Crashing a '12
Old November 3rd 04, 07:56 AM
Mark Grubb
Default Crashing a '12
The 12 has a composite Glass - Balsa - Glass Fuselage
that is probably at least 0.75 inches thick. It is
a very, very sturdy structure.
The 12 would probably be airworthy with either the
glass alone or the wood alone. Laminated together,
it is a tank.
Old November 3rd 04, 03:51 PM
Eric Greenwell
it is a tank.
The designer of the ASW 12 also designed the ASW 24, for which he was
awarded an OSTIV prize for his contribution to safety. I'm tempted to
believe he learned a lot between the 12 and the 24. Some features, like
the very stiff cockpit rails, glass, Kevlar, and carbon construction,
and a "soft" nose, are not present in the 12.
It would be interesting to hear his opinion (and those of other
knowledgeable people) on the relative merits of the two fuselage
constructions.
Eric Greenwell
Washington State
USA
Old November 4th 04, 08:15 AM
I have had a couple of very heavy landings/groundloops in my LAK 12
('12). Comments after the first one, which involved a tree and resulted
in lots of paperwork, is that no German glider would have survived with
no damage. Thank goodness for Eastern Block over-engineering.
Clinton Birch
LAK 12
Old November 5th 04, 09:51 AM
Clint
I think you were misled by the "12" in the subject line, because the '12
Mark and I were referring to is the ASW 12. It's quite unlike the LAK
12, which is basically an ASW 17.
As far as "over-engineering" goes, I've looked at the LAK 12, and I
didn't see anything special about the design of the cockpit, which
seemed to share all the design features and problems of gliders designed
in the 70's. The cockpit design is the part of the glider that interests
this pilot the most when it comes to crashing.
I did understand you were referring to the ASW 12. Beautiful glider
but I have never had the chance to see one. I used the string to refer
to the LAK 12 because it is also incredibly strong - I should have
added a :-) when I referred to the LAK 12 as a '12.
I apologise if my understanding of the term "over-engineering" is
different from that associated with the term elsewhere in the world. I
used it to express the common disbelief in the engineers'
calculations. It is the exact opposite of "beautifully-engineered"
which would be used to express amazement at the fine calculations used
to manufacture a piece with no excess or waste (Lennie would
appreciate "beautiful-engineering" but despise "over-engineering" :-)
). The use of extra material just in case the engineers' calcs are
incorrect is "over-engineer" e.g. using a piece 2" thick when the
engineer says 1" is more than adequate. The LAK appears to have been
constructed with that principle in mind and the result is an
incredible tough aeroplane - like most things built by the old Eastern
Block countries. You should see the suspension system on the LAK T4
trailers - could have come off a T62 tank!
The LAK 12 manual does say the glider has a crashworthy cockpit but I
agree that there isn't the beautiful design found in modern AS gliders
with their strengthened cockpit structures. I think it is considered
crashworthy because it is so thick.
It is a common mistake to say the LAK 12 is basically an ASW 17. The
two have similar profiles and wingspans but the wing profile is closer
to the Nimbus 2 (Wortman FX67) than ASW 17 (modified Wortmann FX62).
The details are actually more Jantar 1 than anything German. The LAK
12 has a single piece wing, which is very different from the Nimbus 2
or ASW 17, which have 2 piece wings. What is similar is the docile
handling and performance - although at higher speeds the ASW 17 should
run away from the LAK. The LAK 12 was designed at a time that the ASW
17 and Nimbus 2 were already being replaced by the ASW 22 and Nimbus 3
respectively. It was designed as a training glider for the Russians
(future airforce pilots and government sponsored clubs), rather than a
competition machine.
Off the topic - the weather bureau are predicting 4m/s thermals and 17
000ft cloud base. A bit of a poor day as earlier in the week they were
saying 6m/s and 20 000ft. Looks like the old LAK will have to stretch
its legs tomorrow. Eat-your-heart-out all those in the Northern
Hemisphere!
Clinton Birch
LAK 12
Old November 5th 04, 10:11 AM
Bert Willing
"Crashworthy" nowadays refers to the pilot's ability to survive a crash -
not the aircraft structure comeingout of a crash undamged. A sturdy,
tank-like design very often means not crashworthy _at all_.
Bert Willing
ASW20 "TW"
"Clint" a écrit dans le message de news:
Hemisphere!
Clinton Birch
LAK 12
Old November 5th 04, 12:10 PM
Mike Hessington
Clint,
You are confused.
I have visited the LAK factory. As a result of this
visit I can't agree with you views on 'over engineering'
of LAKs.
The LAK 17/19 is under engineered. The spars appear
flimsy and the cockpit has no real protection at all.
In fact, one of them broke up at low level during
a test flight and just about killed the pilot.
If I had to crash a glider I would want to be sitting
in an ASW27 or 28.
The Germans calculate, design and test in order to
get things right. Over engineering is fine if you
are building tanks, not gliders.
Mike
X01
in my LAK 12
a tree and resulted
have survived with
Clinton Birch
LAK 12
Old November 5th 04, 06:03 PM
Ian Cant
As I sadly recall, over-engineering means adding unnecessary
complexity; adding unnecessary material is over-building.
Ian
At 11:36 05 November 2004, Mike Hessington wrote:
Clint,
You are confused.
of LAKs.
in an ASW27 or 28.
Mike
X01
in my LAK 12
a tree and resulted
have survived with
Clinton Birch
LAK 12
Old November 5th 04, 06:44 PM
Marc Ramsey
You are confused.
of LAKs.
No, he's not confused. You are. The LAK-12 is an over-engineered tank.
I've seen a LAK-12 make it through a botched takeoff with a few
scratches, that would have reduced many other gliders to a pile of
debris. With all that over-engineering, the one-piece wing of the
LAK-12 weighs only a few pounds more than the inner panel of the similar
ASW-17 wing.
The LAK-17/19 are entirely new designs that have nothing much to do with
the 12. The the spar looks flimsy because it is made of pultruded
carbon rods. It is as strong or stronger than wings made using
traditional composite spar techniques. The 17/19 cockpit area has
several layers of Kevlar. It is not a "safety" cockpit like the newer
Schleicher and DG designs, but it is certainly safer than many older
German designs.
I believe the LAK-16 that crashed had a traditional spar...
in an ASW27 or 28.
I agree, I wish I could afford one.
The LAK-17/19 have several innovative design/safety features that the
Germans haven't managed to pick up on with all of their fine
engineering. I have some real issues with the factory about their
post-sale support, but I think the basic structural design of the
LAK-17A we own is as good as the DG-303, Ventus B, ASW-20B, and Duo
Discus (which was among those needing spar repair, BTW) I've also owned.
I've flown my LAK-17A in some of the strongest conditions in the
world, and it hasn't broken up on me yet...
Marc
Old November 5th 04, 07:10 PM
Raphael Warshaw
Does anyone have more information on the "low level breakup" of a LAK-17/19
referred to in the Mike Hessington post?
Ray Warshaw
1LK
Clint,
You are confused.
of LAKs.
Crashing Experimental on America's Funniest Home Videos Jay Home Built 7 March 10th 04 01:11 AM
