
this same basic wording. It is apparently part of the boiler plate Ops
Lims in
whatever Advisory Circular the FSDO uses to put these things together...
Marc
My older sailplanes Operation Limitations were sort of "hand written" (ie:
much simpler). The Limitations for my current ship was directly out of a
"boiler plate" on the FAA inspector's desktop computer. I watched as he
composed it. I guess that different offices use different criteria. Thanks
for filling me in on what is happening out West.
Duane
Old October 10th 03, 04:22 AM
James
The latest research out of Stanford University suggest that ant
infestations are the result of weather, especially cold and wet
conditions, and unusually hot and dry spells (probably bec they're
trying to find shelter from extreme weather). According to the
researchers, insecticides are also ineffective at controlling the
infestations. The best thing to do is to close up entrances the ants
are using, and wipe down the ant trail with Windex to eliminate their
scent trail. Read about this at
http://www.stanford.edu/dept/news/pr/01/ants45.html
Old October 10th 03, 04:47 AM
Jack Glendening
infestations.
One can certainly learn a lot on RAS! My home is in an area conducive
to ants and I can attest to the close relationship of ant invasion and
weather, but I've found that a spray insecticide at the entry point will
stop ants from invading a specific area (though my ants will crawl right
over bait I leave out). So I will still use the insecticde on my plane
but will also plug the hole in question. Thanks for the info, which I
had not seen before.
Old October 10th 03, 05:27 AM
Mark Navarre
Ants are effective scavengers, and may in fact be consuming a rat or mouse
inside your tailboom that died there after eating your pitot, vario, or static
tubing. It might be better to leave the ants alone until they finish off
whatever is attracting them to the inside of your glider, and then continue
with the pneumatic system fixes. Not to depress you any further or
anything.....
Mark Navarre
ASW-20 OD
California, USA
Old October 10th 03, 10:55 AM
Jack Glendening
At this point I am more concerned with what _live_ ants might be doing
than with an already _dead_ rodent remaining in there, which I could live
with! What worries me is that the last time I was out there I tried
to wash off much of where they had been with the idea of erasing their
chemical tracks - yet the next day were again back in that hidden
hole, which would not seem like an easy thing to do. So I have begun
to wonder if the ants are coming from the outside in or whether there
is already some sort of colony _inside_ (since then they would find
that hole rather easily, from from the inside). My lack of detailed
knowledge of what ants can do and my imagination has produced a paranoia
level which wants those ants out _now_!
Old October 10th 03, 12:54 PM
Martin Gregorie
On Fri, 10 Oct 2003 08:55:11 GMT, Jack Glendening
That seems entirely reasonable paranoia to me.
Some years back I met some fellow Landrover travellers in Goa who
warned me about the local army ants: two evenings later I spotted a
column headed for my back wheel and was able to nip the invasion in
the bud with a few kettles of boiling water, but I digress.
The other group had found ants living inside the box girders that form
their Landrover's chassis. They drove them from one end of the vehicle
to the other three times, using boiling water and insecticide and
completely stripping their stuff out each time, before they were able
to get rid of them.
Are you sure your ants are confined to your tail group and not getting
into the wheel box or under the seat pan?
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
  #28
Old October 10th 03, 08:12 PM
Jack Glendening
My paranoia has now reached a new high! No I'm not sure - though I have
not noticed the ants elsewhere I will now be paying extra attention. I
do appreciate the info that the ants _can_ colonize in such artificial
conditions, since I normally associate them with forming colonies in the
soil and did not know how realistic it might be for them to invade a glider.
  #29
Old October 10th 03, 08:42 PM
Stewart Kissel
Dr. Jack-
It could be worse. A coworker of mine was very intrigued,
but also very nervous about glider flying. We went
through a very thorough briefing and I promised no
thermalling or steep turns.
She seemed to be doing okay in the front seat of the
L-13 on tow, so I did not have the heart to tell her
about the mouse that was perched on her left shoulder.
He eventually ambled back to his abode somewhere in
the ship and the flight continued.
and not getting
extra attention. I
in such artificial
colonies in the
  #30
Old October 10th 03, 08:54 PM
Tony Verhulst
When a student opened the air vent on a 2-33 at about 3K, a wasp was
blasted out and landed on his crotch right, at the seat level. He din't
get stung but his dance, as seen from the back deat, was interesting.
Tony V.
USFJ commander defends US response to, probe of helo crash Otis Willie Military Aviation 0 August 28th 04 01:29 AM
US military rejects Japan police request for chopper probe Otis Willie Military Aviation 0 August 19th 04 03:58 AM
landing gear cleaning Bob Miller Owning 4 July 5th 04 10:24 PM
Follow-up probe ordered into June 'friendly-fire' hit Otis Willie Military Aviation 0 March 3rd 04 04:46 AM
Broken line to Oil Temperature Probe, Repairable? rkane33 Owning 2 July 25th 03 04:19 AM
