Fllight Recorder Wars, Part II: What Backup to Use?
Old March 26th 04, 10:55 PM
Paul Remde
Hi Chip,
You mentioned below that you have questions about the future of CAI. That
is understandable, given the changes over the last 2 years. I was at first
very hesitant to work with the new company, but I have been impressed. They
ship products quickly and have done repairs as well. Gary Kammerer answers
technical questions in a timely fashion. The quality of the products seems
very good. I haven't had any returns.
Who knows what the future holds for any company. I wouldn't be selling
their products if I wasn't comfortable with the future of CAI.
Good Soaring,
Paul Remde
Cumulus Soaring Supplies
"Chip Bearden" wrote in message
om...
Good comments so far. Thanks. A few points:
1. The backup device MUST produce a log that's acceptable for U.S.
regional and national contests. As I read the rules, a handheld GPS
receiver is acceptable--even for a U.S. nationals--so long as it logs
altitude; a PDA-based system with a GPS card is not.
2. The most likely failure mode may well be a power problem, but I've
already got a backup power supply (that I've used 3 or 4 times over
the past 30+ years for genuine failures).
3. Regarding failure of the flight recorder:
a) the probability may be low but it's already happened once (the
UART comm. chip, I was told); to date, that's at least as frequent as
a power supply failure on a per hour or per flight or per year basis
b) the EFFECT is disastrous; if I'm going to drive halfway across
the country and spend the money to enter a nationals, I don't want to
zero a day because some $2 part fails. That's like tossing a live .45
caliber shell into a bin with 99 blanks, mixing them up, then picking
one at random, loading it into a pistol, aiming it at my head, and
pulling the trigger. The percentages are in my favor but the
consequences of that 1% chance are severe.
4. I can live without certain navigation and flight computer features
(I still carry a current sectional and a cardboard final glide
calculator) but if there are several alternatives and one allows me to
switch the source of GPS info for my LNAV and PocketNAV from my
Cambridge 20 to the backup device quickly and easily, it makes the
choice easier.
5. Gaps of up to 15 minutes are allowed, as are multiple incomplete
flight logs. So there is time to switch from one device to another so
long as (i) the primary flight recorder retains the flight log for the
portion of the flight preceding the failure point (not true,
apparently, when mine failed last year) OR the backup device has been
logging the flight from takeoff.
To date, Paul Remde's suggestion of a Cambridge 302A sounds easiest
(though not cheap). But that raises the same questions about
Cambridge's long-term (or even short-term) survival as were discussed
on this forum last year. What's the latest?
Chip Bearden
Old March 27th 04, 01:52 PM
Jim Kelly
| While the Volkslogger is excellent kit is most respects, it has
one
| drawback. It is necessary to manually erase old flights to ensure
there
| is room to store new flights. When the memory becomes full, it
stops
| recording.
True, however it will drive you mad first by beeping incessantly to
tell you that it has "less than 7 hours of memory left"! If this
happens in flight it is a simple matter to extend the interval
between recording fixes. It still records at close intervals near to
turn points and the like.
So, if Colibri has advantages, I consider that this is not one of
them . .
BTW, the Volkslogger can drive WinPilot whilst it is doing it's
official recording job. In this mode WinPilot will accept readings
at every second and save the trace too . . making one that is much
better to see in flight analysis programs. WinPilot provides a way
of sending a declaration to the Volkslogger, and getting the
official file out of it (onto the iPaq).
Cheers,
Jim Kelly.
Old March 29th 04, 09:27 PM
303pilot
I've got a Cambridge GPS, GPS Nav, LNAV and Aero 1550 running CEGlide.
Here's my back-up plan...
Carry my old Garmin 12xl + cables to connect to Aero. Turn on Garmin before
launch.
If any of the Cambridge stuff fails, unplug Aero from Cambridge, & plug Aero
into the Garmin. Turn in Garmin at end of flight.
Garmin traces were acceptable @ regionals summer before last--don't think
that's changed.
Brent
om...
snip
approaches, etc., for a primary flight recorder. I'm interested in
knowing what makes sense for a BACKUP GPS flight recorder that will:
1) act as a "dumb logger" (i.e., connect it to a separate battery,
switch on, and forget) for backup purposes
2) in the event of a failure of the primary flight recorder, could IN
FLIGHT be connected to my LNAV and/or Pocket NAV/Compaq WITHOUT
compromising the integrity of the record in the backup recorder. This
could involve swapping cables from one device to another (my current
GPS/NAV is accessible in the cockpit now) or making up a special "Y"
connector and/or switch.
I drove my LNAV with an early Magellan "fish finder" GPS receiver for
years before I bought the Cambridge flight recorder so I'm not averse
to carrying an independent backup flight recorder PLUS a cheap
handheld that could be powered up to provide GPS info to the LNAV
and/or PocketNAV for navigation.
snip
Old March 31st 04, 11:10 PM
Ian McPhee
I would like to add to Cambridge Service - Gary Kammerer is
outstanding and always seems to get to the bottom of problems. The
ideal situation would be Dave Ellis (with Phil S) or whoever working
on new instrument developments. The new 302A CFR does look good and I
believe will have a black case and "camera mount" 1/4 nut atached real
soon.
Ian McPhee
Australia
molding plexiglas websites? [email protected] Owning 44 February 17th 05 10:33 PM
How safe is it, really? June Piloting 227 December 10th 04 06:01 AM
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons Curtl33 General Aviation 7 January 10th 04 12:35 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 09:08 AM
