Cozy, Long ezy, and diesel engine.
Old February 17th 05, 04:54 AM
Bill Daniels
"Morgans" wrote in message
"LCT Paintball" wrote in message
news:F7QQd.5629$4D6.3605@attbi_s51...
True, but that issue can be fixed.
That comment was about fuel jelling. What are your fixes? Will it
end
up
making the cost higher? What happens when you go to other airports
that
don't have auto diesel fuel?
The first fix would be to pump extra fuel through the system so that it
can
be warmed by the engine, then returned to the tank. Perhaps you could
even
run it through the oil cooler before sending it to the engine. There are
also additives that are routinely used to keep the fuel from jelling.
The additives will be the best bet, but expensive, when you add that to
price for fuel. Truckers use it, but they are only dealing with negative
in
the teens, not 20 to 30 below, with a huge moving air factor, around the
fuel. All that fuel, basicly in direct contact with the air, with Al's
great thermal conductivity. You would need to insulate the tank. Not
easy,
and more weight. Now add in whatever fuel heat exchangers, lines, and
pumps, and more weight, and also, complexity. (read ways to bring you down
before you wanted to) I didn't do any calcs, but you would need to
capture
almost all of the engine's waste heat to do this without additives.
I realize that you would not be in that kind of temperatures all of the
time, but all you need is one time where things were colder than you
thought, and......
Many around here will talk about the hassles of using your own auto fuel,
and what happens when you travel away from home. That is what the
airplane
you are describing will be good at; great economy, and legs.
Shoot, one nutcase that hangs out around here even made his own fuel truck
to feed his habit. g
The old saying about asking how much fuel that yacht burns? If you have
to
ask how much fuel it burns, you can't afford the boat.
Same thing here. Jet fuel is not that bad, it will give you great
economy,
and it is available, and won't end up killing you. Just my humble
opinions.
Jim in NC
You could use the fuel as an engine coolant in a liquid cooled diesel like
the Deltahawk.
With a wet wing, you'd get hot wing anti-ice capability and a skin radiator
in the bargain.
'Course, it wouldn't work if you ran out of fuel.....
Bill Daniels
Old February 17th 05, 05:03 AM
the Deltahawk.
in the bargain.
1960's vintage Allis Chalmers crawlers using the diesel fuel as a cooling
medium and working medium for the torque converter. Worked well.
tom
Old February 17th 05, 05:13 AM
Morgans
radiator
in the bargain.
Bill Daniels
Couple years back, someone did a pretty good set of calculations on that.
If you captured 100% of the engine waste heat, It wouldn't be even close
enough to de-ice a wing.
Turbines do it, cause they burn tons of fuel. IC engines don't come close.
Jim in NC
Old February 17th 05, 05:45 AM
LCT Paintball
Tell you what. Get out your planner, then write down in one month, to
check
and see if the engines are shipping, right then. If not, write it down to
check in a month. Repeat as necessary.
I think I get your point.
Old February 17th 05, 06:16 AM
LCT Paintball
easy,
Cozies and Long ez's aren't aluminum. I haven't studied what the wings look
like on the inside, but don't they already have foam in them? Do you still
think they would loose too much heat?
The fuel pumps are already there, and so are the fuel lines. The only thing
you would be adding is a device to transfer the heat from the engine oil, or
radiator to the fuel. I would think (read I'm not smart enough to do the
calculations) that the improved airodynamics of not having to have a
radiator in the wind would offset the extra weight of the heat exchanger.
airplane
My understanding is that they run equally well off Jet-a. If there's not any
diesel around, just filler up with Jet-a.
to
That is a good statement for me. Money is always an issue. I have been known
to spend $1,000 so I can save $100.
economy,
opinions.
I like that not killing me part. It's a rule that I try to live by.
I also like opinions. They make me think.....
Old February 17th 05, 04:34 PM
Dude
check
No doubt, the Liberty airplane has been ready to ship in 2 to 3 months for 2
to 3 years!
Believe it or not, the jack ass that sold all those useless orders is still
selling airplanes.
Old February 18th 05, 02:47 AM
Morgans
look
Right, I forgot that this was all about a long. Less loss, but it still is
zipping through the air, to help. How much? I don't know.
thing
or
If it did hold the heat real well, you might overheat the fuel, and have no
way to cool the oil. Very bad.
If this is a new tec engine, there is already a real big unknown added to
your plane. The old experience around here says not to add too many new
things to the mix, all at once. It adds to the chance of something going
wrong. It will go wrong, you just have to hope not too bad.
Nice thoughts, but I think it is valid to try to keep it simple.
Jim in NC
Old February 20th 05, 03:14 PM
to
check
down to
Also known as the "Zoche syndrome." www.Zoche.com Ah, yes, I
remember it well..........being excited by Michael Zoche's "pitch" back
in....... I think it was 1980 !!!
Neal
Old February 21st 05, 08:58 PM
Bill Daniels
Compression ignition Wankel-type rotaries have been built and run.
Bill Daniels
"Bryan Martin" wrote in message
No. The Mazda rotary engine is an Otto cycle engine, the same cycle used
in
a piston engine. Jet fuel has too low an octane rating for an Otto cycle
engine, you would get pre-ignition. You would have to convert it to direct
fuel injection to use these low octane fuels. You wouldn't gain much
efficiency unless you also found a way to significantly increase the
compression ratio as well.
in article , Dan Nafe at
wrote on 2/21/05 12:32 PM:
would a mazda/wankle-rotary run on Jet-A, JP-4, etc?
Bryan Martin
