Ultralight sailplane aerotow liability
Old March 27th 04, 01:35 AM
BTIZ
very interesting.. I'll have to research that one..
it could be in the "FAR definition" of "aircraft, airplane, glider, and
ultralight"
BT
"mat Redsell" wrote in message
When I was inquiring about towing an ultralight the FAA said that an "N"
numbered aircraft can't pull one without an "N" number.... this might also
be worth looking into.
-mat
Old March 27th 04, 01:37 AM
BTIZ
snip
shows precedent. I hope this becomes true for Sport Pilot
also. Otherwise, with the 10,000 ft altitude restriction,
Sparrowhawk is unlikely to want to make a Sport version (at
least that was one downside that Greg Cole communicated to me).
snip
makes sense to me, but with no N number.. there are those that are taking on
risk to tow the sparrowhawk aloft.
BT
Old March 27th 04, 06:32 AM
Tim Ward
"Mark James Boyd" wrote in message
news:4064a206$1@darkstar...
In article VQP8c.9144$1I5.308@fed1read01,
BTIZ wrote:
Will this all change with the coming of the "Sport Pilot Certificate" and
the "Sport Aircraft" certification?? I'm sure the Sparrow Hawk will fit
into
that category.
The Vne limit and 10,000 ft altitude Sport restrictions
discourage some glider makers from making
a glider a sport category aircraft...
Mark Boyd
Avenal, California, USA
I think you'll find the altitude limit is on the pilot, not the aircraft.
This is probably so they don't have to have oxygen systems in the Sport
Pilot curriculum.
The Vne limit is kind of silly, but it's just a placard. What if someone
made a glider with a design dive speed of 350 kts, and then placarded Vne as
100 kts, just as a "safety factor"?
But really, why have a Sport Pilot glider license? You need to pass an FAA
practical in either case. In neither case do you need a medical.
The Light Sport Aircraft could make certification somewhat cheaper for a
manufacturer, but as long as gliders are able to get the Experimental --
Exhibition and Racing registration, I don't think it's a huge deal.
Where LSA had the possibility of being useful to gliders was in having LSA
towplanes. I think a purpose-built towplane could be built within the
constraints of LSA that would be fairly inexpensive to run. But as I
understand it, towing is explicitly forbidden.
Tim Ward
Old March 27th 04, 01:21 PM
Michael
"mat Redsell" wrote in message ...
-mat
Mat,
I have seen N-registered tow planes towing gliders not being N-registered.
Are they all illegal in terms of FAA regulations?
Please let us know, thanks
Michael
Old March 27th 04, 05:25 PM
Tim Ward
"Michael" wrote in message
om...
also
-mat
Mat,
Michael
Maybe you could register an ultralight sailplane as a "banner".
Tim Ward
Old March 29th 04, 07:41 AM
Burt Compton
Please look into it - quote the FAR or the FAA letter stating this as a
reference so we can have it on file.
Old April 1st 04, 09:22 PM
Mark James Boyd
US CFR 91.309 outlines towing of "gliders" which presumably
means "gliders" as defined by the FAA (with airworthiness
certificate that says "glider").
US CFR 91.311 says "No pilot of a civil aircraft may tow anything
with that aircraft (other than under 91.309) except in accordance
with the terms of a certificate of waiver issued by the Administrator."
The banner tow guys have waivers, according to my plane partner who
used to tow banners in Los Angeles. I assume one could apply for a
waiver to tow other things, but I'm guessing success could be spotty.
The FAA FSDOs seem to be getting more and more conservative
(no more field approvals, increasing experimental "limitations" list,
etc.).
-mat
Mark Boyd
Old April 1st 04, 09:24 PM
Mark James Boyd
91.309 and 91.311
Mark Boyd
Old April 1st 04, 10:17 PM
Mark James Boyd
Well, with a sport version, an N number is given.
And yep, it would be a "sport glider."
The benefit is that maint. and inspection requirments
can be attained by 80 hours + 16 hours of sport maint. trng.
Others have mentioned the sport glider rating is
silly. Agreed, for the straight rating. But the transition rating
is something quite different (and useful).
In article s149c.12225$1I5.9505@fed1read01,
BTIZ wrote:
snip
snip
BT
Mark Boyd
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
AL-12: New ultralight sailplane ISoar Soaring 4 March 24th 04 02:52 AM
Russian jet powered sailplane John Soaring 4 February 12th 04 01:03 AM
Liability after sale Splat! Home Built 6 October 1st 03 02:20 PM
Ultralight magazine August 1981 Gilan Home Built 0 July 20th 03 05:34 AM
