Why can't the GPS create the 'heading data' my $90 Etrex gives a heading
reading. "Bill Daniels" wrote in message news:_y8Ac.53766$0y.15362@attbi_s03... Dave, can it give highly accurate, real-time wind data, second by second on a straight one hour glide? My last flight showed this problem during a long glide. For 30 miles the wind data showed SW winds at 20 knots but then I noticed the glider drifting to the west. Two 360 turns and the computer showed wind at 090 at 10 knots. When I crossed the wind shift line I had a chance to change strategy. 30 miles later when the wind error became obvious it was too late. More and more I think we need very accurate real-time wind data with no requirement to be constantly changing heading. A cheap, reliable heading sensor would make this possible. Bill Daniels "Dave Nadler YO" wrote in message m... Bill - The heading is not required. In the ILEC SN10 we do this without heading, and it normally has the wind by the time you're off tow. Pilot feedback and measurements indicate that we do it quite accurately. We just use TAS and GPS ground track over multiple observations (TAS requiring accurate IAS, press, temp). Best Regards, Dave "YO" "Bill Daniels" wrote in message news:gw%zc.59643$HG.25574@attbi_s53... I've been analyzing the IGC files from my flights and comparing them to others. Generally, in good conditions, I'm circling less than 25% of the time. Other, far better pilots than I, are circling less than 15% of the time. This means that wind data that depends on the glider flying circles gets way out of date during the long glides. OK, "S" turns can give the computer a chance to compute wind if you remember to fly them but there are still a lot of long, straight glides. To compute real-time wind data we need Groundspeed, Ground Track (any GPS gives these)True Airspeed (Some computers do this if they have OAT, Pressure Altitude and IAS) and accurate heading data. Heading data it the tough nut to crack. So, how do we get Heading? One way might be to put a GPS antenna in each wing and look at the carrier phase difference. If the computer saw a constant track, it could assume the wings are level and determine a heading value. This heading value might update an aerospace quality MEMS heading gyro that would maintain a flow of heading data to the glide computer during times when the wings were banked. With good heading data we could get uninterrupted high quality wind data regardless of the gliders' maneuvering or lack of it. OK, RAS gageteers, how about it? Bill Daniels |
The GPS gives TRACK, not HEADING. It can't tell what direction the glider is
pointing in, only the direction its motion is taking it across the ground. David Starer "f.blair" wrote in message news:E5aAc.44219$2i5.30680@attbi_s52... Why can't the GPS create the 'heading data' my $90 Etrex gives a heading reading. "Bill Daniels" wrote in message news:_y8Ac.53766$0y.15362@attbi_s03... Dave, can it give highly accurate, real-time wind data, second by second on a straight one hour glide? My last flight showed this problem during a long glide. For 30 miles the wind data showed SW winds at 20 knots but then I noticed the glider drifting to the west. Two 360 turns and the computer showed wind at 090 at 10 knots. When I crossed the wind shift line I had a chance to change strategy. 30 miles later when the wind error became obvious it was too late. More and more I think we need very accurate real-time wind data with no requirement to be constantly changing heading. A cheap, reliable heading sensor would make this possible. Bill Daniels "Dave Nadler YO" wrote in message m... Bill - The heading is not required. In the ILEC SN10 we do this without heading, and it normally has the wind by the time you're off tow. Pilot feedback and measurements indicate that we do it quite accurately. We just use TAS and GPS ground track over multiple observations (TAS requiring accurate IAS, press, temp). Best Regards, Dave "YO" "Bill Daniels" wrote in message news:gw%zc.59643$HG.25574@attbi_s53... I've been analyzing the IGC files from my flights and comparing them to others. Generally, in good conditions, I'm circling less than 25% of the time. Other, far better pilots than I, are circling less than 15% of the time. This means that wind data that depends on the glider flying circles gets way out of date during the long glides. OK, "S" turns can give the computer a chance to compute wind if you remember to fly them but there are still a lot of long, straight glides. To compute real-time wind data we need Groundspeed, Ground Track (any GPS gives these)True Airspeed (Some computers do this if they have OAT, Pressure Altitude and IAS) and accurate heading data. Heading data it the tough nut to crack. So, how do we get Heading? One way might be to put a GPS antenna in each wing and look at the carrier phase difference. If the computer saw a constant track, it could assume the wings are level and determine a heading value. This heading value might update an aerospace quality MEMS heading gyro that would maintain a flow of heading data to the glide computer during times when the wings were banked. With good heading data we could get uninterrupted high quality wind data regardless of the gliders' maneuvering or lack of it. OK, RAS gageteers, how about it? Bill Daniels |
Subject: Gageteers, we need a digital heading sensor
From: "Bill Daniels" My last flight showed this problem during a long glide. For 30 miles the wind data showed SW winds at 20 knots but then I noticed the glider drifting to the west. Two 360 turns and the computer showed wind at 090 at 10 knots. When I crossed the wind shift line I had a chance to change strategy. 30 miles later when the wind error became obvious it was too late. More and more I think we need very accurate real-time wind data with no requirement to be constantly changing heading. A cheap, reliable heading sensor would make this possible. I very strongly agree, because I too am "cursed" with long glides between thermals when flying long cross country flights. Air masses may change dramatically in 10's of miles, but you won't know if you don't stop for a few turns, also late in the day shear lines come through and cannot be easily spotted on blue days without real-time wind info. This info WILL make the difference between getting there faster or slower (or getting there at all!). If you don't understand this, then you either haven't flown 50-60+ mile glides, or are just not observant enough of the situation to care. Our climb instruments have evolved to the point that we really know what the air is doing in the vertical direction, it would sure be nice to have as much info about the horizontal direction. - Mark Navarre 2/5 black ace LoCal, USA remove brain to reply - |
Bill, you're absolutely right, during a dead straight glide
with constant airspeed their isn't enough information to compute the result. With an SN10 you need to make an S-turn at least to get an update. The heading sensor issue is a bit difficult. Certainly it can be done with GPS using multiple antennas (I can't remember the commercial products that do this off-hand). Google and you'll find a few research projects using GPS for attitude as well as heading. Cost is not on for gliders real soon. Compasses are very cranky beasts, especially if they need to be glider- pilot-proof (about which I could tell stories for hours). Making something that is low-cost, self-calibrating, immune to stupid installations - that's the hard bit. Hope that all makes sense, Best Regards, Dave PS: Haven't seen anyone suggest a sun-tracker yet ? Or vision-system with terrain matching ? "Bill Daniels" wrote in message news:_y8Ac.53766$0y.15362@attbi_s03... Dave, can it give highly accurate, real-time wind data, second by second on a straight one hour glide? My last flight showed this problem during a long glide. For 30 miles the wind data showed SW winds at 20 knots but then I noticed the glider drifting to the west. Two 360 turns and the computer showed wind at 090 at 10 knots. When I crossed the wind shift line I had a chance to change strategy. 30 miles later when the wind error became obvious it was too late. More and more I think we need very accurate real-time wind data with no requirement to be constantly changing heading. A cheap, reliable heading sensor would make this possible. Bill Daniels "Dave Nadler YO" wrote in message m... Bill - The heading is not required. In the ILEC SN10 we do this without heading, and it normally has the wind by the time you're off tow. Pilot feedback and measurements indicate that we do it quite accurately. We just use TAS and GPS ground track over multiple observations (TAS requiring accurate IAS, press, temp). Best Regards, Dave "YO" "Bill Daniels" wrote in message news:gw%zc.59643$HG.25574@attbi_s53... I've been analyzing the IGC files from my flights and comparing them to others. Generally, in good conditions, I'm circling less than 25% of the time. Other, far better pilots than I, are circling less than 15% of the time. This means that wind data that depends on the glider flying circles gets way out of date during the long glides. OK, "S" turns can give the computer a chance to compute wind if you remember to fly them but there are still a lot of long, straight glides. To compute real-time wind data we need Groundspeed, Ground Track (any GPS gives these)True Airspeed (Some computers do this if they have OAT, Pressure Altitude and IAS) and accurate heading data. Heading data it the tough nut to crack. So, how do we get Heading? One way might be to put a GPS antenna in each wing and look at the carrier phase difference. If the computer saw a constant track, it could assume the wings are level and determine a heading value. This heading value might update an aerospace quality MEMS heading gyro that would maintain a flow of heading data to the glide computer during times when the wings were banked. With good heading data we could get uninterrupted high quality wind data regardless of the gliders' maneuvering or lack of it. OK, RAS gageteers, how about it? Bill Daniels |
gives these)True Airspeed (Some computers do this if they have OAT, Pressure Altitude and IAS) and accurate heading data. Heading data it the tough nut to crack. So, how do we get Heading? One way might be to put a GPS antenna in each wing and look at the carrier phase difference. If the computer saw a constant track, it could assume the wings are level and determine a heading value. This heading value might update an aerospace quality MEMS heading gyro that would maintain a flow of heading data to the glide computer during times when the wings were banked. The LX 5000 has the facility for a digital compass - precisely for the reason that you are looking for a solution for. I have not used a digital compass with my unit so I have no idea if it works better than the other estimation methods used by the unit without a compass attached. Clinton LAK 12 |
"Dave Nadler YO" wrote in message om... Bill, you're absolutely right, during a dead straight glide with constant airspeed their isn't enough information to compute the result. With an SN10 you need to make an S-turn at least to get an update. The heading sensor issue is a bit difficult. Certainly it can be done with GPS using multiple antennas (I can't remember the commercial products that do this off-hand). Google and you'll find a few research projects using GPS for attitude as well as heading. Cost is not on for gliders real soon. Compasses are very cranky beasts, especially if they need to be glider- pilot-proof (about which I could tell stories for hours). Making something that is low-cost, self-calibrating, immune to stupid installations - that's the hard bit. Hope that all makes sense, Best Regards, Dave PS: Haven't seen anyone suggest a sun-tracker yet ? Or vision-system with terrain matching ? Bob Lepp e-mailed me info on a company called Aventech that makes wind direction detection equipment for crop dusters. These folks need very accurate winds aloft data to predict the drift of chemicals sprayed on crops. Their gadget works just like a glider computer with the addition of a two-antenna GPS array that provides heading data accurate to .5 degree. To cover any gaps in the GPS signal, they use a solid state inertial unit. Sensors that detect the earth's magnetic field will always be tricky. GPS heading sensing looks like a winner since we need the GPS receiver anyway. Maybe a couple of self-contained Bluetooth GPS receivers attached to the wingtips would work. An inertial measurement unit would be very useful for applications other than wind data. These could determine true vertical regardless of the glider's attitude and very accurately measure Z-axis acceleration. What vario maker wouldn't love to have that data. No doubt this will be expensive at first but then we couldn't afford GPS 20 years ago. Twenty years before that glider pilots couldn't afford radios. Electronics always seems to follow a learning curve that exponentially reduces cost. Bill Daniels |
This is what we need but smaller, cheaper, lighter and all other good things
engineering-wise. http://www.xbow.com/Products/product...s.aspx?sid=104 Bill Daniels "Dave Nadler YO" wrote in message om... Bill, you're absolutely right, during a dead straight glide with constant airspeed their isn't enough information to compute the result. With an SN10 you need to make an S-turn at least to get an update. The heading sensor issue is a bit difficult. Certainly it can be done with GPS using multiple antennas (I can't remember the commercial products that do this off-hand). Google and you'll find a few research projects using GPS for attitude as well as heading. Cost is not on for gliders real soon. Compasses are very cranky beasts, especially if they need to be glider- pilot-proof (about which I could tell stories for hours). Making something that is low-cost, self-calibrating, immune to stupid installations - that's the hard bit. Hope that all makes sense, Best Regards, Dave PS: Haven't seen anyone suggest a sun-tracker yet ? Or vision-system with terrain matching ? "Bill Daniels" wrote in message news:_y8Ac.53766$0y.15362@attbi_s03... Dave, can it give highly accurate, real-time wind data, second by second on a straight one hour glide? My last flight showed this problem during a long glide. For 30 miles the wind data showed SW winds at 20 knots but then I noticed the glider drifting to the west. Two 360 turns and the computer showed wind at 090 at 10 knots. When I crossed the wind shift line I had a chance to change strategy. 30 miles later when the wind error became obvious it was too late. More and more I think we need very accurate real-time wind data with no requirement to be constantly changing heading. A cheap, reliable heading sensor would make this possible. Bill Daniels "Dave Nadler YO" wrote in message m... Bill - The heading is not required. In the ILEC SN10 we do this without heading, and it normally has the wind by the time you're off tow. Pilot feedback and measurements indicate that we do it quite accurately. We just use TAS and GPS ground track over multiple observations (TAS requiring accurate IAS, press, temp). Best Regards, Dave "YO" "Bill Daniels" wrote in message news:gw%zc.59643$HG.25574@attbi_s53... I've been analyzing the IGC files from my flights and comparing them to others. Generally, in good conditions, I'm circling less than 25% of the time. Other, far better pilots than I, are circling less than 15% of the time. This means that wind data that depends on the glider flying circles gets way out of date during the long glides. OK, "S" turns can give the computer a chance to compute wind if you remember to fly them but there are still a lot of long, straight glides. To compute real-time wind data we need Groundspeed, Ground Track (any GPS gives these)True Airspeed (Some computers do this if they have OAT, Pressure Altitude and IAS) and accurate heading data. Heading data it the tough nut to crack. So, how do we get Heading? One way might be to put a GPS antenna in each wing and look at the carrier phase difference. If the computer saw a constant track, it could assume the wings are level and determine a heading value. This heading value might update an aerospace quality MEMS heading gyro that would maintain a flow of heading data to the glide computer during times when the wings were banked. With good heading data we could get uninterrupted high quality wind data regardless of the gliders' maneuvering or lack of it. OK, RAS gageteers, how about it? Bill Daniels |
Isn't there some form of flux gate compass which can be used? The GPS's we use originated in the maritime market (after NMEA is a maritime standard), surely there is a flux gate compass with NMEA output.
Rgds, Derrick. |
"David Starer" wrote in message ...
The GPS gives TRACK, not HEADING. It can't tell what direction the glider is pointing in, only the direction its motion is taking it across the ground. David Starer True, but the issue is confused because some Etrex models incude a magnetic heading sensor. Andy |
| Coupled approach? | Roy Smith | Instrument Flight Rules | 22 | September 29th 04 10:46 PM |
| GPS/Flight Planner/ATC/Auto Pilot | Dave Schwartz | Simulators | 11 | May 11th 04 03:05 AM |
| FA: 10 Watt - Solid State Digital VHF- Transceiver Unicom | OH | Aviation Marketplace | 0 | March 30th 04 03:29 PM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
| Great circle formulae, True cource and actual heading | Sims | Piloting | 27 | October 11th 03 02:55 PM |
