#41
#42
Andreas Maurer wrote in message . ..
I don't think that the scenario you describe can lead to a wing stall: The cause that returns the wing to normal deflection is of course that the pilot reduces AoA by pushing the stick forward. The instance the pilot reduces g-load this way he also reduces his stall speed - I doubt that it's possible to stall if the pilot was able to pull a high-g pull-up only one second before without having a highspeed stall. Of course the relative AoA-rise indeed occurs when the wing tips are moving downwards, but the overall AoA is reduced a lot more with the elevator (otherwise he woudn't lower the AoA enough to cause the rapid unbending of the wing). I couldn't find the photos last night so I can't attempt any measurements of wing deflection. The scenario I imagine is this. The pilot makes an agressive contest finish pull up. The pull up starts at over 100kts, the pilot continues to pull as the speed decays to say 60kts where the wing experiences an accelerated stall. The reduction in lift causes the wings to start to unflex. What happens next depends on how well the glider is coordinated and how quickly the pilot pushes forward to exit the accelerated stall. Isn't it possible that the push forward makes the wings unflex at a rate that leaves the tips stalled? Andy |
#43
#44
Andy Durbin wrote:
According to Thomas, Fundamentals of Sailplane Design, the wing twist of the ASW-20 is 2.5 deg (page 210). Isn't twist designed into a wing to prevent the tip stalling before the root? It is also used to adjust the lift distribution for decreased drag, and since the airfoil also changes from root to tip, it might be hard to determine (just from the numbers) why the designer chose to put twist into the wing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#45
Andy Durbin wrote:
I couldn't find the photos last night so I can't attempt any measurements of wing deflection. The scenario I imagine is this. The pilot makes an agressive contest finish pull up. The pull up starts at over 100kts, the pilot continues to pull as the speed decays to say 60kts where the wing experiences an accelerated stall. If he waits to 60 knots, he is well into a loop. Based on my contest finishes, I'd guess he'd be back at 1 G before the speed decreases to 85-90 knots. The high G part of the pull-up is very short - just long enough to get the glider aimed upward. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#46
Eric Greenwell wrote
Andy Durbin wrote: I couldn't find the photos last night so I can't attempt any measurements of wing deflection. The scenario I imagine is this. The pilot makes an agressive contest finish pull up. The pull up starts at over 100kts, the pilot continues to pull as the speed decays to say 60kts where the wing experiences an accelerated stall. If he waits to 60 knots, he is well into a loop. Based on my contest finishes, I'd guess he'd be back at 1 G before the speed decreases to 85-90 knots. The high G part of the pull-up is very short - just long enough to get the glider aimed upward. I've read most of these posts and now I'm thoroughly confused: 1. isn't it true that unless the pilot aggressively pushes over, the wings will unflex too slowly to cause a large AOA increase? And even then, the increase is relatively small - at most about 1 degree for realistic speeds of travel and rates of unflexure? 2. isn't it more likely that the pilot tried to initiate a low speed, initially low G turn, then as the load factor increased due to the increasing angle of bank the wing AOA went past the stalling angle and so the (then inevitable) spin became a fact? 3. everything I've ever read and learned about wing theory states that a stall results when the AOA is greater than the stalling angle - it doesn't matter what the G loading is or what the speed is. Rgds, Derrick Steed |
#47
On 15 Jul 2004 18:17:04 GMT, Derrick Steed
wrote: Eric Greenwell wrote Andy Durbin wrote: I couldn't find the photos last night so I can't attempt any measurements of wing deflection. The scenario I imagine is this. The pilot makes an agressive contest finish pull up. The pull up starts at over 100kts, the pilot continues to pull as the speed decays to say 60kts where the wing experiences an accelerated stall. If he waits to 60 knots, he is well into a loop. Based on my contest finishes, I'd guess he'd be back at 1 G before the speed decreases to 85-90 knots. The high G part of the pull-up is very short - just long enough to get the glider aimed upward. I've read most of these posts and now I'm thoroughly confused: 1. isn't it true that unless the pilot aggressively pushes over, the wings will unflex too slowly to cause a large AOA increase? And even then, the increase is relatively small - at most about 1 degree for realistic speeds of travel and rates of unflexure? 2. isn't it more likely that the pilot tried to initiate a low speed, initially low G turn, then as the load factor increased due to the increasing angle of bank the wing AOA went past the stalling angle and so the (then inevitable) spin became a fact? 3. everything I've ever read and learned about wing theory states that a stall results when the AOA is greater than the stalling angle - it doesn't matter what the G loading is or what the speed is. I'm not certain any of us know enough detail about the accident to make a sensible guess about its cause. FWIW, on Tuesday evening I decided to investigate turning stall/spin behaviour in my '20 at a sensible altitude. It was calm and with little air movement under a high overcast. With the aircraft clean and flaps at zero (setting 3) I flew some moderately steep turns - about 45 degrees of bank and at speeds ranging down to about 43 kts. This was completely uneventful - no buffeting, burble or hints of departure. In short, it flew like a pussycat. I'll try this again by myself in a turbulent thermal next time because all that series of turns told me was that in nearly still air my '20 can fly uneventful turns at stupidly slow airspeeds. By comparison I typically fly at 48-50 kts for that steep a turn in zero flap during normal thermalling turns. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
#48
Isn't it possible
that the push forward makes the wings unflex at a rate that leaves the tips stalled? No. The wings unflex as a response to reduced angle of attack and thus load. It does not make sense that the wing could unflex faster than the load being removed. If that was the case, then the wings would not flex in the first place. - Mark Navarre 2/5 black ace LoCal, USA remove brain to reply - |
#49
Andy Durbin wrote:
Isn't it possible that the push forward makes the wings unflex at a rate that leaves the tips stalled? They unflex because the load is removed. In order to stall they would have to unflex faster than the load is removed. If the pilot is pushing, the stall speed can go _way_ down. It's when he starts to load the wings again that his technique, or failure to track his loss of airspeed in the pull/push, can bring about the stall. Jack |
#50
Stalling of a wing is connected to AoA in the first place, nothing else.
-- Bert Willing ASW20 "TW" "Martin Gregorie" a écrit dans le message de ... On 15 Jul 2004 06:43:05 -0700, (Andy Durbin) wrote: (Chris OCallaghan) wrote in message . com... In fact, if you think about it, there would be a change in AoA as the wings returned to their normal 1g state. The AoA increase at the tips would be greatest and negligible at the roots. How large an increase are we talking about? Pretty darn small. An amusing exercise though. A friend once figured out how thick a layer of material a tire leaves on the road, given normal wear. This seems on the same order. According to Thomas, Fundamentals of Sailplane Design, the wing twist of the ASW-20 is 2.5 deg (page 210). Isn't twist designed into a wing to prevent the tip stalling before the root? If my numbers were derived for 68 knots instead of 40kts they give a result that is similar to the designed-in wing twist. In other words, the wing flex effect appears to completely offset the protection provided by the wing twist. If the pilot is pushing over hard the wing will be carrying a reduced load. As a result the stalling speed will be reduced: remember that a stall occurs when the wing fails to generate the lift needed to support the current load on the wing and is only indirectly connected with the AOA and Cl figures. In the case we're considering the stall speed will be reduced below normal because the push-over is creating a reduced G situation. I haven't noticed you mention this factor. How does its inclusion affect your calculation? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 05:49 PM |
| spin characteristics of new racers | Andy Durbin | Soaring | 14 | January 31st 04 07:05 AM |
| Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 03:18 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
