#11
Not at all unusual. You have to keep both the approach plate and low
altitude chart (or area chart) close at hand for reference. Bob Gardner "Marco Leon" mleon(at)optonline.net wrote in message ... Has anyone received a route clearance that included an intersection that was only on an approach chart and not in an Enroute Chart? Flew IFR from FRG to GON with the following clearance: Farmingdale Three, radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct. For the life of me I couldn't find MONDI on the enroute. However, it was in my (up-to-date) Garmin 430 database and it was pretty much on the way (albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the active approach which made it even more difficult to figure out. Is this commom anywhere else? Should they have told me it was only on an IAP chart? Are all the fixes on any of a given airport's approach charts fair-game to include in an enroute clearance? Regards, Marco Leon |
"Marco Leon" mleon(at)optonline.net wrote in message ... Has anyone received a route clearance that included an intersection that was only on an approach chart and not in an Enroute Chart? Flew IFR from FRG to GON with the following clearance: Farmingdale Three, radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct. For the life of me I couldn't find MONDI on the enroute. However, it was in my (up-to-date) Garmin 430 database and it was pretty much on the way (albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the active approach which made it even more difficult to figure out. Is this commom anywhere else? It's not unusual to use an approach fix at the destination airport. Should they have told me it was only on an IAP chart? Since you were landing there they probably assumed you were familiar with the approaches. Are all the fixes on any of a given airport's approach charts fair-game to include in an enroute clearance? If you're landing at that airport, yes. |
"Ron Rosenfeld" wrote in message ... Had you queried the controller about the location of the intersection, he would be able to give you coordinates. Possibly, but not necessarily. |
"Marco Leon" mmleon(at)yahoo.com wrote in :
Now THAT makes sense. Is that a common thing with the air carriers? Air carriers almost always use canned flight plans that never vary, and they seldom file /G. I file /G every time as a Part 135 pilot, and seldom to the same place, so every flight plan is different, and the routes can be really weird, especially the ones going offshore. If you have a GPS, then all you need to do is pull the intersections up on it. The GPS doesn't care where the waypoint is charted, it just knows where it is, and will take you there. Another place to look for intersections, especially at or near your destination, is on the STARs. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
Good advice. However, it's not always practical. As I learned early on in my first few flights as a newly-minted IFR pilot, you ain't always going to get what you file. Further more, you ain't always going to fly what you're initially cleared for. I've had plently of flights where my initial clearance didn't even remotely resemble what I filed, and what I actually ended up flying didn't exactly match the initial clearance. ATC has a interesting habit of dynamically re-routing you based on traffic, weather, and how nice they're feeling that day. Flexibility is certainly a key element of IFR flight (as is not accepting a clearance that you're not comfortable with). Being able to "re-route" in flight with the low-altitude chart in your lap (or high-altitude, if you're lucky enough to fly such a beast) is a necessary skill in IFR flying. -- Dane In article , wrote: Here's some advice. Never launch on a clearance you have not thoroughly reviewed for accuracy, fix by fix, right to the ground. That way, you won't find yourself airborne reworking your clearance to nowhere out with a controller (assuming your radio is working at the time). |
"Dane Spearing" wrote in message ... I've had plently of flights where my initial clearance didn't even remotely resemble what I filed, and what I actually ended up flying didn't exactly match the initial clearance. ATC has a interesting habit of dynamically re-routing you based on traffic, weather, and how nice they're feeling that day. Traffic and weather are pretty good reasons for rerouting, moods are not. Flexibility is certainly a key element of IFR flight (as is not accepting a clearance that you're not comfortable with). Sometimes you have to choose between being a bit uncomfortable and not making the flight. |
is MONDI on a SID ? Information on fix MONDI Name: MONDI Identifier: MONDI Location: 41-09-17.220N / 072-11-58.770W (NEW YORK) ARTCC: ZBW Fix to be published? yes Navaid radial/DME: MAD /cgi-bin/navaid-info?a=MADr126.00 GON /cgi-bin/navaid-info?a=GONr226.45 HTO /cgi-bin/navaid-info?a=HTOr033.56 I-GON SW CRS/13.23 Charts: IAP Fix use: Reporting point if you don't under stand the clearance ask ? for clarification try not to accept any clearance you don't understand jon |
At an airport with multiple approaches, it still seems cumbersome spread out
all the approach plates to understand an enroute clearance. One or two would be fine but airports like KFRG with 5 or 6 doesn't strike me as logical since the winds aren't (and can't be) taken into account. Well, now I know and I appreciate the new knowledge. Thanks Bob, Marco "Bob Gardner" wrote in message ... Not at all unusual. You have to keep both the approach plate and low altitude chart (or area chart) close at hand for reference. Bob Gardner "Marco Leon" mleon(at)optonline.net wrote in message ... Has anyone received a route clearance that included an intersection that was only on an approach chart and not in an Enroute Chart? Flew IFR from FRG to GON with the following clearance: Farmingdale Three, radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct. For the life of me I couldn't find MONDI on the enroute. However, it was in my (up-to-date) Garmin 430 database and it was pretty much on the way (albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the active approach which made it even more difficult to figure out. Is this commom anywhere else? Should they have told me it was only on an IAP chart? Are all the fixes on any of a given airport's approach charts fair-game to include in an enroute clearance? Regards, Marco Leon Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
"Dane Spearing" wrote in message ... Good advice. However, it's not always practical. As I learned early on in my I've had plently of flights where my initial clearance didn't even remotely resemble what I filed, and what I actually ended up flying didn't exactly match the initial clearance. If I made it from Boston to White Plains without getting re-routed at least once I'd expect to see locusts, four horsemen, and dogs and cats living together when I landed. You file the preferred routes, they clear you somewhere else, and up in the air they change their minds again often more than once in the flight. -cwk. |
Stan,
They may not file /G but all of our planes are equipped with GPS and use it all the time. They are offered direct to a fix outside the rage of a VOR and take it all the time. Michelle (veteran of many jumpseat rides) Stan Gosnell wrote: "Marco Leon" mmleon(at)yahoo.com wrote in : Now THAT makes sense. Is that a common thing with the air carriers? Air carriers almost always use canned flight plans that never vary, and they seldom file /G. I file /G every time as a Part 135 pilot, and seldom to the same place, so every flight plan is different, and the routes can be really weird, especially the ones going offshore. If you have a GPS, then all you need to do is pull the intersections up on it. The GPS doesn't care where the waypoint is charted, it just knows where it is, and will take you there. Another place to look for intersections, especially at or near your destination, is on the STARs. |
| Thread Tools | |
| Display Modes | |
| No SID in clearance, fly it anyway? | Roy Smith | Instrument Flight Rules | 195 | November 28th 05 11:06 PM |
| Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 07:02 PM |
| Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 10:11 PM |
| Alternate Intersection Name in Brackets? | Marco Leon | Instrument Flight Rules | 7 | January 22nd 04 05:55 AM |
| Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 02:31 AM |
