Sugar-powered plane unveiled
Old October 23rd 04, 08:00 AM
Mal
Default Sugar-powered plane unveiled
It would make a good glider tug !
BRAZILIAN aircraft manufacturer Embraer today unveiled the world's first
mass-produced commercial aircraft that runs on sugar cane ethanol fuel.
The Ipanema aircraft is designed to take advantage of Brazil's supplies of
the fuel, which is cheaper, burns more cleanly and is more efficient than
fuels refined from crude oil, company officials said.
Brazil is also a major producer of ethanol fuel, extracted from sugar cane.
Satoshi Yokota, a top Embraer official, said operating the plane on ethanol
was three to four times cheaper than using airplane fuel.
The Ipanema is designed mainly as a crop duster.
www.embraer.com
www.mals.net
Old October 23rd 04, 04:50 PM
Stealth Pilot
well those claims are deluded nonsense arent they.
ethanol is less efficient as a fuel energy source than avgas.
200 litres of ethanol does not have the anywhere near the range of
avgas and being a fermented biological material we'd denude the entire
world of arable land if we switched to it globally as a fuel.
....but then the greens were never good at maths.
Stealth Pilot
Old October 23rd 04, 05:11 PM
Mal
Most the gliders I fly have better range than most small aircraft on about
5-10 litres of another aircrafts avgas or a litre of petrol on a winch
launch.
I attached a picture of the aircraft.
The gliding movement is always looking for tug options as the pawnee brave
is no longer produced !
"Stealth Pilot" wrote in message
cane.
ethanol
Stealth Pilot
Old October 23rd 04, 08:03 PM
Stefan
Energy per volume isn't interesting, energy per mass ist. (No, I don't
have the numbers hany right now.)
The actual global food production is enough to feed twice the global
population. It's only a question of distribution.
Neither are you, when the result doesn't fit your opinion.
Stefan
Old October 23rd 04, 09:44 PM
RHWOODY
If the "greenies" really wanted to do
something meaningful they would
put all of their energy and money
into stopping the population growth -
most problems have their basis in more
and more people on this earth. The
"greenie's" present efforts only result
in bitching about almost everything.
Old October 24th 04, 01:28 AM
Eric Greenwell
I believe the "greenies" do not favor ethanol, becuase it is so energy
intensive to produce (watering, fertilizing, cultivating, and harvesting
the crop, and finally manufacturing the enthanol) that it is not really
"green"; however, it is favored by corporate farms because it provides
another market for the subsidized corn they grow, a potentially bigger
market than even corn syrup.
And many (most?) greenies do believe in and pursue population
stabilization through a variety of means, especially in the less
developed countries, generally including poverty reduction, decreased
childhood mortality, empowering women, and increasing family planning
options.
Interestingly, a stable population brings it's own problems, but
generally not the enviormental type.
Eric Greenwell
Washington State
USA
Old October 24th 04, 04:32 AM
matt weber
On Sat, 23 Oct 2004 22:50:24 +0800, Stealth Pilot
Stealth Pilot
It is actually far worse than that. Without distillation, the best you
can do is 97% ethanol, with 3% water, which makes it unacceptable as
fuel. So you have to distill it to get rid of the 3% water.
The problem is that it takes more energy to distill the alcohol than
it produces as energy. That is why 100% ethanol is so expensive. The
only thing that makes it cheaper as fuel is the favorable tax
treatment it usually gets.
Old October 24th 04, 05:00 AM
Bill Daniels
"matt weber" wrote in message
of
than
cane.
ethanol
Stealth Pilot
I've always wondered why those clever bioengineers couldn't teach some bugs
to produce iso-octane instead of ethanol. Iso-octane is the lab reference
for 100 octane motor fuel.
Old October 24th 04, 03:24 PM
Stealth Pilot
On Sun, 24 Oct 2004 03:00:56 GMT, "Bill Daniels"
Stealth Pilot
now that really is the answer isnt it. we have the studies (they were
published in scientific american a few months ago) that point to
petrol being the most efficient fuel on the planet.
pressure with chromium and iron as catalysts will synthesise
hydrocarbons from constituent elements. there must be some
bioengineering available that makes use of that fact or some other
method for synthesising hydrocarbons. after all how were they produced
in the first place?
Stealth Pilot
Old October 24th 04, 06:45 PM
Steve / Sperry
I have seen 2 perspectives on the issue... one says its more efficent
to produce the other says it is less efficent?
Opinion 1/ From a production standpoint... "Ethanol production is
extremely energy efficient, with a positive energy balance of 125%,
compared to 85% for gasoline. Ethanol production is by far the most
efficient method of producing liquid transportation fuels. According
to USDA, each BTU (British Thermal Unit, an energy measure) used to
produce a BTU of gasoline could be used to produce 8 BTUs of ethanol."
Or 2/ David Pimental, a leading Cornell University agricultural
expert, has calculated that powering the average U.S. automobile for
one year on ethanol (blended with gasoline) derived from corn would
require 11 acres of farmland, the same space needed to grow a year's
supply of food for seven people. Adding up the energy costs of corn
production and its conversion into ethanol, 131,000 BTUs are needed to
make one gallon of ethanol. One gallon of ethanol has an energy value
of only 77,000 BTUS. Thus, 70 percent more energy is required to
produce ethanol than the energy that actually is in it. Every time you
make one gallon of ethanol, there is a net energy loss of 54,000 BTUs.
Mr. Pimentel concluded that "abusing our precious croplands to grow
corn for an energy-inefficient process that yields low-grade
automobile fuels amounts to unsustainable subsidized food burning".
If the fuel is efficent to produce then I would like to believe the
following quote from the industry... Ethanol is a much cleaner fuel
than gasoline, reducing air-pollution. It is a renewable fuel made
from plants -- unlike fossil-fuels, manufacturing it and burning it
does not increase the greenhouse effect.
Stealth Pilot
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 08:27 AM
