Fuel pump fittings
Old October 1st 04, 01:57 PM
GeorgeB
On Thu, 30 Sep 2004 20:55:48 -0400, Evan Carew
Dave,
Yeah, I've been to those exact pages, & will note for the record that
none of those pages mention an o-ring for sale, however, the pictures do
indicate that the parts come with said o-ring. If not, like I said, I
would like to know the particulars for when I go a calling the very well
informed A&S sales people (tongue firmly in cheek here).
OK, a hydraulic guy here ... don't know if oyu are after rubber type
or size.
These are what are normally called "SAE" fittings and use (usually) a
90 durometer nitirle material. It looks like they are SAE #6 (thread
is 3/8-24), but just for grins,
size thrd ID section
-4 7/16-20 .351 .072
-5 1/2-20 .414 .072
-6 9/16-20 .468 .078
-8 3/4-16 .644 .087
These do not appear to be in the AS568A dash number series but are
available at any fluid power fitting source.
George
Old October 1st 04, 04:44 PM
Evan Carew
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
George,
I had a feeling they were SAE threads as a common SAE tap set I have
lying around fit the threads. Thanks also for the info on the o-rings.
Sometimes its difficult to get the kind of detailed info you need to
talk to a salesperson who doesn't know their product line. Its good to
see that there are at least a few people who can help out on this
subject from this news group.
Evan
Dave,
or size.
-5 1/2-20 .414 .072
-8 3/4-16 .644 .087
George
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFBXXtboo/Prlj9GScRAkEcAJ91ZV8XGs4RgShULSJ+pysJpQOIxwCfRBFe
AEj/M3I8ZdzCrN5mOQDUrN4=
=fNwY
-----END PGP SIGNATURE-----
Old October 2nd 04, 02:20 AM
Blueskies
All the fittings are he
http://www.parker.com/tfd/cat/pdffiles/C-Triple-Lok.pdf
Packings, seals and materials are he
http://www.parker.com/o-ring/Literature/00-5700.pdf
I work for Parker, so I am biased somewhat....
"Evan Carew" wrote in message ...
Hash: SHA1
George,
I had a feeling they were SAE threads as a common SAE tap set I have lying around fit the threads. Thanks also for the
info on the o-rings. Sometimes its difficult to get the kind of detailed info you need to talk to a salesperson who
doesn't know their product line. Its good to see that there are at least a few people who can help out on this subject
Evan
Dave,
Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale,
however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the
particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here).
or size.
-5 1/2-20 .414 .072
-8 3/4-16 .644 .087
George
=fNwY
Old October 2nd 04, 11:56 AM
GeorgeB
I worked for a Parker distributor and got the dims from that catalog.
You folks are GREAT.
I've since found that the SAE o-rings are to 568-9xx series where xx
is the 2 digit dash number (nominal tube OD in 1/16" units). I listed
the ones for the dimensions I gave below with the eimensions.
568-904
-5 1/2-20 .414 .072
568-905
568-906
-8 3/4-16 .644 .087
568-908
Old October 3rd 04, 02:19 AM
Bob Olds
"Dave Hyde" wrote in message ...
Evan Carew wrote...
none of those pages mention an o-ring for sale...
You might note that none of the fittings pictured are
simple 37 deg flare to NPT fittings - there's
a wider bearing surface for the O-ring/NPT end.
The Lycoming standard solution does _not_ appear to
be to stuff an O-ring over an NPT fitting, cut down
or otherwise.
Dave 'field mod' Hyde
That fuel punp fitting must have a nut to clamp down on the "O" ring.
This compresses the "O"ring and locks the fitting in place.
Bob Olds RV-4
A&P , EAA Tech. Counselor
Charleston,Arkansas
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 12:08 PM
