#21
In article , Todd Pattist
writes: The first time I tried this in my Ventus, I was flying along sideways with full rudder and level wings and heard a loud "BANG!" After my heart stopped thumping, I figured out that one of the gear doors had sucked open into the sideways airflow. :-) That happened to me once.Scared the hell out of me. Another scarey bang was in a Puchacz on the winch when the cover, which is over the rear seat adjustment bar, could not have been secure and flicked down and hit the side of the fuselage. This was about six inches from my left ear and was magnified by the megaphone shape of the hollow fuselage. A third was in a Bocian, also on a winch when the rear canopy, which slid backwards on rails, came unlocked, slid back and hit the rear stop. This one was probably the worst because, a) we were about 100ft and starting to rotate into full climb, b) in addtion to the "bang" as it hit the stop, there was a huge, disorientating rush of air, and c) it took a while to work out what had happened, take over from the pupil, (only his second or third winch take off) and get the nose down etc. However, one of the the worst I know of these type of incidents was a pilot at my club who owned a Carmem and lost the complete canopy at about 4000ft agl. It departing it caught his skull which bled profusely and a combination of blood and the wind causing his eyes to run, made it extremely hard for him to see. Once he worked out what had happened, his big concern was what else the canopy had hit, tailplane for example. He considered baling out but, having checked all controls decided to ride it down to the nearest field, successfully I am pleased to say. The farmers reaction to this bllod covered figure arriving at his door was, I understand, unprintable. Needlesss to say, all of the above (except U/c doors) occurred either as a result of poor take off checks or mechanical faults. Barney UK |
When turning, the only rotation is about the vertical (earth-fixed) axis.
Then take it to the extreme case of diving straight down (here defined as the longitudinal axis vertical). In that situation, all of the rotation will be around the longitudinal axis of the aircraft - i e roll. Remember, we're talking about Sammy's model. When diving there is no rotation, about the longitudinal or yaw axis. (There is no aileron input.) Same thing going straight up. The orientation of the lift vector (positve values) would rotate the glider about the lateral axis. In turning flight with the fuselage level (longitudinal axis horizontal), all of the rotation will be around the yaw axis of the aircraft. Again, not according to the model as I understand it. If the aircraft is sinking, the one wingtip is travelling faster than the other, and therefore there is a difference in angle of attack, and in model, this is accounted for as a roll. I'm waiting for the book to show up, but I suspect that we're all taking this too literally, trying to justify it in the real world. As for the train, the only force of importance is the side force on the rail. There is no friction (or better said, it is unabserved). The point is that a leaning train looks like a turning train to a sensor that simply measures force acting in a single direction. |
| Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 04:44 PM |
| Stalling and spinning generally | Ian Strachan | Soaring | 0 | February 1st 04 09:40 PM |
| Spinning or the after effects of stalling. | Dave Martin | Soaring | 0 | January 30th 04 12:24 AM |
| Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 02:35 AM |
| Dynamic stalling of delta wing a/c (wrt MiG 21) | drake | Military Aviation | 12 | August 26th 03 07:37 PM |
